    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.6k
    • chrishammundefined
      chrishamm administrators @garyd9
      @garyd9 @PaulHew Thanks for reporting these issues! I'll fix them in v2.1.2.
      Duet software engineer
      PaulHewundefined 1 Reply Last reply Reply Quote 0
      • mikedahlgrenundefined
        mikedahlgren
        Ever since RC6 I have been getting disconnects and the following error from "Journalctl -f"
        Apr 06 14:34:56 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
        Apr 06 14:34:56 duet3 DuetControlServer[2170]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
        Apr 06 14:34:57 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
        Apr 06 14:34:57 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:35260
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: [fatal] Update task faulted
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: System.ArgumentException: Requested value 'fault' was not found.
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 535.3719ms ^CApr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Request finished in 540.9393ms 101 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
        Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
          mikedahlgren
          Apr 06 14:59:45 duet3 DuetControlServer[7457]: Duet Control Server v1.3.1
          Apr 06 14:59:45 duet3 DuetControlServer[7457]: Written by Christian Hammacher for Duet3D
          Apr 06 14:59:45 duet3 DuetControlServer[7457]: Licensed under the terms of the GNU Public License Version 3
          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Settings loaded
          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Environment initialized
          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Connection to Duet established
          Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] IPC socket created at /var/run/dsf/dcs.sock
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
          Apr 06 14:59:47 duet3 DuetWebServer[551]: Request starting HTTP/1.1 GET http://duet3/machine
          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
          Apr 06 14:59:47 duet3 DuetWebServer[551]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
          Apr 06 14:59:47 duet3 DuetWebServer[551]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Abnormal program termination
          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
          Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket connected from ::ffff:127.0.0.1:36822
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Update task faulted
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: System.ArgumentException: Requested value 'fault' was not found.
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
          Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
          Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:36822
          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
          Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 374.0239ms
          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
          Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
          Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
          Apr 06 14:59:47 duet3 DuetWebServer[551]: Request finished in 374.9353ms 101
          • PaulHewundefined
            PaulHew @chrishamm
            @chrishamm And fan sliders do not work or indicate current speed.
            Sorry.
            • DocTruckerundefined
              DocTrucker
              Version 2.0.7 ran fine on v0.6 and v0.8.5 boards. Is version 2.1+ dependant on using RepRapFirmware 2+ or 3+?
                jay_s_uk @DocTrucker
                @DocTrucker
                Its dependant on RRF3.01+ as it uses the object model
                  DocTrucker @jay_s_uk
                  @jay_s_uk cheers, that's what I expected but I wasn't sure if it used the object model it available, or exclusively. From what you say it is the latter.
                  • GrodanBundefined
                    GrodanB @PaulHew
                    @PaulHew said in Duet Web Control 2.1.1 released:
                    @chrishamm
                    Found this this morning.
                    'Turn Everything Off' does not do anything.
                    FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-01-03b3
                    Also strange is that with a dual set-up the loaded filament is moved from T1 to T0 and cannot be unloaded.
                    (To be clear, T1 has a filament loaded, I do a pause, then immediately a cancel and suddenly T0 is loaded with T1 filament and that cannot be loaded to T1 again and T0 does not what to unload it. Temp settings is still on as espected on T1 (old temp) and t0 also as before...)
                    I had to delete the file "filaments.csv" and do a "EMERGENCY STOP" to get T0 to relese the T1 filament...
                    I think this happen when I cancel a print...
                    Which I do a lot since I try to get my filament to stick.
                    Would be nice to be able to cancel directly and not need to pause and then cancel...
                    This time I do not see the "filament.csv" so I pray to god that a power on of cycle get my printer back...
                    I did... the file was not shown until I made a power on/off cycle.
                    That would be nice if it did.
                    I also do not understand why the file "filament.csv" kept after a power cycle? At least a forced unload feature would be useful...
                    • GrodanBundefined
                      GrodanB
                      For some reason I cannot change the wording mistake I did above (someServer.com identified post as spam)
                      So a power OFF/ON did work...
                      • smoki3undefined
                        smoki3
                        Is M122 working for someone?
                        SIamundefined 1 Reply Last reply Reply Quote 0
                          Thanks, I've already fixed the crash that occurs when a heater fault occurs and I'll fix the filament assignment next. Both fixes will be available when RRF 3.01 is released. Likewise the "Turn off all" button has been fixed and a new DWC version will be released among the next DSF version.
                          GrodanBundefined 1 Reply Last reply Reply Quote 0
                          • SIamundefined
                            SIam @smoki3
                            @smoki3
                            M122 is working here
                            6.4.2020, 20:32:50 	m122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet WiFi 1.02 or later + DueX5
                            Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
                            Used output buffers: 4 of 24 (22 max)
                            Static ram: 28052
                            Dynamic ram: 94208 of which 24 recycled
                            Exception stack ram used: 576
                            Never used ram: 8212
                            Tasks: NETWORK(ready,116) HEAT(blocked,1244) DUEX(suspended,136) MAIN(running,1608) IDLE(ready,80)
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 11:14:43 ago, cause: software
                            Last software reset at 2020-04-06 09:18, reason: User, spinning module GCodes, available RAM 8532 bytes (slot 3)
                            Error status: 0
                            Free file entries: 10
                            SD card longest block write time: 133.8ms, max retries 0
                            MCU temperature: min 21.7, current 39.7, max 41.7
                            Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 0: standstill, SG min/max 0/981
                            Driver 1: standstill, SG min/max 0/1023
                            Driver 2: standstill, SG min/max 0/1023
                            Driver 3: standstill, SG min/max 0/1023
                            Driver 4: standstill, SG min/max 0/1023
                            Driver 5: standstill, SG min/max not available
                            Driver 6: standstill, SG min/max not available
                            Driver 7: standstill, SG min/max not available
                            Driver 9: standstill, SG min/max 0/1023
                            Date/time: 2020-04-06 20:32:48
                            Slowest loop: 312.35ms; fastest: 0.12ms
                            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 107, MaxWait: 5922743ms
                            === MainDDARing ===
                            === AuxDDARing ===
                            Heater 0 is on, I-accum = 0.0
                            Heater 1 is on, I-accum = 0.7
                            Segments left: 0
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 0
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === Network ===
                            Slowest loop: 789.12ms; fastest: 0.00ms
                            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(2) FTP(0) Telnet(0)
                            HTTP sessions: 2 of 8
                            - WiFi -
                            Network state is active
                            WiFi firmware version 1.23
                            WiFi MAC address 2c:3a:e8:0b:06:33
                            WiFi Vcc 3.44, reset reason Unknown
                            WiFi flash size 4194304, free heap 15424
                            WiFi IP address 192.168.188.36
                            WiFi signal strength -49dBm, reconnections 0, sleep mode modem
                            Socket states: 4 0 0 4 0 0 0 0
                            === Filament sensors ===
                            Extruder 0 sensor: ok
                            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                            Duet WiFi Server: 1.26
                            Duet Web Control 3.4.0beta4 (2021-09-27)
                            smoki3undefined 1 Reply Last reply Reply Quote 0
                            • GrodanBundefined
                              GrodanB @chrishamm
                              @chrishamm said in Duet Web Control 2.1.1 released:
                              Great, by the way, great work. Much appreciated.
                              Do you require me to upgrade to RRF 3.01? Do not see the benefit to me until new functions are added at the moment I understand that soon it will be at the same function level as latest 2.x.
                              Again thanks.
                                DocTrucker @GrodanB
                                @GrodanB said in Duet Web Control 2.1.1 released:
                                @jay_s_uk said in Duet Web Control 2.1.1 released:
                                • smoki3undefined
                                  smoki3 @SIam
                                  @SIam said in Duet Web Control 2.1.1 released:
                                  @smoki3
                                  Static ram: 28052
                                  Error status: 0
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  === Network ===
                                  - WiFi -
                                  I just get this without an output. Are you on Duet 2 Wifi?
                                  jay_s_ukundefined SIamundefined smoki3undefined 3 Replies Last reply Reply Quote 0
                                    jay_s_uk @smoki3
                                    @smoki3
                                    i get full M122 output on a duet 3 + pi and a duet 2 ethernet
                                    • wilrikerundefined
                                      wilriker
                                      @jay_s_uk @DocTrucker @GrodanB DWC 2.1.1 is supposed to work with RRF versions pre-ObjectModel. Unfortunately, currently there is a bug in the code that prevents it to get into legacy-mode.
                                      Manuel
                                      My Tool Collection
                                      jay_s_ukundefined chrishammundefined GrodanBundefined 3 Replies Last reply Reply Quote 1
                                      • SIamundefined
                                        SIam @smoki3
                                        @smoki3
                                        Yes i use duet wifi
                                          jay_s_uk @wilriker
                                          @wilriker good to know!
                                            chrishamm administrators @wilriker
                                            @wilriker I am not aware of this bug, in fact I successfully tested DWC 2.1 with RRF2 just a few days ago.
