    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.6k
    • GrodanBundefined
      GrodanB @PaulHew
      @PaulHew said in Duet Web Control 2.1.1 released:
      @chrishamm
      Found this this morning.
      'Turn Everything Off' does not do anything.
      FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-01-03b3
      Also strange is that with a dual set-up the loaded filament is moved from T1 to T0 and cannot be unloaded.
      (To be clear, T1 has a filament loaded, I do a pause, then immediately a cancel and suddenly T0 is loaded with T1 filament and that cannot be loaded to T1 again and T0 does not what to unload it. Temp settings is still on as espected on T1 (old temp) and t0 also as before...)
      I had to delete the file "filaments.csv" and do a "EMERGENCY STOP" to get T0 to relese the T1 filament...
      I think this happen when I cancel a print...
      Which I do a lot since I try to get my filament to stick.
      Would be nice to be able to cancel directly and not need to pause and then cancel...
      This time I do not see the "filament.csv" so I pray to god that a power on of cycle get my printer back...
      I did... the file was not shown until I made a power on/off cycle.
      That would be nice if it did.
      I also do not understand why the file "filament.csv" kept after a power cycle? At least a forced unload feature would be useful...
      • GrodanBundefined
        GrodanB
        For some reason I cannot change the wording mistake I did above (someServer.com identified post as spam)
        So a power OFF/ON did work...
        • smoki3undefined
          smoki3
          Is M122 working for someone?
          SIamundefined 1 Reply Last reply Reply Quote 0
          • chrishammundefined
            chrishamm administrators
            Thanks, I've already fixed the crash that occurs when a heater fault occurs and I'll fix the filament assignment next. Both fixes will be available when RRF 3.01 is released. Likewise the "Turn off all" button has been fixed and a new DWC version will be released among the next DSF version.
            Duet software engineer
            GrodanBundefined 1 Reply Last reply Reply Quote 0
            • SIamundefined
              SIam @smoki3
              @smoki3
              M122 is working here
              6.4.2020, 20:32:50 	m122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet WiFi 1.02 or later + DueX5
              Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
              Used output buffers: 4 of 24 (22 max)
              Static ram: 28052
              Dynamic ram: 94208 of which 24 recycled
              Exception stack ram used: 576
              Never used ram: 8212
              Tasks: NETWORK(ready,116) HEAT(blocked,1244) DUEX(suspended,136) MAIN(running,1608) IDLE(ready,80)
              Owned mutexes: WiFi(NETWORK)
              Last reset 11:14:43 ago, cause: software
              Last software reset at 2020-04-06 09:18, reason: User, spinning module GCodes, available RAM 8532 bytes (slot 3)
              Error status: 0
              Free file entries: 10
              SD card longest block write time: 133.8ms, max retries 0
              MCU temperature: min 21.7, current 39.7, max 41.7
              Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: standstill, SG min/max 0/981
              Driver 1: standstill, SG min/max 0/1023
              Driver 2: standstill, SG min/max 0/1023
              Driver 3: standstill, SG min/max 0/1023
              Driver 4: standstill, SG min/max 0/1023
              Driver 5: standstill, SG min/max not available
              Driver 6: standstill, SG min/max not available
              Driver 7: standstill, SG min/max not available
              Driver 9: standstill, SG min/max 0/1023
              Date/time: 2020-04-06 20:32:48
              Slowest loop: 312.35ms; fastest: 0.12ms
              Hiccups: 0(0), FreeDm: 169, MinFreeDm: 107, MaxWait: 5922743ms
              === MainDDARing ===
              === AuxDDARing ===
              Heater 0 is on, I-accum = 0.0
              Heater 1 is on, I-accum = 0.7
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 789.12ms; fastest: 0.00ms
              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(2) FTP(0) Telnet(0)
              HTTP sessions: 2 of 8
              - WiFi -
              Network state is active
              WiFi firmware version 1.23
              WiFi MAC address 2c:3a:e8:0b:06:33
              WiFi Vcc 3.44, reset reason Unknown
              WiFi flash size 4194304, free heap 15424
              WiFi IP address 192.168.188.36
              WiFi signal strength -49dBm, reconnections 0, sleep mode modem
              Socket states: 4 0 0 4 0 0 0 0
              === Filament sensors ===
              Extruder 0 sensor: ok
              Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
              Duet WiFi Server: 1.26
              Duet Web Control 3.4.0beta4 (2021-09-27)
              smoki3undefined 1 Reply Last reply Reply Quote 0
              • GrodanBundefined
                GrodanB @chrishamm
                @chrishamm said in Duet Web Control 2.1.1 released:
                Great, by the way, great work. Much appreciated.
                Do you require me to upgrade to RRF 3.01? Do not see the benefit to me until new functions are added at the moment I understand that soon it will be at the same function level as latest 2.x.
                Again thanks.
                • DocTruckerundefined
                  DocTrucker @GrodanB
                  @GrodanB said in Duet Web Control 2.1.1 released:
                  @jay_s_uk said in Duet Web Control 2.1.1 released:
                  Its dependant on RRF3.01+ as it uses the object model
                  • smoki3undefined
                    smoki3 @SIam
                    @SIam said in Duet Web Control 2.1.1 released:
                    @smoki3
                    Static ram: 28052
                    Error status: 0
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    - WiFi -
                    I just get this without an output. Are you on Duet 2 Wifi?
                    jay_s_ukundefined SIamundefined smoki3undefined 3 Replies Last reply Reply Quote 0
                      jay_s_uk @smoki3
                      @smoki3
                      i get full M122 output on a duet 3 + pi and a duet 2 ethernet
                      • wilrikerundefined
                        wilriker
                        @jay_s_uk @DocTrucker @GrodanB DWC 2.1.1 is supposed to work with RRF versions pre-ObjectModel. Unfortunately, currently there is a bug in the code that prevents it to get into legacy-mode.
                        Manuel
                        My Tool Collection
                        jay_s_ukundefined chrishammundefined GrodanBundefined 3 Replies Last reply Reply Quote 1
                        • SIamundefined
                          SIam @smoki3
                          @smoki3
                          Yes i use duet wifi
                            jay_s_uk @wilriker
                            @wilriker good to know!
                              chrishamm administrators @wilriker
                              @wilriker I am not aware of this bug, in fact I successfully tested DWC 2.1 with RRF2 just a few days ago.
                              • wilrikerundefined
                                wilriker
                                @chrishamm @jay_s_uk It seems that this bug is only for very specific uncommon configurations. So it should already work with everything <3.01-something
                                Manuel
                                My Tool Collection
                                • c310undefined
                                  c310
                                  How to enable fans on GUI ?!
                                    chrishamm administrators @c310
                                    @c310 Job Status => Fans => Change Visibility
                                    c310undefined 1 Reply Last reply Reply Quote 0
                                    • GrodanBundefined
                                      GrodanB @wilriker
                                      @wilriker said in Duet Web Control 2.1.1 released:
                                      OK... so next release might contain the fix so that it is 2.x compatible?
                                      Plan to go to 3.x but not convinced that it is as good as 2.x yet... Seems to have some bug left to remove until I feel it is worth the work... (2.x works fine for me and I only upgrade for any new features so far...)
                                      But being able to use new DWC is a good reason for upgrade if that is necessary...
                                      • c310undefined
                                        c310 @chrishamm
                                        @chrishamm it does not show up at all. however, if i switch to DWC1 fan is there and works...
                                          @c310 What firmware are you using? Is the fan thermostatically controlled? If yes, no fans are displayed.
                                          • c310undefined
                                            c310 @chrishamm
                                            @chrishamm it was 3.01RC4 with invisible symptoms ... after i upgraded to RC6 it is visible now.
                                            why thermostatic fans are invisible?
                                            how i can input into localization / correct some minor mistakes ?
