CoreXY Ringing
  • Hi all,
    I've built a huge CoreXY printer - based loosely on a short lived design by FLSun. Currently its at the "proof of concept" stage while I iron out all the bugs.
    I've been trying to iron out the settings, and I spent a few hours on these forums last night looking for clues to a ringing problem I had on a large test cube.
    I added M593 to my config.g file (along with a few other tweaks) and that seems to have cured it completely. However, There is now a larger artifact at the very start of a long wall, then it fades away to nothing. - see image below.
    What could cause this? I'm assuming it's a G-Code thing since it wasn't there before.
    I've attached my config.g as well for reference. config.g
    (also appreciate if you notice anything in that config that I should attend too as well.
    Finally... Big thanks to dc42 and Phaedrux for all their wisdom - all the posts I found offered some valuable contribution from one or both of you.
    All the best.
  • Is ringing affected by the print speed?
  • I would try lowering the acceleration.
    There may be a part which is flexing (belt tenstion too low, some pulley or axis).
  • @fcwilt
    This is the first print since I tweaked the settings, so I'm not sure...
    What action would I take in either case?
  • @JoergS5
    Its likely that the gantry is flexing ... it's only 40x20 Vslot over 800mm long,
    I'll try reprinting on a different area of the bed (gantry closer to one end), and tweaking the accel...
    Keen to keep the suggestions coming, it'll keep me busy over the weekend.
    Cheers
  • @Gerrard said in CoreXY Ringing:
    @fcwilt
    I have no idea. I was just wondering about this ringing issue which I don't think I have encountered in my prints BUT I don't try to print at very high speeds with 60 mm/s being my normal speed.
    @JoergS5
    Cheers
    Sometimes it helps to make the gantry more stiff by adding some triangle connections at the corners. Steel/Aluminium plates or even steel wires could help.
  • Moderator
    It looks like you've traded one frequency of ringing for another. DAA has limitations, especially in a corexy where the X and Y axis may have different ringing frequencies. In the end, for my corexy, I had to find a jerk/accel combo that gave good quality on external walls, I also use Cura that allows me to set different jerk/accel per print move, so that infill, etc can be much faster than the walls need to be.
  • Hi All,
    Quick updated. I spent most of today tuning settings and speeds - mostly in search of good quality and super high speeds.
    I added an equal angle to the back of the gantry in the hope of curing some of the vibration, and it's done the trick for sure - which validates the flexing hypothesis.
    I reduced the acceleration slightly (at the same time) and started cranking up the speed. I've managed to achieve 300mm/s on a simple thin walled square with only the faintest trace of ringing so I'm thrilled with that result. I did get a problem with under extrusion at about the 200mm/s mark, but I cured that by just turning the nozzle temp up to 220°C, and that cured it.
    My final settings were
    300mm/s for all surfaces (walls, top and bottom layers).
    100mm/s for initial layers.
    500mm/s^2 Accel (all conditions)
    9mm/s Jerk.
    I feel like I could go a fair bit higher on the accel, so I'm going to try pushing that a little harder over time.
    I do however have another problem (pre-existing)... I'll start a new thread for that to keep this clean.
    Thanks all.
  • What could cause this? I'm assuming it's a G-Code thing since it wasn't there before.
    On my printer (CR10 style) this would be caused by an incorrect pressure advance parameter.
  • Hi @jens55 - As above, it seems to be related to the stiffness of the gantry... increasing the stiffness made the problem go away.
  • DAA (M593) has an inherent flaw in that it only really works perfectly when there is 0 jerk.
    Unfortunately it´s usually the jerk that causes most of the ringing...
  • I somehow missed the picture with the final settings when I replied earlier.
    That surface finish is incredible! I have never seen finish like that before even at a much lower speed. It's amazing what can be done if you don't sling a 2 kg (or whatever) bed around !
    Thanks for posting that ....
    Hmmmm ..... food or new 3D printer ..... well this seems a good enough reason to go on a diet!
  • @jens55 It's worth noting that I was only printing at 0.2mm layer height. It's easy (easier?) to get a nice finish at lower layer height - there's less molten plastic to deal with.
  • At 300 mm/sec you can print as fast with 0.2 mm layers as I can go with a 1 mm layer height! It just amazes the hell out of me!
    I hope that you might have a chance to share more pictures of your build as it progresses (or when it's ready for prime time).
  • @jens55 with acceleration at 500 mm/sec^2 and jerk at 9 mm/sec, the printer probably never actually achieves 300 mm/sec.
  • @jens55 said in CoreXY Ringing:
    With a good multipaterial printer you can print your food! 😉
  • @mrehorstdmd The bed is 800x870 so there's plenty of room to move. But you're right, you need a bigger print. I'll increase Accel and Jerk soon - I decreased them to help eliminate those defects initially.
  • @Gerrard Now look at corners of a square print- at low jerk and accel they then to get fat and rounded. Everything is a trade off.
