    heater fault when print starts
    1.5k
    • Government_Baconundefined
      Government_Bacon
      so when i start my print the temp just starts to drop and dosent recover and heater faults i have done auto tune and it didnt seem to help and have been trying to figure this out for a while and cant figure it out
      running a CR-10 S5 frame
      M307 H2
      Heater 2 model: gain 368.8, time constant 138.3, dead time 6.4, max PWM 1.00, calibration voltage 12.1, mode PID, inverted no, frequency default
      Computed PID parameters for setpoint change: P10.5, I0.352, D46.9
      Computed PID parameters for load change: P10.
      Config.G
      ; generated by RepRapFirmware Configuration Tool v2.1.2 on Sat Nov 09 2019 17:35:22 GMT-0800 (Pacific Standard Time)
      M550 P"My Printer" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P4 S0 ; physical drive 4 goes backwards
      M584 X0 Y1 Z2 E4 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
      M566 X900.00 Y800.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X750.00 Y750.00 Z1200.00 E8000.00 ; set maximum speeds (mm/min)
      M201 X850.00 Y850 Z20.00 E500.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1500 Z1000 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X500 Y500 Z500 S0 ; set axis maxima
      M574 X1 Y1 S1 ; set active high endstops
      M574 Z1 S2 ; set endstops controlled by probe
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H7 F300 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X47 Y0 Z1.0 ; set Z probe trigger value, offset and trigger height
      M557 X15:275 Y15:275 S20 ; define mesh grid
      M140 H-1 ; disable heated bed
      M305 P1 T100000 B4725 C7.200000e-8 R4700 ; set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4725 C7.200000e-8 R4700 ; set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; set temperature limit for heater 2 to 280C
      M106 P0 S1 I0 F1000 H1 T100 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 I0 F1000 H-1 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P1 S"Main" D0 H2 F0:1 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
        dc42 administrators @Government_Bacon
        See https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them.
        • Vetiundefined
          Veti
          @Government_Bacon said in heater fault when print starts:
          e3d thermistor use
          B4725 C7.060000e-8
          Government_Baconundefined 1 Reply Last reply Reply Quote 0
            Government_Bacon @Veti
            @Veti i tryed this it did not work i have even replace the thermistor and autotune it and it still dose it (i had sock and fan on when i auto tuned and fan off when printing. it is as soon at the steppers start to move the temp starts to drop quickly
            M
            122
            Printing paused at X335.6 Y331.4 Z0.5
            12/31/2019, 12:21:26 AM M292 P1
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-917DA-G4MS8-6J9DJ-3SJ6R-KBVV9
            Used output buffers: 4 of 24 (22 max)
            Static ram: 25680
            Dynamic ram: 93696 of which 484 recycled
            Exception stack ram used: 424
            Never used ram: 10788
            Tasks: NETWORK(ready,524) HEAT(blocked,740) MAIN(running,3820) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:13:36 ago, cause: reset button or watchdog
            Last software reset at 2019-12-30 22:03, reason: User, spinning module GCodes, available RAM 10824 bytes (slot 2)
            Error status: 0
            Free file entries: 9
            SD card longest block write time: 9.2ms, max retries 0
            MCU temperature: min 39.6, current 39.9, max 40.2
            Supply voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 2: ok, SG min/max not available
            Driver 4: standstill, SG min/max 0/327
            Date/time: 2019-12-31 00:20:24
            Cache data hit count 3181261680
            Slowest loop: 30.40ms; fastest: 0.08ms
            Hiccups: 0, FreeDm: 168, MinFreeDm: 142, MaxWait: 2ms
            === DDARing ===
            Scheduled moves: 109, completed moves: 107, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
            Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
            Heater 2 is on, I-accum = 0.3
            Segments left: 0
            Movement lock held by autopause
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            autopause is idle in state(s) 19
            Code queue is empty.
            • deckingmanundefined
              deckingman @Government_Bacon
              @Government_Bacon Looking at your config.g file, it seems that you only have a single tool defined and that is tool#1. So my best guess is that your slicer puts a TO command in because tool 0 usually the default. Try either putting a T1 command in your slicer start code or better still, define your one and only tool to be TO instead of T1.
                Government_Bacon @deckingman
                @deckingman the tooling is set up right.
                • Vetiundefined
                  Veti
                  how quickly? can you show the graph?
                    @Veti i think i have fixed it i droped the motor mA down and i has been stable
                    a63c9c0c-6f12-411c-b240-80c34ce8db8d-image.png i guess not it still drops
                    • Vetiundefined
                      Veti
                      M307 H2
                      where are you saving those values? there is no M501 in your config.
                        @Veti I noticed that it wasn't there and I tried adding it but didn't work is there a line of code I should put in?
                          Phaedrux Moderator @Government_Bacon
                          What didn't work?
                          After running the auto tune, send M500, then in config.g at the bottom of the file add M501.
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
                            Government_Bacon @Phaedrux
                            @Phaedrux i did that and this what i gotc37b1f06-5448-4660-b897-fed36cbda51f-image.png
                              That looks right for the first part. Now you need to edit config.g and add the M501 at the end.
                                @Phaedrux ok got the m500 to work and it still heater falted you can see at the end on the chart it drop really hard and then wasnt droping as hard 6287d8db-b772-4d2d-88fb-b7d3f7594d12-image.png
                                  Just to verify can you post your config-override.g?
                                  Is the part cooling fan running at all during that drop?
                                  Did you run the tune with the part cooling fan on at normal print speeds?
                                  What kind of hotend and thermistor are you using?
                                  Have you physically checked the wiring?
                                    @Phaedrux the cooling fan was running full blast on the auto tune and i have a sock on and the fan was off when printing
                                    ; config-override.g file generated in response to M500 at 2019-12-31 16:54
                                    ; Heater model parameters
                                    M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                                    M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                    M307 H2 A363.5 C140.9 D4.4 S1.00 V12.1 B0
                                    M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                    M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                    M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                    M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                                    G10 L2 P1 X0.00 Y0.00 Z0.00
                                    G10 L2 P2 X0.00 Y0.00 Z0.00
                                    G10 L2 P3 X0.00 Y0.00 Z0.00
                                    G10 L2 P4 X0.00 Y0.00 Z0.00
                                    G10 L2 P5 X0.00 Y0.00 Z0.00
                                    G10 L2 P6 X0.00 Y0.00 Z0.00
                                    G10 L2 P7 X0.00 Y0.00 Z0.00
                                    G10 L2 P8 X0.00 Y0.00 Z0.00
                                    G10 L2 P9 X0.00 Y0.00 Z0.00
                                      Government_Bacon
                                      i am using the bond tech cr-10 direct drive it has a e3d v6 and i have checked the wiring and my heat bed is independent from the main board
                                      Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                      • Vetiundefined
                                        Veti @Government_Bacon
                                        what do you mean by independent of the main board?
                                          @Veti it is its own system you plug it in to the wall and set it manual
                                            What is the heater fault error message shown in the console?
