    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.6k
    • smoki3undefined
      smoki3
      Is M122 working for someone?
      SIamundefined 1 Reply Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators
        Thanks, I've already fixed the crash that occurs when a heater fault occurs and I'll fix the filament assignment next. Both fixes will be available when RRF 3.01 is released. Likewise the "Turn off all" button has been fixed and a new DWC version will be released among the next DSF version.
        Duet software engineer
        GrodanBundefined 1 Reply Last reply Reply Quote 0
        • SIamundefined
          SIam @smoki3
          @smoki3
          M122 is working here
          6.4.2020, 20:32:50 	m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
          Used output buffers: 4 of 24 (22 max)
          Static ram: 28052
          Dynamic ram: 94208 of which 24 recycled
          Exception stack ram used: 576
          Never used ram: 8212
          Tasks: NETWORK(ready,116) HEAT(blocked,1244) DUEX(suspended,136) MAIN(running,1608) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 11:14:43 ago, cause: software
          Last software reset at 2020-04-06 09:18, reason: User, spinning module GCodes, available RAM 8532 bytes (slot 3)
          Error status: 0
          Free file entries: 10
          SD card longest block write time: 133.8ms, max retries 0
          MCU temperature: min 21.7, current 39.7, max 41.7
          Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/981
          Driver 1: standstill, SG min/max 0/1023
          Driver 2: standstill, SG min/max 0/1023
          Driver 3: standstill, SG min/max 0/1023
          Driver 4: standstill, SG min/max 0/1023
          Driver 5: standstill, SG min/max not available
          Driver 6: standstill, SG min/max not available
          Driver 7: standstill, SG min/max not available
          Driver 8: standstill, SG min/max not available
          Driver 9: standstill, SG min/max 0/1023
          Date/time: 2020-04-06 20:32:48
          Slowest loop: 312.35ms; fastest: 0.12ms
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 107, MaxWait: 5922743ms
          === MainDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
          === AuxDDARing ===
          Heater 0 is on, I-accum = 0.0
          Heater 1 is on, I-accum = 0.7
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 789.12ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(2) FTP(0) Telnet(0)
          HTTP sessions: 2 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address 2c:3a:e8:0b:06:33
          WiFi Vcc 3.44, reset reason Unknown
          WiFi flash size 4194304, free heap 15424
          WiFi IP address 192.168.188.36
          WiFi signal strength -49dBm, reconnections 0, sleep mode modem
          Socket states: 4 0 0 4 0 0 0 0
          === Filament sensors ===
          Extruder 0 sensor: ok
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          smoki3undefined 1 Reply Last reply Reply Quote 0
          • GrodanBundefined
            GrodanB @chrishamm
            @chrishamm said in Duet Web Control 2.1.1 released:
            Great, by the way, great work. Much appreciated.
            Do you require me to upgrade to RRF 3.01? Do not see the benefit to me until new functions are added at the moment I understand that soon it will be at the same function level as latest 2.x.
            Again thanks.
            DocTruckerundefined 1 Reply Last reply Reply Quote 0
            • DocTruckerundefined
              DocTrucker @GrodanB
              @GrodanB said in Duet Web Control 2.1.1 released:
              @jay_s_uk said in Duet Web Control 2.1.1 released:
              Its dependant on RRF3.01+ as it uses the object model
              • smoki3undefined
                smoki3 @SIam
                @SIam said in Duet Web Control 2.1.1 released:
                @smoki3
                Static ram: 28052
                Error status: 0
                === MainDDARing ===
                === AuxDDARing ===
                Segments left: 0
                === Network ===
                - WiFi -
                I just get this without an output. Are you on Duet 2 Wifi?
                jay_s_ukundefined SIamundefined smoki3undefined 3 Replies Last reply Reply Quote 0
                  jay_s_uk @smoki3
                  @smoki3
                  i get full M122 output on a duet 3 + pi and a duet 2 ethernet
                  • wilrikerundefined
                    wilriker
                    @jay_s_uk @DocTrucker @GrodanB DWC 2.1.1 is supposed to work with RRF versions pre-ObjectModel. Unfortunately, currently there is a bug in the code that prevents it to get into legacy-mode.
                    Manuel
                    My Tool Collection
                    jay_s_ukundefined chrishammundefined GrodanBundefined 3 Replies Last reply Reply Quote 1
                    • SIamundefined
                      SIam @smoki3
                      @smoki3
                      Yes i use duet wifi
                        jay_s_uk @wilriker
                        @wilriker good to know!
                          chrishamm administrators @wilriker
                          @wilriker I am not aware of this bug, in fact I successfully tested DWC 2.1 with RRF2 just a few days ago.
                          • wilrikerundefined
                            wilriker
                            @chrishamm @jay_s_uk It seems that this bug is only for very specific uncommon configurations. So it should already work with everything <3.01-something
                            Manuel
                            My Tool Collection
                            • c310undefined
                              c310
                              How to enable fans on GUI ?!
                                chrishamm administrators @c310
                                @c310 Job Status => Fans => Change Visibility
                                c310undefined 1 Reply Last reply Reply Quote 0
                                • GrodanBundefined
                                  GrodanB @wilriker
                                  @wilriker said in Duet Web Control 2.1.1 released:
                                  OK... so next release might contain the fix so that it is 2.x compatible?
                                  Plan to go to 3.x but not convinced that it is as good as 2.x yet... Seems to have some bug left to remove until I feel it is worth the work... (2.x works fine for me and I only upgrade for any new features so far...)
                                  But being able to use new DWC is a good reason for upgrade if that is necessary...
                                  • c310undefined
                                    c310 @chrishamm
                                    @chrishamm it does not show up at all. however, if i switch to DWC1 fan is there and works...
                                      @c310 What firmware are you using? Is the fan thermostatically controlled? If yes, no fans are displayed.
                                      • c310undefined
                                        c310 @chrishamm
                                        @chrishamm it was 3.01RC4 with invisible symptoms ... after i upgraded to RC6 it is visible now.
                                        why thermostatic fans are invisible?
                                        how i can input into localization / correct some minor mistakes ?
                                          droftarts administrators @c310
                                          @c310 said in Duet Web Control 2.1.1 released:
                                          Because if they're under temperature control, you can't change their speed, so there's no point having a control over them that doesn't work. If send the gcode to make them non-thermostatic, they will appear. Also (not sure exactly if it's true with the current version), fans linked to specific tools usually don't show until that tool is enabled.
                                          • smoki3undefined
                                            smoki3 @smoki3
                                            @smoki3 said in Duet Web Control 2.1.1 released:
                                            @smoki3
                                            Static ram: 28052
                                            Error status: 0
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Segments left: 0
                                            === Network ===
                                            - WiFi -
                                            @chrishamm can you help here? Looks like for some it is working. I already tried a reset of DWC but it is not working.
