    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    8.9k
    • Vetiundefined
      Veti @dhusolo
      @dhusolo
      can you answer some questions?
      where do the endstops on the x carriage go now? the bottom seems to be different and no space to mount the endstop.
      are the mounting holes on the x carriage compatible with the hemera?
      does the original hotend cooling fan cover fit?
      does the original part cooling fan duct fit?
      dhusoloundefined 1 Reply Last reply Reply Quote 0
      • dhusoloundefined
        dhusolo @Veti
        @Veti I'm not entirely sure. I haven't seen any of the cad drawings to see how it's assembled. I won't purchase the metal parts until a suitable triple/quad independent Z axis is developed.
        However I was mistaken. You do need to be on the Facebook group to have access to the beta metal parts
        • I_Jediundefined
          I_Jedi @MartinNYHC
          I used blind joints with my Misumi extrusions and it was worth every penny! Misumi's cuts were spot on and when done, no angle was off my more than .3 degrees using my digital square. And SOLID as a rock to! Thanks to @Nuramori for the suggestion!
          • Vetiundefined
            Veti
            the metal parts have now been released.
            https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
            not sure if i will get them as i like a direct extruder setup, and so far its only bowden
            whopping pochardundefined dhusoloundefined MartinNYHCundefined 3 Replies Last reply Reply Quote 1
            • whopping pochardundefined
              whopping pochard @Veti
              @Veti that looks pretty great!
              • dhusoloundefined
                dhusolo @Veti
                @Veti Ben will be making a direct drive version. I also talked to him and I'm going to be alpha testing the independent triple Z setup when he finishes it
                • MartinNYHCundefined
                  MartinNYHC @Veti
                  @Veti I just assembled the kit and I think it's worth it even if you don't use the extruder parts. I also skipped the extruder parts because I'm using a BMG-M with Mosquito.
                  And I'm currently working on a three axis setup 😉
                  • Vetiundefined
                    Veti
                    Ben just posted a video about blind joints
                    https://www.youtube.com/watch?v=ueniUWrUcjE
                    MartinNYHCundefined 1 Reply Last reply Reply Quote 0
                      MartinNYHC @Veti
                      @Veti Yes, I'm very interested but I think I can't wait until it's available. I need my kitchen 🙂
                      • Vetiundefined
                        Veti @MartinNYHC
                        @MartinNYHC
                        not by ben, but for 1204 there is a metal kit
                        https://de.aliexpress.com/item/4001277526161.html
                          MartinNYHC @Veti
                          @Veti Very nice. Did you try it?
                          Wondering if there every will be a point in time where a build is finished. Don't think so 😂
                          • Vetiundefined
                            Veti @MartinNYHC
                            @MartinNYHC
                            no i made my own 1204 mounting with metal parts.
                              whopping pochard
                              Very cool! Love to see the ballscrews.
                              Looking forward to seeing the finished product!
                              • Vetiundefined
                                Veti
                                the bed is rock solid and does not move under pressure.
                                  MartinNYHC
                                  @Veti Can you please share details of your reinforcement rods and mounts? Where can I get them?
                                  • Vetiundefined
                                    Veti @MartinNYHC
                                    @MartinNYHC
                                    4x 8mm linear rods (had them from an old printer)
                                    8x SK8
                                    https://www.robotdigg.com/product/126/SK8-Linear-Shaft-Support-Unit
                                    4 SCS8LUU (screwed into 2020 profile with m3 t nut)
                                    https://www.robotdigg.com/product/422/SCS8LUU-Linear-Block
                                    2 Nema 17 2020 mounting brackets (the store from which i ordered does not sell them anymore, similar item)
                                    https://www.aliexpress.com/item/32892098907.html
                                    2 SFU1204
                                    the sfu1204 mount will be replaced with when i replace the other parts with the blv metal kit
                                    https://www.aliexpress.com/item/4001120210864.html
                                      MartinNYHC
                                      Thanks @Veti
                                      • fcwiltundefined
                                        fcwilt
                                        Simple can work as well.
                                        The part with the V groove attaches to the bed support frame, which is not shown for clarity purposes.
                                        I like seeing the wide variety of solutions to common issues.
                                        • flux_capacitorundefined
                                          flux_capacitor
                                          Amazing mod! The independent triple z-axis system from @Nuramori seems unavailable though: the zip file on Thingiverse contains only one small file (chain_mount_-_bed.stl). What happened to the design?
                                          dhusoloundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                                          • dhusoloundefined
                                            dhusolo @flux_capacitor
                                            @flux_capacitor That's because he's using a different source file due to all the changes he's done.
                                            Z Drive System.zip
                                            If you want to stay up to date with the project join the facebook page. Thingiverse went to crap after their last update and they don't seem to keen on fixing it.
                                            Nuramoriundefined 1 Reply Last reply Reply Quote 1
