    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    9.0k
    • dhusoloundefined
      dhusolo @Veti
      @Veti I'm not entirely sure. I haven't seen any of the cad drawings to see how it's assembled. I won't purchase the metal parts until a suitable triple/quad independent Z axis is developed.
      However I was mistaken. You do need to be on the Facebook group to have access to the beta metal parts
      • I_Jediundefined
        I_Jedi @MartinNYHC
        I used blind joints with my Misumi extrusions and it was worth every penny! Misumi's cuts were spot on and when done, no angle was off my more than .3 degrees using my digital square. And SOLID as a rock to! Thanks to @Nuramori for the suggestion!
        • Vetiundefined
          Veti
          the metal parts have now been released.
          https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
          not sure if i will get them as i like a direct extruder setup, and so far its only bowden
          whopping pochardundefined dhusoloundefined MartinNYHCundefined 3 Replies Last reply Reply Quote 1
          • whopping pochardundefined
            whopping pochard @Veti
            @Veti that looks pretty great!
            • dhusoloundefined
              dhusolo @Veti
              @Veti Ben will be making a direct drive version. I also talked to him and I'm going to be alpha testing the independent triple Z setup when he finishes it
              • MartinNYHCundefined
                MartinNYHC @Veti
                @Veti I just assembled the kit and I think it's worth it even if you don't use the extruder parts. I also skipped the extruder parts because I'm using a BMG-M with Mosquito.
                And I'm currently working on a three axis setup 😉
                • Vetiundefined
                  Veti
                  Ben just posted a video about blind joints
                  https://www.youtube.com/watch?v=ueniUWrUcjE
                  MartinNYHCundefined 1 Reply Last reply Reply Quote 0
                    MartinNYHC @Veti
                    @Veti Yes, I'm very interested but I think I can't wait until it's available. I need my kitchen 🙂
                    • Vetiundefined
                      Veti @MartinNYHC
                      @MartinNYHC
                      not by ben, but for 1204 there is a metal kit
                      https://de.aliexpress.com/item/4001277526161.html
                        MartinNYHC @Veti
                        @Veti Very nice. Did you try it?
                        Wondering if there every will be a point in time where a build is finished. Don't think so 😂
                        • Vetiundefined
                          Veti @MartinNYHC
                          @MartinNYHC
                          no i made my own 1204 mounting with metal parts.
                            whopping pochard
                            Very cool! Love to see the ballscrews.
                            Looking forward to seeing the finished product!
                            • Vetiundefined
                              Veti
                              the bed is rock solid and does not move under pressure.
                                MartinNYHC
                                @Veti Can you please share details of your reinforcement rods and mounts? Where can I get them?
                                • Vetiundefined
                                  Veti @MartinNYHC
                                  @MartinNYHC
                                  4x 8mm linear rods (had them from an old printer)
                                  8x SK8
                                  https://www.robotdigg.com/product/126/SK8-Linear-Shaft-Support-Unit
                                  4 SCS8LUU (screwed into 2020 profile with m3 t nut)
                                  https://www.robotdigg.com/product/422/SCS8LUU-Linear-Block
                                  2 Nema 17 2020 mounting brackets (the store from which i ordered does not sell them anymore, similar item)
                                  https://www.aliexpress.com/item/32892098907.html
                                  2 SFU1204
                                  the sfu1204 mount will be replaced with when i replace the other parts with the blv metal kit
                                  https://www.aliexpress.com/item/4001120210864.html
                                    MartinNYHC
                                    Thanks @Veti
                                    • fcwiltundefined
                                      fcwilt
                                      Simple can work as well.
                                      The part with the V groove attaches to the bed support frame, which is not shown for clarity purposes.
                                      I like seeing the wide variety of solutions to common issues.
                                      • flux_capacitorundefined
                                        flux_capacitor
                                        Amazing mod! The independent triple z-axis system from @Nuramori seems unavailable though: the zip file on Thingiverse contains only one small file (chain_mount_-_bed.stl). What happened to the design?
                                        dhusoloundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                                        • dhusoloundefined
                                          dhusolo @flux_capacitor
                                          @flux_capacitor That's because he's using a different source file due to all the changes he's done.
                                          Z Drive System.zip
                                          If you want to stay up to date with the project join the facebook page. Thingiverse went to crap after their last update and they don't seem to keen on fixing it.
                                          Nuramoriundefined 1 Reply Last reply Reply Quote 1
                                          • Nuramoriundefined
                                            Nuramori @dhusolo
                                            @dhusolo Yep, thingiverse crapped the bed.
                                            I should look at putting things on github instead.
