Very Strange Mesh map
  • Railcore II ZLT - Aluminium bed, no magnets, bl touch for probe.
    I have a wavy mesh map and it do not know why.
    Latest mesh ^^
    First Mesh
    I have an Ender3 and the mesh maps look nothing like this.
    Some assistance would be appreciated.
  • Moderator
    @PaulHew how much offset on the probe? Most likely is that the carriage is rocking as it’s pulled in different directions, and if the probe has a large offset, this amplifies it.
    Maybe post config and M115 response, too?
  • @droftarts As requested
    m115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-01-03b3
    and
    ; Configuration file for RailCore II 300 ZLT
    ; Communication and general
    M111 S0                             	; Debug off
    ;Network
    M550 P"RailCore II"                       ; Set machine name
    M552 P192.168.0.7 S1                     ; Enable network and set IP address
    M553 P255.255.255.0                      ; Set netmask
    M554 P192.168.0.1                        ; Set gateway
    M586 P0 S1                               ; Enable HTTP
    M586 P1 S0                               ; Disable FTP
    M586 P2 S1                               ; Enable Telnet
    M575 P1 B57600 S1					; Comms parameters for PanelDue
    G21                                 	; Work in millimetres
    G90                                		; Send absolute coordinates...
    M83                                 	; ...but relative extruder moves
    ; Axis and motor configuration
    M669 K1								; CoreXY mode
    M584 X0 Y1 Z5:6:7 E3:4:8:9 		       ; Map Z to drivers 5, 6, 7. Define unused drivers 3,4,8 and 9 as extruders
    M569 P0 S1                                     ; Drive 0 goes forwards (change to S0 to reverse it) X stepper (Rear)
    M569 P1 S0                                     ; Drive 1 goes backwards	Y Stepper (Front)
    M569 P2 S1                                     ; Drive 2 goes forwards Unused
    M569 P3 S1                                     ; Drive 3 goes forwards Extruder
    M569 P4 S1                                     ; Drive 4 goes forwards Extruder (unused)
    M569 P5 S1			  	                       ; Drive 5 goes backwards	Front Left Z
    M569 P6 S1				                       ; Drive 6 goes backwards	Rear Left Z
    M569 P7 S1				                       ; Drive 7 goes backwards	Right Z
    M84 S30                                        ; Set idle timeout
    ;Leadscrew locations
    M671 X-10:-10:333 Y22.5:277.5:150 S7.5  ;Front left, Rear Left, Right  S7.5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
    M350 X16 Y16 Z16 E16 I1	                 ; set 16x microstepping for axes& extruder, with interpolation
    ;Endstop Configuration
    M574 X1 S1 P"xstop"			             ; _RRF3
    M574 Y1 S1 P"ystop"			             ; _RRF3
    ;Speeds
    M906 X1400 Y1400 Z2400 E700 I60	         ; Set motor currents (mA)
    M201 X3000 Y3000 Z100 E1500              ; Accelerations (mm/s^2)
    M203 X24000 Y24000 Z900 E3600            ; Maximum speeds (mm/min)
    M566 X1000 Y1000 Z100 E10                ; Maximum jerk speeds mm/minute
    M92 X200 Y200
    M92 Z1600
    M92 E407	             ; steps/mm
    M204 P1500 T1500
    M208 X-10:310 Y-8:293 Z-0:550                 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
    ; Thermistors
    ;Bed Configuration
    M308 S0 P"bedtemp" Y"thermistor" A"Bed-Top" T100000 B3950 R4700 H0 L0
    M950 H0 C"bedheat" T0
    M143 H0 S120
    M307 H0 A481.6 C758.5 D11.3 V24.2 B0
    ;HotEnd Configuration
    M308 S1 P"e0temp" Y"thermistor" A"E3Dv6" T100000 B4725 R4700 C7.06e-8 H0 L0	;
    M950 H1 C"e0heat" T1				;
    M143 H1 S280
    M307 H1 A503.9 C237.3 D4.9 V24.2 B0        ;
    ; Other Tempreture Inputs
    M308 S6 P"exp.thermistor6" Y"thermistor" A"Keenovo" T100000 B3950 R4700
    M308 S7 P"exp.thermistor7" Y"thermistor" A"RoomTemp" T100000 B3950 R4700
    M950 F0 C"fan0"						;Part Cooling Fan
    M106 P0 H-1
    M950 F1 C"fan1" Q500                           ;Hotend Fan
    M106 P1 S1 H1 T40
    M950 F2 C"fan2"						;_RRF3_ define fan2
    M106 P2 H-1
    M106 P0 S0 				; turn off fans
    ; Tool definitions
    M563 P0 D0 H1                       	; Define tool 0
    G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
    ; Z probe and compensation definition
    M558 P9 C"^zprobe.in" H5 R1 F120 T6000 A5 S0.02  ;BLTouch connected to Z probe IN pin
    M950 S0 C"duex.pwm1"				             ;BLTouch Servo (S0) on duet pwm1
    G31 X2 Y42 Z1.422 P25                            ; Customize your offsets appropriately - do a paper test, and put the probed value in the Z value here
    M557 X30:280 Y30:280 S20
    T0					; select first hot end
    Thanks for looking.
    P.
  • Moderator
    @PaulHew yes, 40mm X offset on probe. All points on the mesh in one direction are high, and low in the other direction, so the carriage is rotating in the XZ plane. What’s the X axis? Linear rail? HiWin or cheaper Chinese copy? I’d guess latter, and tolerances aren’t great, causing lateral movement. Alex Kenis has done some great YouTube videos on these, worth watching.
    You may be able to reduce this by tightening the belts, but I’m not sure.
  • @droftarts All axis have original HiWin rails, 3 on Z, 2 on Y and 1 on X.
    I will check the belt tension.
    Could a slight wobble on one of the Z leadscrews cause this too?
    Thanks again Ian
  • Moderator
    @PaulHew said in Very Strange Mesh map:
    I wouldn't think so. Seems like a case of backlash though. Are you able to wiggle the print carriage by hand? Are the belts equally tensioned?
  • @Phaedrux The print head is solid, I purchased all of the aluminium upgrade parts so there is no plastic.I will check the belt tension, again as I have just plucked the belts and one sounds higher than the other.
    Belts were about 60-60hz. Have tweaked them down to 50hz and running a mesh now.
    Thanks @Phaedrux and @droftarts
    Paul
  • Latest mesh after re-tuning the belts
    and another angle
  • Moderator
    So... better?
  • I was expecting something better than this, This is on my Ender3
    Considering the cost and only putting premium parts in it, I was expecting or hoping to get it green all the way.
    This is the latest from my Railcore with a 9 point grid.
    I have a 4mm glass mirror tile on a 6mm machined bed.
    Maybe I should take the glass off and probe the bed.
  • Moderator
    Would be interesting to see the difference. Is it possible the bed was damaged in shipping or that it came with some waves?
  • I have changed to a 4 point probe and adjusting the rails as I need.
    Its looking better than the previous posts.
    Long process, but getting there!
  • Moderator
    Ah yes, the rails. Should have thought of that.
  • Your bed map looks very good with just a slight tilt. I'd be extremely happy to have something that smooth.
    Going to 9 point is like trying to look at a picture with the vast majority of it's pixels removed and substituted with average values - useless. 4 point and 9 point meshes are good for the very initial steps of leveling the bed but nothing beyond that.
  • So after adjusting rails and tweaking things, I am now here.
    I thought I would update so others could benefit.
    I was close before, but one corner was not right, front right. Back right was OKish
    Satre on the Railcore discord forum asked me to try something.
    Originally I was running a 3 point levelling routine, near the leadscrews.
    He suggested I use a 4 point, so changed my bed.g to
    M561                         ; clear any existing bed transform
    G1 Z5                         ; RRF3 remove S2
    G30 P0 X15 Y45 Z-99999
    G30 P1 X15 Y275 Z-99999
    G30 P2 X275 Y275 Z-99999
    G30 P3 X275 Y45 Z-99999 S3
    G1 X0 Y0 F5000               ; move the head to the corner (optional)
    Power off then on, (I wait at least 15secs before powering back on)
    I ran G32 5 times to get the bed as near as level then ran a 4 point mesh and ended up with a nigh on perfect mesh.
    So pleased and can get printing now that I have all of the niggles ironed out.
    Issues were bad idlers, cheap belt, belt tension was also toooooo high - 65hz, at about 50hz now.
    Thanks to all who suggested brilliant ideas, everything on here and discord got me to this place.
    Kind Regards,
    Paul.
  • While you certainly have done a great job levelling the bed, you do NOT have a mesh map!
    Your printer has exactly ZERO information about what is going on in the middle of the bed. All it knows is that the 4 corners are looking good.
    If you are happy printing without mesh bed compensation then you are golden but you are wasting a great feature and doing yourself a dis-service by not going to the highest resolution mesh.
