    Duet 3 Mainboard 6HC - initial production run.
    243
    33.4k
    • gtj0undefined
      gtj0 @wilriker
      @wilriker said in Duet 3 Mainboard 6HC - initial production run.:
      @gtj0 There is also MonoDevelop as an IDE. And the apps are actually based on .NET Core and as such do not need Mono (if anyone needs more recent packages of .NET Core on Arch Linux I have them in my Dropbox 😁 ).
      EDIT: one of these days I need to look into finding a good Language Server for C# and then I can develop in neovim. 🙂
      MonoDevelop doesn't support .NET Core projects using .csproj project files. It complains about the project file not having a ProjectGuid.
      BTW, I have a Wandboard loaded with Fedora 30 and SPI support running the DSF. No changes to the DSF needed but then I don't have a Duet3 board to test with 🙂
      • T3P3Tonyundefined
        T3P3Tony administrators @deckingman
        @deckingman said in Duet 3 Mainboard 6HC - initial production run.:
        @t3p3tony
        Tony, there is a bit of a conflict in the documentation https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview.
        The picture of the boards has a graphic with the words "6x stepper drivers rated to 4A peak". But under "Features" the words say "Six high-current advanced TMC5160 stepper drivers: SPI controlled will all the latest Trinamic features. Maximum motor current 6.3A peak per phase (4.45A RMS)."
        As DC ran the thermal tests on an expansion board at 6.3A, I'm assuming the "4A" in the graphic is incorrect.
        Thanks Ian - its fixed now
        www.duet3d.com
        • T3P3Tonyundefined
          T3P3Tony administrators @A Former User
          @calvinx Thats the plan - just see if we can get them sorted in time for this initial batch.
          www.duet3d.com
          • evan38109undefined
            evan38109
            Dumb question: what voltage do the 5A OUT1-3 receive, the ones intended for "extruder heaters or similar?" Is it just VIN?
            https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_Heating_Fans
            (Apologies in advance if there's a better place to ask!)
            A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
            • A Former User?
              A Former User @evan38109
              @evan38109 said in Duet 3 Mainboard 6HC - initial production run.:
              Is it just VIN?
              yeah
                dc42 administrators @evan38109
                Yes.
                • deckingmanundefined
                  deckingman @T3P3Tony
                  @t3p3tony said in Duet 3 Mainboard 6HC - initial production run.:
                  @t3p3tony
                  Still showing 4A here https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview
                  • wilrikerundefined
                    wilriker @gtj0
                    @gtj0 said in Duet 3 Mainboard 6HC - initial production run.:
                    It does so for me. Which versions of MonoDevelop and .NET Core do you use? I have MonoDevelop 7.8.3 and .NET Core 2.2.401 (with 2.2.6 Runtime).
                    Manuel
                    My Tool Collection
                    gtj0undefined 1 Reply Last reply Reply Quote 0
                    • A Former User?
                      A Former User @T3P3Tony
                      Thanks for the clarification.
                      Whats the plan to cater for those that purchased the initial batch if you cant amass connectors and plugs in time ?
                      • Dougal1957undefined
                        Dougal1957
                        @t3p3tony Tony how is the pr-orders going for the first batch I need to order one but won't be able to till the end of this week?
                        Cheers
                        Doug
                        Danalundefined 1 Reply Last reply Reply Quote 0
                        • gtj0undefined
                          gtj0 @wilriker
                          .NET Core is the same but MonoDevelop is 5.10.0 which is what's packaged for Fedora. Upgrading to 7.8 fixed it. Thanks Manuel!
                          • Danalundefined
                            Danal @Dougal1957
                            @dougal1957 said in Duet 3 Mainboard 6HC - initial production run.:
                            Cheers
                            Doug
                            Also curious. I'll order one, just to support you guys, if there are enough left to stand a good chance of the order going through in this first batch.
                            • fotomasundefined
                              fotomas
                              The "Hardware overview" of the Duet 3 says "Ethernet for future expansion", I am guessing that this is a typo and the board has an ethernet connection not using WiFi?
                                deckingman @fotomas
                                @fotomas The RPi has an RJ45 Ethernet which is what will be used for the web server etc. So my guess (and it is just a guess) would be that it's not typo but is indeed an additional Ethernet connector.
                                • A Former User?
                                  A Former User @deckingman
                                  @deckingman
                                  You are correct the pi 3B+ also has wifi
                                  @fotomas
                                  I think you would benefit from reading and analyze and digest the documentation in greater detail, as guessing is the mother of all F******s
                                  • A Former User?
                                    A Former User
                                    The ethernet port has been covered earlier in this very thread..
                                    https://forum.duet3d.com/post/104297
                                    https://forum.duet3d.com/post/104241
                                      dc42 administrators @deckingman
                                      The Ethernet connector is there for 2 reasons:
                                      1. For possible support of EtherCat in future.
                                      2. We have a small number of OEMs who use Duet 2 in print farms, where one PC uploads GCode files to multiple Duets. They will need to replicate this with Duet 3. So there will be the possibility of running the Duet 3 in standalone mode with a local SD card and no RPi. Then the Ethernet port will be used to upload files, send commands and get status, just like the Duet 2. But we haven't yet decided whether to fit the SD card socket as standard to the initial production run.
                                      gtj0undefined fotomasundefined 2 Replies Last reply Reply Quote 0
                                      • gtj0undefined
                                        gtj0 @dc42
                                        @dc42 If you decide to not populate them, will the Duet3's be field upgradable if we decide we'd like that functionality? I.E. Is it just a matter of adding the magnetics/jack and the sd card holder?
                                        • T3P3Tonyundefined
                                          @deckingman yes 4A but RMS now. David has tested over 4A RMS but I will keep the claim to 4 for now until we have done more testing
                                          www.duet3d.com
                                          DocTruckerundefined 1 Reply Last reply Reply Quote 0
                                          • T3P3Tonyundefined
                                            T3P3Tony administrators @Danal
                                            @danal @Dougal1957
                                            We still have some of the first batch unallocated. When we have sold out of that production run it will be out of stock on the website.
                                            The "normal" production run later this year will not be a pre-order.
                                            Cheers
                                            Tony
                                            www.duet3d.com
