SSR stuck on???
I stared like 10 minutes at his photo and didn't see the error, thanks to @jens55's remark, it all made sense
Completely glossed over that one. Should have looked at the diagram.
But my test asked to disconnect the bed wiring and test the terminals without an SD card present. Was that not actually carried out?
@whosrdaddy yep, that was it! Thank you!
@Phaedrux I didn't, I just disconnected the SSR and used the wires
I guess then with vin being fed into the bed terminals it was also present on the actual win terminals. Of course.
@gnydick said in SSR stuck on???:
Sometimes I wonder why you even bother asking for help here, you clearly think you know better than all of us.
First post: “it’s all wired correctly”
Humble pie!
@elmoret I'll be the first to admit when I'm wrong. I didn't insist or argue that it was correct or protest against sending photos. So what's your point?
@bearer wow. People make mistakes. At what point did I argue, disagree, or try to defend my mistakes in this post?
I know exactly what you're referring to. Solution is easy enough, just don't interact with me. In fact, I can make that happen for you.
