    Bltouch setup need help
    Firmware installation
    3.8k
    • JoergS5undefined
      JoergS5 @Elvis0z
      @Elvis0z can you make a M122 after the G28 test please and show?
      An does G1 Z10 and G1 Z-10 move as expected when you run this commands directly?
      • Elvis0zundefined
        Elvis0z
        @JoergS5 said in Bltouch setup need help:
        G1 Z-10
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
        Board ID: 08DGM-9T6BU-FG3SD-6J9D0-3S86Q-1AMBF
        Used output buffers: 3 of 24 (10 max)
        Static ram: 27980
        Dynamic ram: 93712 of which 44 recycled
        Exception stack ram used: 264
        Never used ram: 9072
        Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
        Owned mutexes:
        Last reset 00:00:35 ago, cause: software
        Last software reset at 2020-07-09 19:59, reason: User, spinning module GCodes, available RAM 8584 bytes (slot 1)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
        Error status: 0
        MCU temperature: min 30.6, current 31.7, max 32.0
        Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
        Date/time: 2020-07-09 19:59:45
        Cache data hit count 60372819
        Slowest loop: 4.74ms; fastest: 0.13ms
        === Storage ===
        Free file entries: 10
        SD card longest read time 3.1ms, write time 0.0ms, max retries 0
        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
        === MainDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        === AuxDDARing ===
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 41.57ms; fastest: 0.00ms
        Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is active
          WiFi firmware version 1.23
          WiFi MAC address ec:fa:bc:2d:b3:11
          WiFi Vcc 3.36, reset reason Unknown
          WiFi flash size 4194304, free heap 20056
          WiFi IP address 192.168.50.68
          WiFi signal strength -46dBm, reconnections 0, sleep mode modem
        09/07/2020, 20:00:48 G1 Z10
        Error: G0/G1: insufficient axes homed
        09/07/2020, 20:01:17 G1 Z-10
        • Elvis0zundefined
          Elvis0z
          When I do a G28 command once z probe deploys the console just spins around and I can't put any commands in till I restart control board
          JoergS5undefined 1 Reply Last reply Reply Quote 0
          • JoergS5undefined
            JoergS5 @Elvis0z
            @Elvis0z first sorry for my G1 Z-10 and G1 Z10. This will not work because Z is not homed. The correct commands are G1 H2 Z-10 and H1 H2 Z10 to move even when the Z is not homed. Just to check Z can move at all at this position.
            I was searching what this fast white LED blinking means, but I can only find fast red blinking (which would be eg white and black cables switched).
            Can you please make an image of the wiring of the Duet Wifi and the cables at the 5-pin connector of the BLTouch?
            • Elvis0zundefined
              Elvis0z
              G1 H2 Z-10
              Yep moves up and down with new commands
              • JoergS5undefined
                JoergS5 @Elvis0z
                @Elvis0z I have no more ideas.
                Two things I found in my research:
                • often it was a wiring problem. Wrong wiring, wiring or connector broke or disturbance by heat or magnets
                • on reddit was a report of a damaged charge of BLtouch 3.1. But you tried 2 BLtouch, I think probability is low for this reason
                I have only one idea left: please recheck wiring and connections. And the other idea to find out the reason for the error message of M98 P"config.g".
                If I have a new idea, I'll tell you.
                • Elvis0zundefined
                  Elvis0z
                  Wiring for bltouch
                  • Elvis0zundefined
                    Elvis0z
                    Black wire is connected to white
                    Blue wire is connected to black
                    JoergS5undefined 2 Replies Last reply Reply Quote 0
                    • JoergS5undefined
                      JoergS5 @Elvis0z
                      @Elvis0z looks all ok.
                      • JoergS5undefined
                        JoergS5 @Elvis0z
                        @Elvis0z what you can try is the G30 has some options:
                        https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
                        e.g. you could try the
                        G30 P0 X20 Y50 Z-99999
                        or
                        G30 S-1
                        etc.
                        and try to find out why Z is not moving with the G30 without parameters.
                        I would run homeall to home X and Y and position in the middle of the bed, comment out the rest of homall and make the tests with G30 from the console input field.
                        • Elvis0zundefined
                          Elvis0z
                          Thanks for your help so far. Bit of a mystery
                            Does your Z axis move at all? Does it raise and lower slightly when you do home all?
                            If you send G92 Z100 to mark it as homed and at position 100mm, then send G91 for relative moves, and then G1 Z10 it should move up 10mm.
                            • Elvis0zundefined
                              Elvis0z
                              @Phaedrux said in Bltouch setup need help:
                              G1 Z10
                              Yep moved up 10mm
                              • Elvis0zundefined
                                Elvis0z
                                Once I did those commands it said that z was homed. But when I did home all it does the same thing as in the video.
                                • Elvis0zundefined
                                  Elvis0z
                                  Woohoo don't know what I did but it homed z when I did home all. As the command G92 z100 homed the z, I was able to calibrate the Zprobe trigger hight in the centre of the bed. Then there where a few errors
                                  G28
                                  Error: Z probe was not triggered during probing move
                                  Error: Homing failed
                                  Same stuff.
                                  Then the bltouch was just blinking red led. I raised up the bed another 10mm and restarted the printer and the blinking stopped.
                                  Tried G30 said that not enoght axis homed so homed x and y. Then did G30 and it deployed the probe and when down and retracted when touching the bed did this again and homed.
                                  Then I did a home all and woohoo it worked.
                                  so I have not idea what went on but hey its working
                                  Thanks for all the help getting my printer working. I really appreciate all the help you guys have given me. Next is to do bed leveling.
                                    I have no idea what happened either, but glad it's working.
                                    • JoergS5undefined
                                      JoergS5 @Elvis0z
                                      @Elvis0z I expect it will remain a mystery... but I am happy that it works for you now!
