Vertical Hole Compression: Possible Solution
  • Hello all,
    Just wanted to share something I just tested. I have a sneaking suspicion I have read something to this effect before somewhere else (or possible on this forum) but could not find the source.
    I have been designing some parts that have two haves that fit over 3 small ball bearings. Initially, they did not fit due to the slicer not being able to perfectly replicate a circle (or arc) in the z-axis, and in effect compressed the hole. This was causing my two parts to have a small gap between them when placed over the bearing.
    During my research, I came across a post which talked about creating a small teardrop or similar shaped cutout in the top of the circle to prevent sagging. I tried to using this technique for the bottom of the circle but to no avail; even with a small offset to account for the tolerances of my printer it still did not work.
    A few hours ago, after printing another set of the parts and again having them not successfully fit over the bearings, I really paid attention to another vertical hole in the part (shaft output) that I had not previously paid attention to. I measure the width and height, and found the height to be less than the width by almost exactly one layer height (plus or minus human error when using calipers, so roughly 0.2mm-0.4mm)
    I quickly designed a basic bearing holder, with an ellipse instead of a normal circle and the height offset of the bearing diameter by 0.2mm, with the width remaining the same. After printing, I found that the bearing seated
    perfectly.
    TL,DR: Try to use an ellipse with a width matching the exact hole size (+- tolerances) and a height equaling the hole diameter plus the layer height you are going to be printing at for rounder holes in the z-axis.
    (if/when slicers ever adopt import of native .step/.stp file formats it would be nice to see automatic compensation like that done on the slicer side, so designs could be a little more agnostic of a persons' chosen manufacturing methods.
  • remember reprap logo?
    it's the shape of the hole that "works" 🙂
  • @arhi Is that why the teardrop is the logo? The more you know!
    However, my issue was the bottom half of the circle being not round enough, not the top.
    (just added a picture to the original post to explain it better)
  • @Red-Sand-Robot said in Vertical Hole Compression: Possible Solution:
    Yup, dr. Adrian designed that shape so that holes will work and rods can go in without a need to redril every hole. If you look at first darwin all holes are like that 😄
    that's the error I discussed many times with number of developers, originally with Enrique while he was making skeinforge, the layer off and you have "larger" hole, layer on and you have smaller hole, decision is usually to go with smaller hole as hole can be drilled oposed to if it's too big you can't do much. I personally design holes + layer height when it's big holes (holding big bearings etc) or I leave it as is and drill out the holes manually later (rods, small bearings..) especially when I print big .6mm or bigger layers, those issues become much more obvious and drilling actually gets to be for me the only way around it
  • @arhi said in Vertical Hole Compression: Possible Solution:
    What I have been noticing is that the width and diameter is generally correct in the XY plane, but the diameter in the Z gets squished (layer removed?). I tried that exact shape (teardrop) with limited success; not sure if its due to it being the lower half of the hole or just the issues with how the slicer is analyzing the shape.
    With the ellipse, I have a feeling the way the offset is more gradually applied causes the edges of the layers to line up with the "proper" shape of circle. I've been trying to limit post processing as much as possible, as the geometry makes it difficult or next to impossible to sand by hand/Dremel effectively.
  • Moderator
    A logo that highlights one of the limitations of the technology!
    Understandable, that's why I drill holes (as if there is a screw that can go in, a drill can go in too), and design "holders" bigger (bearing openings and such) by adding a layer height to the whole size. The elipse approach might be more accurate I will have to try next time 🙂
  • If I'm printing something where I need accurate alignment between bearings I print it so that the holes for the bearings are printed in the XY plane. I know it isn't possible with all prints to do that, but you'll definitely get best alignment and fit that way. If the part has other areas that need accurate alignment as well, I will typically split it into multiple pieces so that all of them get the better alignment assured by printing in the XY plane. It's not cheating to make printed things out of multiple parts!
    Recent motor mount with a bearing on the end of the shaft:
    alt text]
    The only support material was under a 10mm tang to fit into t-slot on the bottom of the print in the picture.
    The forces on the bearings are usually radial, and if you print the bearing mount in the XY plane you get maximum strength from the print. If you print with the bearing mount(s) in the XZ or YZ plane, you usually get a much weaker print.
  • @mrehorstdmd said in Vertical Hole Compression: Possible Solution:
    alt text]
    I see you received your JMC servos!
    Have you tuned them yet?
    ...typically split it into multiple pieces so that all of them get the better alignment assured by printing in the XY plane. It's not cheating to make printed things out of multiple parts!
    I already have my gearbox design spit in to two halves, I wish I could split it in to more pieces but assembly would be a nightmare!
    For a frame of reference, those bearings are 15x24x5mm. I'm trying to keep everything as compact as possible.
    I do agree that generally the mounts will be weaker in the XZ or YZ plane, but since I will be applying a clamping force to the bearings the printed parts will be under a compressive, not tensile force. From personal experience and reading/watching others' work, printed parts are a far stronger under compressive loads than tensile in the Z axis (as I am sure you already know).
  • Moderator
    @Red-Sand-Robot What layer heights are you printing at?
    I've also found that using a piece of breakaway supports can also help. Either in the slicer or even in CAD by simply adding a little block under the top arch of the hole with a small single layer height gap.
  • @Phaedrux I've ranged from 0.2 to 0.28, both as static values and using adaptive layer heights (PrusaSlicer 2.2).
    The issue isn't the top of the circle, but the bottom half. I'm only printing the lower half of the circle due to the geometry of my design (less supports) and to avoid the sagging/loss of roundness that occurs on the upper half of circles in Z. Circles in the Z axis will most likely continue be an issue with FFF due to the 2D layers only approximating the curve of a circle, at least until slicers support .step import so smarter compensation can be done on the slicer side of things.
  • I printed a similar gearbox by splitting it into two pieces and printing both with the worm gear bearing slots facing up. Everything fit together quite well. In your gearbox, there would be only one bearing slot for the worm.
    Don't make bosses the way I did! They should be opposite the way I did them- the screws should pass freely through the boss and thread into the body of the other half of the shell.
    What layer height did you use for that, and did you include any offsets to account for tolerances of your printer? I have seen your printers, and know they are rock solid - but machines extruding melted plastic have their limits.
    I am printing all three bearing slots facing up, as you did with the work gear bearing slots. Unfortunately for my micro differential, the shape of the bevel gear pairing makes it difficult to successfully split in a different configuration, unless I split it in to four pieces (two for the differential and two to constrain the pinion bearing, to prevent it from shifting forward) - but then alignment issues between the teeth of the pinion and wheel gear could occur.
  • @Red-Sand-Robot I probably used 200 um layers, as I do for most prints. I generally bump round, XY plane hole diameters up by 0.25 mm and find that results in a tight fit- the bearings for the disc gear had to be gently convinced to go into their holes. I use a little less bump in size for the vertical holes- maybe 0.15 mm. I also use random seam position so the little perimeter start/stop bumps will get scattered around and won't mess up the alignment.
  • Moderator
    I dare ask, have you tuned pressure advance?
  • @Phaedrux Probably not as much as I need to...
  • i asked similar question here and got number of valuable answers and tested all of them.
    In general the approach was to modify TOP of the circle.
    In my case that was not sufficient. So, i made ellipse. in vertical diameter it is 1.3x in horizontal is it the same as hole .
    Also i have reduced the hole size. As an example - M5 bolt: hole size 4,1mm (R2.05), ellipse: vertical 2.05*1.3=2.665 horizontal 2.05
    That gives more or less circle hole on the top and on the bottom as well. illustration is below
    this is what i get without support or cooling with 0.3 layer
    and with bolt inside:
    as you can see - bolt sits very well. no spaces either side (if i use "standard" M5 hole, there will be quiet a space on left and right 🙂
    M5 goes in like in the nut, but if you want just to insert the bolt, than drill 4.8 mm hole.
    You can tell that "drilling is possible without additional ellipse", but from my tests i can say that drilling "standard" hole has high chance of center being offset.
    hope it helps someone.
  • What about using support in holes?
  • @NitroFreak from my experience in small holes supports may help to avoid small bubble on the top, but they may create bubble on the bottom 🙂
    and support does not help with holes being not-round...
    so i decided not to use supports for this model.
