    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    31.1k
    • paralepsisundefined
      paralepsis
      Hi! I've got one of these running now, using PCR's PCB. Thanks to you both!
      Having played a little, here are two suggestions in case someone is further improving the software:
      • If there's a simulated time available for a print, use that rather than the slicer-provided time on the Printing summary.
      • Perhaps use the full screen for the list when selecting filaments. I've found it easy to accidentally turn on a tool while selecting filaments, and difficult to select the right filament (or maybe there's a bug, hard to tell).
      Thanks again for this cool design! It's a nice little HUD of sorts for prints while I work from home and away from the printer.
      Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
      • seeul8erundefined
        seeul8er
        @paralepsis Thank you for your feedback!
        The displayed remaining time should be (simulated_time-elapsed_time) if a simulation time is available. If not it takes the time based on the file.
        paralepsisundefined 1 Reply Last reply Reply Quote 0
          paralepsis @seeul8er
          @seeul8er Do I have to have performed the simulation from the RepPanel? What I did was run the simulation from the web UI, start the print from the web UI, observed an apparent use of the slicer timing on RepPanel.
          I can try this again.
            paralepsis @paralepsis
            @paralepsis Repeating the experiment, I am seeing the simulated time on the RepPanel. Must have been operator error. Sorry for the misdirection.
            • k3lagundefined
              k3lag
              I just got my display from buydisplay.com and realized I ordered the 3-wire SPI version instead of the 4 wire version. I also have @PCR's circuit board. Is there a way to reconfigure the software to work with the 3-wire display?
              Also, does anyone have a close up picture of their display board? According to the data sheet there should be 0R resistors installed at R1-R10 and R21-R28 and I am missing them.
              • seeul8erundefined
                seeul8er
                @k3lag I think you might be in luck. To me it is not 100% clear what the "4-wires" are exactly. The current built also does not directly specify a MISO for the SPI. The display offers a "data" connection that could be independent from the SPI to read the TFT data chip ID etc. So just give it a try!
                k3lagundefined 1 Reply Last reply Reply Quote 0
                • k3lagundefined
                  k3lag @seeul8er
                  @seeul8er said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                  I did. It didn’t work. The board appears to be jumpered for 18-bit rgb instead of SPI. I’m in contact with buydisplay and we will see what they say.
                  • k3lagundefined
                    k3lag
                    Apparently I accidentally selected the wrong option when I ordered my board and I got the 18-bit RGB version. After talking to buydisplay I choose to rejumper the board for 4-pin SPI and it works now.
                    I am having a problem with it freezing after a few minutes of operation. Right before it freezes I see the WiFi icon turn yellow momentarily then it goes back to green and it's frozen at that point. After a reset it will work again for a while then do the same thing. I have an Orbi mesh WiFi network and I wonder if it's somehow struggling with that. When I go to pick a WiFi network it shows each of the 3 Orbi bases as separate networks and there is no way to tell which one you are picking. Don't know if that's the problem or not but I plan to fiddle more to see if I can figure it out. Never mind. I don't use the filament directory so once I added a filament file it was happy.
                    • seeul8erundefined
                      seeul8er
                      @k3lag Thank you for reporting the issue. I think someone already mentioned that. I added the bug to the github issues 👍
                      • fractalengineerundefined
                        fractalengineer
                        Aw man did I just goof up again?
                        I ordered this panel after ordering another one that wasn't touchscreen...
                        The pinout doesn't look right; but it seems to have the recommended driver
                        https://www.aliexpress.com/item/4000127949256.html?spm=a2g0s.9042311.0.0.13734c4dRwnSJw
                        Can I use this at all?
                        Railcore II ZL
                          fractalengineer
                          Ok so it appears to be a parallel display; I did however manage to get the library examples working on my esp32 using the TFT_eSPI lib on arduino IDE...Not sure how that would work on IDF
                          Railcore II ZL
                          • seeul8erundefined
                            seeul8er
                            @fractalengineer In your case to get it working you will need to write a display driver for LvGL that supports the parallel interface. The drivers from LVGL do not support the parallel display interface as far as I know. The touch screen should work out of the box since there is already a driver available.
                            fractalengineerundefined 1 Reply Last reply Reply Quote 0
                              fractalengineer @seeul8er
                              @seeul8er Ok that's well beyond my skill level lol; I'll just look for an appropriate screen.
                              Btw this is tested to work on Duet3+SBC right?
                              Railcore II ZL
                                jay_s_uk
                                This currently only works with boards in standalone mode
                                • chimaeraghundefined
                                  chimaeragh
                                  @Sindarius Can this be adapted to work in CNC mode? I would prefer this interface to the paneldue to control my workbee
                                  Duet 2 Wifi, Ooznest Workbee CNC 1510
                                  Sindariusundefined 1 Reply Last reply Reply Quote 0
                                  • Sindariusundefined
                                    Sindarius @chimaeragh
                                    @chimaeragh The DWC-CNC itself should not have anything to do with this. This is a separate interface that others are working on. It is quite slick though 🙂 Maybe whoever is working on this effort can look at making a version of it focused around a CNC, would be quite slick.
                                    • seeul8erundefined
                                      seeul8er
                                      @chimaeragh As Sindarius already stated: RepPanel is self contained and runs on the ESP32.
                                      Sadly I do not have the time or motivation to make a port for CNC applications. CNCs require quiet a lot more manual control over the heads position. I also think that because of that a bigger display (coupled with a more powerfull MCU) would be adequate which probably requires a complete rewirte of the code.
                                      • leewaaundefined
                                        leewaa
                                        Hi there @PCR any boards pcb boards left ?
                                        • PCRundefined
                                          PCR
                                          yes 18x or so 😉
                                          • leewaaundefined
                                            leewaa
                                            Oh cool, I would be interested in one!
                                            Is there some kind of dedicated page documenting the things I would need to get it running. I'm running the Duet 3 v1.01
