    Duet 3 Mini 5+ : Initial announcement
    288
    31.0k
    • pixelpieperundefined
      pixelpieper
      One more question: will GPIO14/15 on the SBC interface be wired to a UART on the ยตC? Seems like this is not the case in the moment for the Duet 3 but could be very useful for compatibility with Klipper.
      Voron V2.434 / Duet 3 Mini5+, Duet 3 Expansion Mini 2+, Duet 1LC V1.1 Toolboard
      Voron V0.250 / Duet 2 Maestro
        dc42 administrators @pixelpieper
        @pixelpieper said in Duet 3 Mini 5+ : Initial announcement:
        No; but a UART is available on the IO1 connector.
        pixelpieperundefined 1 Reply Last reply Reply Quote 1
          pixelpieper @dc42
          @dc42 I guess there is no space left for a 2x2 header to jumper this connection if needed?
          • T3P3Tonyundefined
            T3P3Tony administrators @pixelpieper
            @pixelpieper can you expand on the usage? Why can Klipper not use SPI?
            www.duet3d.com
            pixelpieperundefined 1 Reply Last reply Reply Quote 0
              pixelpieper @T3P3Tony
              @T3P3Tony Klipper could if someone implements it, direct UART communication is just already available and would simplify the implementation.
              If you have the space to allow for a 2x2 header to be soldered in connecting to the IO1 pins it would be a neat way to get this UART (edit: connected through jumpers) if needed while adding no cost to the PCB...
              • A Former User?
                A Former User @pixelpieper
                If you have the space to allow for a 2x2 header to be soldered in connecting to the IO1 pins it would be a neat way to get this UART if needed while adding no cost to the PCB...
                The connector that support PanelDue already has UART available and as of 3.x something RRF support using it in "raw" mode so that can be done as is for all Duets.
                  pixelpieper @A Former User
                  @bearer sure, its just much neater if it can be done directly through the already existing SBC cable rather than having to make your own wiring loom.
                  • A Former User?
                    @pixelpieper oh, then i missread your post, as adding UART to the SBC connector only requires to route the rx and tx pins to pin 8 and 10 on the existing 2x13 header
                      @bearer hence the suggestion to allow for this connection ๐Ÿ™‚
                      • A Former User?
                        @pixelpieper then you might want to change the wording - asking for additional space for a 2x2 header isn't the same thing, and doesn't even achieve the goal of using the same 26pin ribbon cable without custom wiring loom.
                        T3P3Tonyundefined pixelpieperundefined 2 Replies Last reply Reply Quote 1
                        • T3P3Tonyundefined
                          T3P3Tony administrators @A Former User
                          @bearer @pixelpieper
                          Thanks - I understand. The 2x2 header would be a pair of jumpers so that the UART was not always connected to the SBC (for example if you wanted to use a PanelDue instead.
                          I will look at this as part of the next design review.
                          www.duet3d.com
                            @bearer good point, I meant 2x2 in order to add jumpers to RX and TX
                            • A Former User?
                              A Former User
                              d'oh - brain is being slow...
                              if its talk of a unpopulated headed then solder bridges are smaller and easier to place?
                              • piperswundefined
                                pipersw
                                So if I have a Duet2wifi with 1.68A steppers for X Y E0, Dual Z 1.68 steppers in serial, bltouch and Rotating Magnet Filament Monitor, I could go to this board without issue ?
                                A Former User? pixelpieperundefined 2 Replies Last reply Reply Quote 0
                                  @bearer either through bridges or by soldering in the header and adding jumpers to easily reverse it, I don't mind either way.
                                  • A Former User?
                                    A Former User @pipersw
                                    @pipersw said in Duet 3 Mini 5+ : Initial announcement:
                                    most likely quite soon, ref https://forum.duet3d.com/post/168488 (maybe i missread that too, I meant you could use existing board with klipper and sbc)
                                      pixelpieper @pipersw
                                      @pipersw You would probably use a separate driver for each Z, but yes.
                                      • rilotundefined
                                        rilot
                                        Wow. This is going to be a release day purchase for sure. I love my Duet2 Wifi and have put RRF on my SKR boards because the Duet spoiled me so much with its ease of use.
                                        I was reluctant to buy more Duets as I figured there'd be something like this coming soon.
                                        Can't wait. I'll take two!
                                        • tetra3dprintundefined
                                          tetra3dprint
                                          Very excited about this with the three driver expansion board!
                                          I've been deliberating what board I want to use for an upcoming project and the Duet 3 6HC was up there, although a little ott for my needs.
                                          @gregsaun pointed out this upcoming board and it's actually a perfect match for the project. There is no longer any question as what board I'll be using ๐Ÿ™‚
                                          • jchodakowskiundefined
                                            jchodakowski
                                            100% ๐Ÿ‘ all day
