    Dead Driver or Stepper Motor?
    743
    • BlueDustundefined
      BlueDust
      One of my Z motors is having an issue. It holds its position, but will not spin. Just shakes.
      It started this right after the print finished... (is that weird? or just lucky?)
      I get this error...
      2020-06-08 16:59:12 Warning: motor phase B may be disconnected reported by driver(s) 8
      As my drivers look clean, I don't think it is the Duex5. And as such I am swapping the 3rd Z motor with my Extruder motor to confirm.
      Any advice, or way to confirm it's the motor or the driver?
      I am asking to learn something for next time as by the time you read this, I should already have the motors swapped.
      Thanks!
      The center driver has the motor showing problems...
      Fun, that 3 letter word with "u" in the middle.
      • BlueDustundefined
        BlueDust
        So now I am a bit worried....
        What can I do to test this without possibly doing more damage... Assuming something is or isn't already damaged... I am guessing the Motor is bad, but if it's the driver/duex5 I could break another motor by testing it. Or maybe it's just the crimp finally failed after almost 2 years of use and I just need to replace the end???
          What do the solder points for those pins look like on the underside?
          How does the crimp on that cable look?
          If you're lucky the error message was correct and that phase was loose and disconnecting and the driver chip didn't get damaged itself.
          BlueDustundefined 1 Reply Last reply Reply Quote 0
          • BlueDustundefined
            BlueDust @Phaedrux
            @Phaedrux said in Dead Driver or Stepper Motor?:
            I just started to play with it a bit more. The motor connected to that driver looks fine. The pin on it has no marks. I just swapped out the driver/motor wire, and everything is working again.
            I haven't had a chance to take the Duex5 off the case just yet, and now may not.
            My guess is the crimp was bad and just now, decided to get hot. It's been maybe two years running and have had prints take days. This one was only about 8 hours long, and the moment I went to start the next print, it stopped working.
            It will take me a few minutes to get that bad cable out, and will share a picture shortly.
            • BlueDustundefined
              BlueDust @BlueDust
              How much should I worry about other damages at this point?
              I can't see anything wrong with that crimp... Other then the fact its burnt up that is.
                Could have been poor contact between the crimp and the pin, or the wire could be poorly crimped itself. Either way, I'd definitely recrimp them.
                • BlueDustundefined
                  BlueDust @Phaedrux
                  @Phaedrux
                  I will recrimp and possibly just not use this cable right now and replace the cable I took from spare inventory I just put into production...
                  Karmaundefined 1 Reply Last reply Reply Quote 0
                  • Karmaundefined
                    Karma @BlueDust
                    @BlueDust That was a very good find. I would say that you should just re-crimp that wire with a new pin and you will be all set. I would also replace that connector if possible. I would also highly suggest that you clean/gently scrap the connector that had connected to that failed pin. I only say this because you will most likely find some sort of a carbon buildup on it.
                    I have seen this kind of situation before many times while I was in the Air Force working on the Electrical System of many different Aircraft.
                    If you have any questions about this, please reply or send me a private message.
                    Take Care
                    Shawn B. aka Karma
                    BlueDustundefined 1 Reply Last reply Reply Quote 1
                    • BlueDustundefined
                      BlueDust @Karma
                      Hey @Karma
                      I did "try" to scrap some of the carbon off the pin, but I don't think I was able to do a good job before I put it back together to test (and confirm it was just the wire/crimp). I will be taking it apart again to do a better job at cleaning the pin off.
                      I will replace the connector , as if I have more problems I don't want this burn mark to confuse me and hinder my troubleshooting in the future.
                      I am just happy it doesn't look like anything "real" was damaged. I really think this was a reminder that I planned to replace all of the motor wires with custom lengths and neatly hide them in the frame of the printer... Its a custom build, and I really haven't 100% finished it... After a lot of troubleshooting upfront I just wanted to print and prove it worked.... I think it has been almost 2 years now. 😆
                      Karmaundefined 1 Reply Last reply Reply Quote 1
                      • Karmaundefined
                        Karma @BlueDust
                        @BlueDust Bro, I get what you mean about just wanting to get it together just enough to see if it will print. My control box that has all my components in is falling apart. Stupid acrylic design. Cracked it on the first day, and also on the second and third. Very cheap design. I am going to customize where the control board will be with everything else. I seen how to do it and how it looks from a facebook group dedicated to the Tevo Black Widow. There is this one member that has completely redesigned the Black Widow and it looks mean as heck. He has also got the mmu from Prusa to work on it. Crazy, I know, but he did it. He had to figure out how to interfave with the mmu in order to get it to work. He didn't have enough Tx and Rx pins left on the main board. But somehow he figured it out and it runs great.
                        • A Former User?
                          A Former User
                          If the pins are plated then scraping anything off them will likely scrape off the plating resulting in a short term solution.
                          Best bet it replace both, should be possible to pull out a single pin and put in a new if de-soldering the whole header is a problem.
                            dc42 administrators @A Former User
                            @bearer said in Dead Driver or Stepper Motor?:
                            It's possible to pull the plastic part off. It's easier of you use hot air at about 150-180C to heat the connector first. After that you should be able to remove and replace the connector pin.
                            • BlueDustundefined
                              BlueDust @dc42
                              Does the printer automatically stop or pause when this error occurs?
                              I saw this error when I was trying to rehome the printer, and it didn't appear to stop. I hit the STOP button.
                              I am curious to know as if this happens again while printing, I would want it to stop or at least run the pause script (but the printer isn't working so that sounds dumb).
                              Thanks!
                                dc42 administrators @BlueDust
                                @BlueDust said in Dead Driver or Stepper Motor?:
                                No, because the warning isn't a 100% guarantee that the stepper motor phase has become disconnected.
                                • BlueDustundefined
                                  BlueDust @dc42
                                  Is there a way to make it user configurable, so I can make the printer stop if this or similar error occurs? But then turn the it off if there are false errors?
                                  In my case it was happening, and it would have been bad for the printer to continue trying to print.
                                  OwenDundefined 1 Reply Last reply Reply Quote 0
                                  • OwenDundefined
                                    OwenD @BlueDust
                                    @BlueDust you could probably use daemon.g to monitor the driver for errors and act accordingly.
                                    You’d have to see what values are available in the object model.
                                    • BlueDustundefined
                                      BlueDust @OwenD
                                      @OwenD
                                      Thanks for letting me know about daemon.g.
                                      Is deamon.g for both the RR2.x and RR3.x?
                                      I started to look into it but 1 quick search didn't find anything in the wiki. Do you have a link to any documentation I can read before I start asking questions?
                                      I have yet to do any custom programming for the Duet2, and I guess spending a few minutes at least reading this may motivate me to get started.
                                      Thanks!
                                        jay_s_uk
                                        The daemon.g is only applicable to RRF3
                                        • BlueDustundefined
                                          BlueDust @jay_s_uk
                                          @jay_s_uk
                                          Thanks!
                                          I have yet to upgrade to RR3....
                                          Rebuilt printer with rails/new carriage, resolved extrusion problems, started to print large project.... will have to put large project on hold and upgrade to RR3...
                                          Thanks!
