    Duet 3 Mini 5+ : Initial announcement
    288
    31.6k
      piperswundefined 1 Reply Last reply Reply Quote 3
      • oliofundefined
        oliof
        ... that green PCB confused me for a second.
        Exciting!
          It's only green because green prototypes are sometimes faster to get made and delivered than blue ones.
          Dougal1957undefined 1 Reply Last reply Reply Quote 1
          • Dougal1957undefined
            Dougal1957 @dc42
            @dc42 Want one for my Delta time it had an upgrade lol
              So far, testing shows that the wifi upload speed is about the same as the Duet WiFi, and the Ethernet upload speed is a little faster than the Duet Ethernet.
              Dougal1957undefined piperswundefined 2 Replies Last reply Reply Quote 2
                Dougal1957 @dc42
                @dc42 I assume that the SBC support is there as that would be the way I would want to run it failing that the ethernet one would be my choice TBH. Once it is available.
                • elmoretundefined
                  elmoret
                  Looking good!
                    SBC support is included, but not tested yet. I've currently disabled SBC support in firmware, because I identified an issue that causes problems when SBC support is included but no SBC is connected.
                    Dougal1957undefined 1 Reply Last reply Reply Quote 0
                      Dougal1957 @dc42
                      @dc42 said in Duet 3 Mini 5+ : Initial announcement:
                      Is that across the whole duet3 range or just the mini due to the different MCU?
                      • jbarrosundefined
                        jbarros
                        This would be great to test on an IDEX I'm building 🙂
                        You get picked for the testing or will there be a way to apply?
                        • piperswundefined
                          pipersw @dc42
                          @dc42 There is a big difference of speed between wifi and ethernet speed ?
                            dc42 administrators @pipersw
                            @pipersw said in Duet 3 Mini 5+ : Initial announcement:
                            No, the Ethernet is currently only about 20% faster than the WiFi, although there is more scope for improvement with Ethernet.
                            • Traveler0612undefined
                              Traveler0612
                              I already have a Duet 2 Wifi. I would love to test this on my Delta, and Folgertech FT-5, that is likely going to be converted to corexy.
                              • jallen810undefined
                                jallen810
                                This looks awesome! I am especially interested in being able to use my 24v PS and then use 12v fans as they're so much easier to get ahold of!
                                Was the rumor I heard that Duet3 Mini will have both Ethernet and WiFi, true as well?
                                  dc42 administrators @jallen810
                                  There will be separate Ethernet and WiFi versions.
                                  • Vetiundefined
                                    Veti
                                    this is a very nice evolution.
                                    any news on when it will be available?
                                    • T3P3Tonyundefined
                                      T3P3Tony administrators @Veti
                                      @Veti I expect we will have some availability for normal purchase in November.
                                      We have to iterate on the prototype and then conduct more CE and FCC testing before we put it on general sale.
                                      www.duet3d.com
                                      cabal2000undefined 1 Reply Last reply Reply Quote 1
                                      • DIY-O-Sphereundefined
                                        DIY-O-Sphere
                                        @T3P3Tony said in Duet 3 Mini 5+ : Initial announcement:
                                        We are excited to officially announce a new Duet Mainboard:
                                        The Duet 3 Mini 5+ is an evolution of the Duet 2 Maestro
                                        Have you also plans to bring Duet2 WiFI/Ethernet to the next level?
                                        For the next project I need 9 -12 steppers....
                                        As a user of a Maestro the Duet 3 Mini 5+ would fulfill all my requirements...except the count of steppers...
                                        Are there any options to get 9 steppers working ???
                                        (UTC+1)
                                        dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                                          dc42 administrators @DIY-O-Sphere
                                          @DIY-O-Sphere said in Duet 3 Mini 5+ : Initial announcement:
                                          The Duet 3 Mini is intended to fit in the medium price and performance segment, so the microcontroller doesn't have enough I/O pins for 9 drivers. However, we're looking at adding CAN bus expansion to the Mini 5+, which would allow tool boards etc. to be connected.
                                          • T3P3Tonyundefined
                                            T3P3Tony administrators @DIY-O-Sphere
                                            @DIY-O-Sphere also, you can use 12 steppers on the Duet 2!
                                            www.duet3d.com
                                            DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
