    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    32.3k
    • Sindariusundefined
      Sindarius
      Been a while since I provided an update. I have been working toward getting my viewer converted to a plugin in 3.2. Here's a little sneak peek of where it is at today.
      1 Reply Last reply Reply Quote 14
      • PCRundefined
        PCR
        Woow looking Forward to it
          Sindarius
          For anyone who is building and running the latest beta 3.2 you can install and test the plugin. Enjoy!
          https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.5.0
          1 Reply Last reply Reply Quote 6
          • PCRundefined
            PCR
            Yeah! Super nice work!
            Best
            • copystringundefined
              copystring
              Hey, this requires DWC 3.2-beta3 but there is no beta3 on github? Only beta2.
              Compiling the source code of DWC results in "Plugin requires incompatible DWC version (need 3.2.0-beta3, got 3.2.0-beta3pre)"
                Phaedrux Moderator @copystring
                @copystring You may want to wait for RRF 3.2 beta3 to be released if you don't want to compile it yourself. Sounds like you've got DWC compiled, but not the firmware itself.
                  jay_s_uk @Phaedrux
                  Works for me when using the latest code off GitHub to compile my own
                    Sindarius
                    Just finished implementing object cancelling in the 3d viewer.
                    https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.6.0
                    A Former User? 1 Reply Last reply Reply Quote 4
                    • PCRundefined
                      PCR
                      What What What! Thats a game changer!
                      Sindariusundefined 1 Reply Last reply Reply Quote 0
                        Sindarius @PCR
                        @PCR I am cleaning up some of the view so it looks a little cleaner.
                        I am still working through some transparency order issues. (Always a PITA)
                        • Vetiundefined
                          Veti
                          awesome work.
                          • oozeBotundefined
                            oozeBot
                            Great work! I just installed and am excited to give it a try this weekend. One bit of initial feedback - it would feel much more intuitive if there was an option to flip the camera control around and the center scroll wheel's zoom..
                              Sindarius @oozeBot
                              @oozeBot Noted. Appreciate the feedback. I'll have to look into making that an option. I think some of it comes from how you play video games. I tend to use inverted mouse when I play games so it has been more natural to me, I can see that being a problem for others.
                              I am resolving some alpha blending issues and trying out some different textures.
                              I expect to probably have another version out this evening.
                              • Thaliosundefined
                                Thalios
                                This is truly wonderful!
                                I love seeing the cancelled object.
                                Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                                Heavily modified Ender 3 Pro (Duet 3 6HC)
                                Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                                CR-10S Pro V2 (Duet 3 Mini 5+)
                                and a bunch of SLA printers..
                                • A Former User?
                                  A Former User
                                  A genuine question.
                                  What is considered the real world use for this?
                                  Vetiundefined 1 Reply Last reply Reply Quote 0
                                  • Vetiundefined
                                    Veti @A Former User
                                    @CaLviNx
                                    when one print fails over you can still finish the print on the other objects.
                                    • A Former User?
                                      A Former User @Veti
                                      @Veti said in 3D GCode Viewer integrated with DWC:
                                      @CaLviNx
                                      How does it do that then ? if what you are saying is true then how does the printer know one object has failed and stops extruding for that object but continues to extrude for the others?
                                      And that still doesn't explain the real world application use of this when you can see 99% of this from the slicer
                                      Vetiundefined Sindariusundefined 2 Replies Last reply Reply Quote 0
                                      • Vetiundefined
                                        Veti @A Former User
                                        @CaLviNx said in 3D GCode Viewer integrated with DWC:
                                        this has been a feature in octoprint for some time.
                                        https://plugins.octoprint.org/plugins/cancelobject/
                                        each object layer has a prefix comment. if the object is to be cancelled the pointer jumps to the next prefix object for the g code printing. leaving out the g code of that object.
                                        • PCRundefined
                                          PCR
                                          yep. its super useful if you printing a lot of small parts and it happens that some does not stick!
                                          There is a thread somewhere here explaining it!
                                          Will post the link later
                                            Sindarius @A Former User
                                            @CaLviNx if you are talking about the 3D viewer the original purpose of it was because I use a mixing hotend and I wanted a way to preview how a model would look when i changed the filament on each of the extruders. This viewer approximates what the printed model will look like based on configured colors. Another use is being able to see the model before printing without having to go to a slicer to load it up.
