    [DSF Extension] Exec On MCode (was: Shutdown SBC)
    DSF Development
    22
    117
    10.1k
    • wilrikerundefined
      wilriker @CrazyCreator
      @crazycreator said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
      How can i do this?
      Run sudo poweroff and check what that does.
      pi@CCC:~ $ sudo /usr/local/bin/execonmcode -version
      2021/05/20 16:20:43 0x24142bc
      pi@CCC:~ $
      That looks like a bug in previous version and it may be that DCS is rejecting this client. Please get the version 5.2.0 of execonmcode from GitHub and try again.
      Manuel
      My Tool Collection
      CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
      • CrazyCreatorundefined
        CrazyCreator @wilriker
        @wilriker I used 5.1 so that I could imitate the tutorial 100%. now I'm back on 5.2
        sudo poweroff
        pi@CCC:~ $ sudo poweroff
        Connection to ccc.local closed by remote host.
        Connection to ccc.local closed.
        Versionscheck
        pi@CCC:~ $ sudo /usr/local/bin/execonmcode --version
        5.2.0
        Debug and Trace
        pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command -poweroff -debug -trace
        2021/05/20 16:35:27 7722: -poweroff
        2021/05/20 16:35:27 [DEBUG] <Recv> {"version":11,"id":21}
        2021/05/20 16:35:27 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
        2021/05/20 16:35:27 [DEBUG] <Recv> {"success":true}
        2021/05/20 16:35:27 [DEBUG] <Connect> Connection established
        put the M7722 command in DWC Console ... show me this in terminal
        2021/05/20 16:35:58 Connection to DCS closed
        2021/05/20 16:35:58 [DEBUG] <Close> Closing connection
        2021/05/20 16:35:58 EOF
        http://www.crazycreatorcube.com
        • wilrikerundefined
          At least this time you used -poweroff which most likely is not a valid command. 😉
          Manuel
          My Tool Collection
            @wilriker
            but in shutdownsbc.service is used and in the video tutorial too.
            What should I write / use that instead?
            What else can I try to get the script to work?
            • wilrikerundefined
              @crazycreator Just remove the dash from the start of poweroff then it should work.
              Manuel
              My Tool Collection
              CrazyCreatorundefined 2 Replies Last reply Reply Quote 0
                @wilriker
                you mean so:
                pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command poweroff -debug -trace
                2021/05/20 18:47:03 7722: poweroff
                2021/05/20 18:47:03 [DEBUG] <Recv> {"version":11,"id":80}
                2021/05/20 18:47:03 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                2021/05/20 18:47:03 [DEBUG] <Recv> {"success":true}
                2021/05/20 18:47:03 [DEBUG] <Connect> Connection established
                  @wilriker
                  When I send M7722 in the DWC Console I get the familiar popup with the message:
                  M7722
                  Warning: M7722: Command is not supported
                  But the Raspberry does not switch off or restarts!
                  When I send the M7722 command in the DWC console, I see the following lines in the terminal:
                  2021/05/20 18:47:47 Connection to DCS closed
                  2021/05/20 18:47:47 [DEBUG] <Close> Closing connection
                  2021/05/20 18:47:47 EOF
                  oozeBotundefined 1 Reply Last reply Reply Quote 0
                  • oozeBotundefined
                    oozeBot @CrazyCreator
                    @crazycreator One note that I've found is that when rebooting or powering off the SBC from a custom mCode, DCW will report "Command not supported" as the API immediately shuts down. See this thread:
                    • https://forum.duet3d.com/topic/20968/3-2-final-execonmcode-warning-issue
                      CrazyCreator @oozeBot
                      @oozebot
                      thanks for the hint. I've already read that while looking for a solution to my problem.
                      if execonmcode would run, then the message would be pretty irrelevant to me;) ... but unfortunately I can't do that
                      • wilrikerundefined
                        @crazycreator TBH I have no idea why it does not work for you. Can you please post the output of
                        sudo journalctl -eu duetcontrolserver
                        after you sent M7722 and execonmcode reported EOF?
                        Also another idea, please try the absolute path to poweroff, i.e. /usr/bin/poweroff.
                        Manuel
                        My Tool Collection
                          @wilriker
                          this the output:
                          2021/05/20 20:27:38 7722: poweroff
                          2021/05/20 20:27:38 [DEBUG] <Recv> {"version":11,"id":114}
                          2021/05/20 20:27:38 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                          2021/05/20 20:27:38 [DEBUG] <Recv> {"success":true}
                          2021/05/20 20:27:38 [DEBUG] <Connect> Connection established
                          2021/05/20 20:27:47 Connection to DCS closed
                          2021/05/20 20:27:47 [DEBUG] <Close> Closing connection
                          2021/05/20 20:27:47 EOF
                          pi@CCC:~ $ sudo journalctl -eu duetcontrolserver
                          May 20 18:31:16 CCC DuetControlServer[424]: [warn] IPC#67: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:40:55 CCC DuetControlServer[424]: [warn] IPC#69: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:43:43 CCC DuetControlServer[424]: [warn] IPC#70: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:44:42 CCC DuetControlServer[424]: [warn] IPC#72: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:45:54 CCC DuetControlServer[424]: [warn] IPC#75: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:46:20 CCC DuetControlServer[424]: [warn] IPC#77: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:46:25 CCC DuetControlServer[424]: [warn] IPC#78: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:47:03 CCC DuetControlServer[424]: [warn] IPC#80: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:47:06 CCC DuetControlServer[424]: [warn] IPC#81: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:47:58 CCC DuetControlServer[424]: [warn] IPC#83: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:48:08 CCC DuetControlServer[424]: [warn] IPC#85: Client with outdated protocol version connected (got 10, want 11)
                          May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homeall.g on channel HTTP
                          May 20 18:58:23 CCC DuetControlServer[424]: [info] Starting macro file homey.g on channel HTTP
                          May 20 18:58:28 CCC DuetControlServer[424]: [info] Finished macro file homey.g
                          May 20 18:58:28 CCC DuetControlServer[424]: [info] Starting macro file homex.g on channel HTTP
                          May 20 18:58:32 CCC DuetControlServer[424]: [info] Finished macro file homex.g
                          May 20 18:58:32 CCC DuetControlServer[424]: [info] Starting macro file homez.g on channel HTTP
                          May 20 18:58:47 CCC DuetControlServer[424]: [info] Starting macro file bed.g on channel HTTP
                          May 20 18:59:14 CCC DuetControlServer[424]: [info] Finished macro file bed.g
                          May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homez.g
                          May 20 18:59:15 CCC DuetControlServer[424]: [info] Finished macro file homeall.g
                          May 20 20:26:35 CCC DuetControlServer[424]: [warn] IPC#109: Client with outdated protocol version connected (got 10, want 11)
                          May 20 20:27:38 CCC DuetControlServer[424]: [warn] IPC#114: Client with outdated protocol version connected (got 10, want 11)
                          lines 74-96/96 (END)
                            @wilriker
                            and with the absolute path:
                            pi@CCC:~ $ sudo /usr/local/bin/execonmcode -mCode 7722 -command /usr/bin/poweroff -debug -trace
                            2021/05/20 20:31:12 7722: /usr/bin/poweroff
                            2021/05/20 20:31:12 [DEBUG] <Recv> {"version":11,"id":117}
                            2021/05/20 20:31:12 [DEBUG] <Send> {"Mode":"Intercept","Version":10,"InterceptionMode":"Pre","Channels":["HTTP","Telnet","File","USB","Aux","Trigger","Queue","LCD","SBC","Daemon","Aux2","AutoPause","Unknown"],"Filters":["M7722"],"PriorityCodes":false}
                            2021/05/20 20:31:12 [DEBUG] <Recv> {"success":true}
                            2021/05/20 20:31:12 [DEBUG] <Connect> Connection established
                            2021/05/20 20:31:48 Connection to DCS closed
                            2021/05/20 20:31:48 [DEBUG] <Close> Closing connection
                            2021/05/20 20:31:48 EOF
                            May 20 20:27:57 CCC DuetControlServer[424]: [warn] IPC#116: Client with outdated protocol version connected (got 10, want 11)
                            May 20 20:31:12 CCC DuetControlServer[424]: [warn] IPC#117: Client with outdated protocol version connected (got 10, want 11)
                            May 20 20:31:58 CCC DuetControlServer[424]: [warn] IPC#119: Client with outdated protocol version connected (got 10, want 11)
                            lines 77-99/99 (END)
                            • wilrikerundefined
                              @crazycreator Hm, there is something strange here. I can now reproduce your issue. I have to investigate that.
                              EDIT: It seems that you discovered a but in DCS 3.3-rc2 (and possibly earlier) that will be fixed in the next RC (I have to confirm that still).
                              Manuel
                              My Tool Collection
                                @wilriker
                                Why does this always have to happen to me?
                                Which RRF version do you use?
                                How long do you think it will take to get to the RC?
                                • wilrikerundefined
                                  @crazycreator It's not RRF but DSF (DCS to be exact) that has that problem. And the next RC is planned to be released within the next couple of days unless important issues will postpone it.
                                  Manuel
                                  My Tool Collection
                                    CrazyCreator
                                    @wilriker
                                    then I will probably have to wait ... or you can send me an image of your SD card 😄
                                    • oozeBotundefined
                                      oozeBot @wilriker
                                      @wilriker - just adding in that I'm experiencing the same thing on 3.3rc2.. I was able to capture it from a console when running below.
                                      Do you know if the issue has been found and is being corrected in 3.3rc3? Any interim builds out there floating around I could download to get past this issue?
                                      Thanks
                                      Phaedruxundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                                        Phaedrux Moderator @oozeBot
                                        @oozebot said in [DSF Extension] Exec On MCode (was: Shutdown SBC):
                                        You could test with this build but be aware there are other potential issues.
                                        https://www.dropbox.com/sh/1bblsmpe8m6kb0p/AAD4J_9-uEEnr-Rvh3OjlXyZa?dl=0
                                        • wilrikerundefined
                                          wilriker
                                          @CrazyCreator @oozeBot I can confirm that this bug will be fixed with DSF v3.3-rc3.
                                          Manuel
                                          My Tool Collection
                                          • wilrikerundefined
                                            wilriker @oozeBot
                                            There are no interim builds of DSF available. You would have to build it yourself from sources. What @Phaedrux posted was "only" preliminary builds of RRF 3.3-rc3.
                                            Manuel
                                            My Tool Collection
