    Cambio elettronica
    124
    6.4k
      @Phaedrux said in Cambio elettronica:
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 16:46:31 GMT + 0200 (Central European
      Summer Time) G91; relative positioning
      G1 H2 Z5 F6000; lift Z relative to current position
      G1 H1 X-335 Y-335 F1800; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-335; home X axis
      G1 H1 Y-335; home Y axis
      G1 X5 Y5 F6000; go back a few mm
      G1 H1 X-335 F360; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-335; then move slowly to Y axis endstop
      G90; absolute positioning
      G1 X60 Y50 F6000; go to first bed probe point and home Z
      G30; home Z by probing the bed
      Does your homeall match this?
      • Leblondundefined
        Leblond
        te lo mando
        • Leblondundefined
          Leblond
          ; homeall.g
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT+0200 (Ora legale dell’Europa centrale)
          G91 ; relative positioning
          G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
          G1 H1 X-335 ; home X axis
          G1 H1 Y-335 ; home Y axis
          G1 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H1 Y-335 ; then move slowly to Y axis endstop
          G90 ; absolute positioning
          G1 X60 Y50 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 Z5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          • Leblondundefined
            Leblond
            si sposta verso il dietro e a dx
              Phaedrux Moderator @Leblond
              @Leblond said in Cambio elettronica:
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European
              I think the problem may be here. The G91 must be on a new line.
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 02 2020 20:16:54 GMT + 0200 (Central European Summer Time)
              • Leblondundefined
                Leblond
                😧 scusami errore mio M574 X1 S1 P"!xstop" avevo tolto "!"
                Adesso funziona😊 grazie della pazienza che mi hai dimotrato fratello
                • Leblondundefined
                  Leblond
                  ecco la configurazione funzionante per la tronxy x5sa pro con duet, in caso qualcun'altro ne avesse bisogno
                  M550 P"X5SA PRO" ; set printer name
                  M669 K1 ; select CoreXY mode
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0 S0 ; physical drive 0 goes backwards
                  M569 P2 S0 ; physical drive 2 goes forwards
                  M92 X80.00 Y80.00 Z800.00 E420.00 ; set steps per mm
                  M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z100.00 E1200.00 ; set maximum speeds (mm/min)
                  M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X-5 Y0 Z0 S1 ; set axis minima
                  M208 X352 Y330 Z400 S0 ; set axis maxima
                  M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin xstop
                  M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin ystop
                  M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                  M558 P5 C"! zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                  G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                  M557 X60:300 Y50:300 S20 ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                  • Leblondundefined
                    Leblond
                    Buona notte a tutti
                      Glad you got it working.
                      • Leblondundefined
                        Leblond
                        buongiorno a tutti voi.
                        Sto completando la stampante per quanto riguarda l'elettronica ho letto qui https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing e non son sicuro di aver capito bene.
                        allora ricapitolando, quello che cerco e' nel comando M591 se non erro ed e' il seguente
                        M591 D0 P1 C "e0_stop" S1 corretto? l'interruttore rimane alto quando c'e' il filamento e viceversa quando non c'e' mi basta solo questo in config? o ho bisogno di altro?
                        • Leblondundefined
                          Leblond
                          RISOLTO
                          gdefrancundefined 1 Reply Last reply Reply Quote 0
                          • gdefrancundefined
                            gdefranc @Leblond
                            @Leblond
                            Ciao Altro italiano....
                            possessore di una Tronxy x5sa.
                            mi dai qualche riscontro. hai finito la configurazione del passaggio alla duet wifi?
                            HAi preso un clone o una originale?
                            Ha cambiato altre parti oltre alla motherboard?
                            Leblondundefined 1 Reply Last reply Reply Quote 0
                            • Leblondundefined
                              Leblond @gdefranc
                              @gdefranc Ciao la configurazione con la duet2 wifi funziona perfettamente, ma purtroppo x colpa mia la duet ha fatto puff, quindi sto aspettando quella nuova sempre la stessa presa da filastruder a parte la scheda, ho sostituito anche il sensore e gli ho messo il 3dtouch, in particolare cosa vorresti sapere?
                              • gdefrancundefined
                                gdefranc @Leblond
                                @Leblond Grazie per la risposta.
                                Quindi alla fine hai cambiato la motherboard il 3dTouch e niente altro.
                                l'lcd hai mantenuto quello originale?
                                A livello meccanico hai fatto qualche modifica?
                                Usi il piatto in Vetro borosilicato?
                                • Leblondundefined
                                  Leblond @gdefranc
                                  @gdefranc lcd della tronxy non va bene con la duet, quindi ho preso il paneldue 7i, a livello meccanico devo cambiare le chiocciole mettendo quelli in derlin "pom" e dovrei sostituire una t8 che e' storta, gia' da quando e' arrivata la stampante, poi vedro', ho intenzione anche di modificare l'asse z portando da 2 motori ad 1 con un kit di alluminio fatto da https://www.dmakers.it/componenti-per-stampanti-3d/kit-one-z-motor/ , ha solo un problema questo kit, che bisogna acquistare altri pezzi che non vende lui, ma comunque di facile reperibilita', per quanto riguarda il piano di stampa non sto usando il vetro ma uso il suo originale che non e' affatto male
                                  • logrisoundefined
                                    logriso
                                    Buongiorno,
                                    vedendo che qui è scritto anche in italiano, mi unisco per condividere e leggere le mie ( poche) e vostre esperienze...
                                    io sto per avviare una stampante fatta interamente da me, sulla falsa riga di sharebot.
                                    asse z con chiocciola a ricircolo, asse y con doppio motore opposto e cinghia GT2, asse x motore singolo e cinghia GT2, carro estrusione a doppio estrusore, dove come principale uso un e3d V6 all metal, e some secondario un e3d v6 lite e bltouch per livellamento piano.
                                    Elettronica con duet ethernet e duet panel i5, ammeniccoli vari come power supply, mosfet per piano riscaldato.
                                    allo stato dei fatti non ho ancora mosso un motore....ho finito i cablaggi, ad esclusione del bltouch.
                                    Prossima mossa sarebbe quella far muovere i motori.
                                    vi faccio due domandine....
                                    domanda 1)
                                    sui due assi x e y ho messo due finecorsa...mentre il finecorsa high (diciamp Y+ e X+) immagino debbano finire come finecorsa di home, quelli sulla parte low (X- e Y- e Z-) vorrei metterli in serie come emergenza. qualcuno di voi ha inserito un emergenza di quel tipo? se si, come?
                                    domanda 2)
                                    per raffreddare gli stepper della scheda ho collegato due fans da 12 v ai pin always on della scheda.
                                    avendo una alimentazione a 24V ho portato il 12v al pin centrale come da descrizione (togliedo il jumper che selezione i 5V interni. Le ventole non si muovono. devo verificare se effettivamente sui due pin il 12v arriva....ma ci sono altre verifiche da poter fare?
                                    Intanto vi ringrazio per la pazienza nel leggere tutta questa "spataffiata" di roba!!!
                                    Ciao
                                    droftartsundefined 2 Replies Last reply Reply Quote 0
                                      droftarts administrators @logriso
                                      @logriso via google translate:
                                      ask you two questions .... question 1)
                                      on the two x and y axes I put two limit switches ... while the high limit switch (say Y + and X +) I guess they must end as home limit switches, those on the low part (X- and Y- and Z-) I would like to put them in series as an emergency. Did any of you put in an emergency like that? if yes, how?
                                      You can home to the high or low endstops, but not both; RepRapFirmware only supports one endstop per motor/axis. There is not much point adding an 'emergency' endstop, because the maximum and minimum movement of the axis will be limited by the firmware. After homing, the endstops are effectively ignored.
                                      You can do it if you really want to; connect the 'emergency' endstops in series, connect them to an available pin connector on the Duet, and use M581 https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger to configure this to pause the printer if triggered.
                                      question 2)
                                      to cool the board steppers I connected two 12v fans to the always on pins of the board.
                                      having a 24V power supply I brought the 12v to the central pin as described (I remove the jumper that selects the internal 5V. The fans do not move. I have to check if the 12v actually arrives on the two pins .... but there are other checks what can you do?
                                      There is no 12V regulator on the Duet, only VIN (24V) and 5V. So you need to use a buck regulator or something else to step down to 12V. See https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans#Section_Using_12V_fans_when_VIN_is_24V
                                        @logriso Also, probably best if you start a new thread.
                                        • Gianlucaundefined
                                          Gianluca
                                          Buongiorno a tutti,
                                          aprofitto della interessante discussione per chiedere informazioni su un problema che mi ostacola nel passaggio da RRF2 a RRF3.
                                          Ho una LK4 pro con vari upgrade ( doppio asse Z con viti a ricircolo e assi X e Y con guide lineari e BL-touch v3.1) e monto una scheda Duet2 Wi.Fi.
                                          Attualmente è tutto perfettamente funzionante e configurato, ma dopo aver portato il firmware alla versione 3.20 non riesco a configurare i fine corsa.
                                          In realtà funzionano ma al contrario, attualmente hanno il contatto NA ma la scheda si aspetta un NC.
                                          Dando il comando home si muove un attimo e si ferma, perchè legge che è già a fine corsa. Se invece faccio l'hon di un asse chiudendo manualmente il contatto, l'asse si muove correttamente e lasciandolo si ferma. Nel config.g ho questo riga:
                                          M574 X1 S1 P"xstop"
                                          M574 Y1 S1 P"ystop"
                                          Ho provato a cambiare i paramteri con altre combinazioni ma i fine corsa restano sempre invertiti.
                                          Con il RRF 2.05 funziona perfettamente.
                                          Avete qualche suggerimento?
                                          Grazie
                                            Phaedrux Moderator @Gianluca
                                            @Gianluca
                                            Hello everyone, take advantage of the interesting discussion to ask for information on a problem that hinders me in the transition from RRF2 to RRF3. I have a LK4 pro with various upgrades (double Z axis with ball screws and X and Y axes with linear guides and BL-touch v3.1) and I mount a Duet2 Wi.Fi card. Currently everything is fully functional and configured, but after bringing the firmware to version 3.20 I cannot configure the limit switches. Actually they work but on the contrary, they currently have the NO contact but the board expects a NC. By giving the command home it moves for a moment and stops, because it reads that it is already at the end of its travel. If, on the other hand, I hone an axis by manually closing the contact, the axis moves correctly and when it is released, it stops. In config.g I have this line:; Endstops M574 X1 S1 P "xstop" M574 Y1 S1 P "ystop" I tried to change the parameters with other combinations but the limit switches are always inverted. With the RRF 2.05 it works perfectly. Do you have any suggestions? Thank you
                                            You must invert the signal of the pin using a ! before the pin name
                                            Gianlucaundefined 1 Reply Last reply Reply Quote 0
