DWC2 bug: heater names not displayed correctly
  • Hi
    I noticed a bug in DWC2. The heater names in the Tools box are displayed correctly.
  • I cannot see the issue. It looks OK to me. Can you explain a bit more what you are expecting to see?
  • @wilriker said in DWC2 bug: heater names not displayed correctly:
    I agree that it's difficult to understand without more information but if the OP has assigned sensor names using M308 (RRF3) or M305 (RRF2) then the sensor name should display on the temperature chart rather than the default "Heater1 etc". It works for me using DWC 2.0.4 and RRF 3 so a little more information from the OP is needed.
  • Actually, on RRF3, if you rename a heater (using M308), it fails to display correctly:
    Config:
    M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138
    M308 S1 P"e0temp" Y"thermistor" T100000 B4138
    Display:
  • @deckingman If you look carefully at the OP image, you can see that the names are wrong (heater 1, heater 1, heater 2 instead of heater 1, heater 2, heater 3)
  • Same issue on RRF3, If I name Heater 0 and Heater 1, name is missing in Tools window
  • @pipersw That is literally what I just wrote 😉
  • @remopini Yes I know that DWC is showing the default names. The information that's missing is what names you have assigned and how you have made those assignments. The board, firmware and DWC versions that you are using would also help. For info, heater names are displaying correctly for me using RRF 3 and DWC 2 so I suspect that it might be a configuration issue rather than a bug.
  • @deckingman Hey Ian, I think the issue is that on the screenshot in the first post it shows "Heater 1" twice in the Tool box. Instead of "Heater 1" and "Heater 2". It is correct above the temperature chart.
    But you are right that essential information on versions and related config is missing.
  • @wilriker In that case, then we also need to know how the tool has been defined.
  • @deckingman if you look at my screenshot and post, you can see what I configured. Using the latest available 3.0 firmware bundle from github.
  • @remopini We still need to know what "platform" you run it on. Available candidates are
    • Duet3 + SBC
    • Duet3 or Duet2 (Wifi, Ethernet, Maestro) in standalone mode
    Also a full config.g can never hurt.
  • @wilriker Sure, here you go:
    Board: Board: Duet Ethernet 1.04
    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.0 (2020-01-03b3)
    DWC: Duet Web Control 2.0.4
    Sanitized config.g:
    M569 P0 S0                              ; physical drive 0 goes backwards (X)
    M569 P1 S0                              ; physical drive 1 goes backwards (Y)
    M569 P2 S1                              ; physical drive 2 goes forwards (Z)
    M569 P3 S0                              ; physical drive 3 goes backwards (E0)
    M584 X0 Y1 Z2 E3                        ; set drive mapping
    M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z400.00 E450.00       ; set steps per mm
    M566 X900.00 Y900.00 Z120.00 E120.00    ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z1800.00 E1200.00; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
    M906 X600 Y800 Z800 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
    M84 S30                                 ; Set idle timeout
    M208 X0 Y0 Z0 S1                        ; set axis minima
    M208 X300 Y300 Z400 S0                  ; set axis maxima
    M574 X1 S1 P"!xstop"
    M574 Y1 S1 P"!ystop"
    M574 Z1 S1 P"!zstop"
    M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
    M557 X20:280 Y20:280 S65                ; define mesh grid
    G29 S1                                  ; read mesh grid from file
    M308 S0 P"bedtemp" Y"thermistor" A"Bed" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
    M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
    M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
    M307 H0 B0 S1.00                               ; disable bang-bang mode for the nozzle heater and set PWM limit
    M308 S1 P"e0temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e0temp
    M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
    M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
    M307 H1 B0 S1.00                               ; disable bang-bang mode for the nozzle heater and set PWM limit
    M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S0 I0 F500 H-1                  ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H1 T45               ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 F1                        ; define tool 0 -> using FAN 1 (fritzed Fan 0)
    G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
    G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
    M912 P0 S-3.2                           ; Calibrated MCU Temperature (reading is 3.2° too high)
    M501                                    ; load saved parameters from non-volatile memory
    config-override.g
    M307 H0 A476.5 C791.3 D4.8 S1.00 V23.9 B0
    M307 H1 A1167.0 C239.9 D8.4 S1.00 V23.5 B0
  • The same Problem here
    Board: Duet WiFi 1.02 or later + DueX5
    Version von Duet WiFi Server: 1.23
    in dwc1 the names are shown correctly
    in dwc2 the names are missing so its impossible to switch betwen on/aktiv/standby
    config.g
    ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Jan 05 2020 16:17:09 GMT+0100 (Mitteleuropäische Normalzeit)
    G90                                                 ; send absolute coordinates...
    M83                                                 ; ...but relative extruder moves
    M550 P"hypercube"                                   ; set printer name
    M667 S1                                             ; select CoreXY mode
    M552 S1                                             ; enable network
    M586 P0 S1                                          ; enable HTTP
    M586 P1 S1                                          ; disable FTP
    M586 P2 S1                                          ; disable Telnet
    M569 P0 S0                                          ; physical drive 0 = X goes backwards
    M569 P1 S0                                          ; physical drive 1 = Y goes backwards
    M569 P2 S1                                          ; physical drive 2 = Z goes forwards
    M569 P3 S1                                          ; physical drive 3 = E0 goes forwards
    M569 P4 S1                                          ; physical drive 4 = Z goes forwards
    M569 P5 S0                                          ; physical drive 5 = Z goes backwards
    M569 P6 S1                                          ; physical drive 6 = E1 goes forwards
    M584 X0 Y1 Z2:4:5 E3                                  ; set drive mapping
    M671 X0:380:0 Y52:190:327 S3 F1.0; Leitspindeln links und rechts von der X-Achse ****
    M350 X16 Y16 Z16:16:16 E16 I1                          ; configure microstepping with interpolation
    M92 X200.60 Y200.60 Z797:797:797 E2666.67           ; set steps per mm
    M566 X600.00 Y600.00 Z300.00 E40.00          ; set maximum instantaneous speed changes (mm/min)
    M203 X30000.00 Y30000.00 Z1200.00 E4800.00     ; set maximum speeds (mm/min)
    M201 X2000.00 Y2000.00 Z500.00 E120.00          ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1500.00 E500                        ; set motor currents (mA)
    M84 S0                                              ; Disable motor idle current reduction
    M208 X-1 Y0 Z-1 S1                                  ; set axis minima
    M208 X400 Y370 Z450 S0                              ; set axis maxima
    M574 X1 S1 P"xstop"                                 ; configure active-high endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop"                                 ; configure active-high endstop for low end on Y via pin ystop
    M558 P8 R0.4 C"^!zprobe.in+zprobe.mod" H5 F450 T6000 ;
    G31 P500 X0 Y0 Z-0.25                                 ; set Z probe trigger value, offset and trigger height
    M557 X15:390 Y15:370 S25                            ; define mesh grid
    M308 S0 P"bedtemp" Y"thermistor" A"Heizbett" T100000 B3950      ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S100                                        ; set temperature limit for heater 0 to 100C
    M308 S1 P"e0temp" Y"thermistor" A"Hotend" T100000 B4276       ; configure sensor 1 as thermistor on pin e0temp
    M950 F0 C"fan0" Q25500 ;H-1                              ; create fan 0 on pin fan0 and set its frequency
    M106 P0 S0 H-1 F25500 C"Bauteilkühlung"                                  ; set fan 0 value. Thermostatic control is turned on
    M950 F1 C"fan1" Q75 T45 ;H1                              ; create fan 1 on pin fan1 and set its frequency
    M106 P1 S1 H1 T45 F75 C"Hotend"                                    ; set fan 1 value. Thermostatic control is turned off
    M950 F2 C"fan2" Q250 ;H-1                              ; create fan 2 on pin fan2 and set its frequency
    M106 P2 S0 H-1 F250 C"LED"                                  ; set fan 2 value. Thermostatic control is turned off
    M563 P0 D0 H1 F0                                  ; define tool 0              *****
    T0                                                  ; select first tool
  • @SIam You can still switch (by clicking on the blue "Bett" or "Werkzeug 0"), but it is highly annoying 🙂
  • ok you are right 😮
  • OK, since in all cases there is no DuetSoftwareFramework in play this means it's a bug in either RRF or DWC. I'll take a quick look at it.
    EDIT: First result: DWC receives the list of correct names but fails to show them correctly in all places.
  • @SIam
    I have named tools (not the fans) and the heaters are clickable.
    ~~I see it that way, the fan names are displayed In the graph and the tool names are displayed in the menu. And they can differ.
    Maybe the graph should also display tools and not fans.
    Edit: The fan names are only displayed when no tool names are defined.~~
  • @DIY-O-Sphere It's not fans, it's heaters and showing tools instead of heaters in a temperature chart is a bad idea, because there isn't necessarily one heater for one tool (a tool could have 2 or more heaters or none).
  • @remopini
    You are right. Forget about my post.
    I thought that are the fan names, but that is not correct. ace702ec-93cf-4618-8df5-8e403390ef69-grafik.png
    Who can read is clearly at an advantage. 👎
