    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    8.9k
    • Vetiundefined
      Veti @MartinNYHC
      @MartinNYHC
      not by ben, but for 1204 there is a metal kit
      https://de.aliexpress.com/item/4001277526161.html
      MartinNYHCundefined 1 Reply Last reply Reply Quote 0
      • MartinNYHCundefined
        MartinNYHC @Veti
        @Veti Very nice. Did you try it?
        Wondering if there every will be a point in time where a build is finished. Don't think so 😂
        Vetiundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti @MartinNYHC
          @MartinNYHC
          no i made my own 1204 mounting with metal parts.
          • whopping pochardundefined
            whopping pochard
            Very cool! Love to see the ballscrews.
            Looking forward to seeing the finished product!
            • Vetiundefined
              Veti
              the bed is rock solid and does not move under pressure.
                MartinNYHC
                @Veti Can you please share details of your reinforcement rods and mounts? Where can I get them?
                • Vetiundefined
                  Veti @MartinNYHC
                  @MartinNYHC
                  4x 8mm linear rods (had them from an old printer)
                  8x SK8
                  https://www.robotdigg.com/product/126/SK8-Linear-Shaft-Support-Unit
                  4 SCS8LUU (screwed into 2020 profile with m3 t nut)
                  https://www.robotdigg.com/product/422/SCS8LUU-Linear-Block
                  2 Nema 17 2020 mounting brackets (the store from which i ordered does not sell them anymore, similar item)
                  https://www.aliexpress.com/item/32892098907.html
                  2 SFU1204
                  the sfu1204 mount will be replaced with when i replace the other parts with the blv metal kit
                  https://www.aliexpress.com/item/4001120210864.html
                    MartinNYHC
                    Thanks @Veti
                    • fcwiltundefined
                      fcwilt
                      Simple can work as well.
                      The part with the V groove attaches to the bed support frame, which is not shown for clarity purposes.
                      I like seeing the wide variety of solutions to common issues.
                      • flux_capacitorundefined
                        flux_capacitor
                        Amazing mod! The independent triple z-axis system from @Nuramori seems unavailable though: the zip file on Thingiverse contains only one small file (chain_mount_-_bed.stl). What happened to the design?
                        dhusoloundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                        • dhusoloundefined
                          dhusolo @flux_capacitor
                          @flux_capacitor That's because he's using a different source file due to all the changes he's done.
                          Z Drive System.zip
                          If you want to stay up to date with the project join the facebook page. Thingiverse went to crap after their last update and they don't seem to keen on fixing it.
                          Nuramoriundefined 1 Reply Last reply Reply Quote 1
                          • Nuramoriundefined
                            Nuramori @dhusolo
                            @dhusolo Yep, thingiverse crapped the bed.
                            I should look at putting things on github instead.
                            • psychotik2k3undefined
                              psychotik2k3
                              @whopping-pochard you said: "The IR sensor. The mini IR sensor, presumably a clone, appears to have an old version of the firmware which causes premature triggering."
                              How can i check the firmware version and mitigate this ? thanks.
                              • Nuramoriundefined
                                Nuramori @whopping pochard
                                @whopping-pochard said in My BLV MGN cube build/upgrade saga (ongoing):
                                @Nuramori thanks for your beautiful design! It was a big inspiration for this. 😄
                                Happy to help! Looks great!
                                • Nuramoriundefined
                                  Nuramori @flux_capacitor
                                  @flux_capacitor if you need it let me know. I'm on here too... 😛
                                  • Pro100sanek23undefined
                                    Pro100sanek23 @whopping pochard
                                    @whopping-pochard
                                    hi, can you share a link or files of the back wall and electronics mounts? thanks
                                      whopping pochard
                                      As far as I gathered, if it displayed the issue, it had the old firmware. Specifically, what it looked like was it would trigger twice -- once around 8-11 mm away, and once at the proper trigger height of ~2-3 mm. You could see it as a sort of intermittent illumination at the 8-11 mm distance. I don't think you could actually check the firmware directly without an AVR programmer, which I didn't happen to have. I solved the issue by buying a genuine part. 🙂
                                      I will carve out some time to update my files this weekend. I'm now hosting at PrusaPrinters because Thingiverse is too unreliable. Will ping here when I get them up!
                                      -j
