Unsolved Short to ground on drivers 0123
@droftarts said in Short to ground on drivers 0123:
G1 X10 F300
No Panel Due Ethernet connection
G92 X0 Y0
G1 X10 F300Error: short-to-ground reported by driver(s) 0 1
03/08/2020 à 15:04:54 m122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
Board ID: 08DJM-956L2-G43S8-6JKD6-3SJ6L-KA02G
Used output buffers: 2 of 40 (11 max)
Static ram: 154604
Dynamic ram: 162384 of which 44 recycled
Exception stack ram used: 272
Never used ram: 75912
Tasks: ETHERNET(blocked,436) NETWORK(ready,388) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,204) MAIN(running,4656) IDLE(ready,76)
Owned mutexes:
Last reset 00:02:33 ago, cause: power up
Last software reset at 2020-08-02 08:21, reason: User, spinning module LinuxInterface, available RAM 75776 bytes (slot 1)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443c000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 22.7, current 32.1, max 32.2
Supply voltage: min 0.2, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 0.1, current 12.1, max 12.4, under voltage events: 0
Driver 0: short-to-ground standstill, reads 44551, writes 14 timeouts 0, SG min/max 0/8
Driver 1: short-to-ground standstill, reads 44552, writes 14 timeouts 0, SG min/max 0/8
Driver 2: standstill, reads 44556, writes 11 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 44557, writes 11 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 44558, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 44558, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-08-03 15:04:53
Slowest loop: 29.12ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 2.3ms, write time 23.8ms, max retries 0
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 134960ms
=== MainDDARing ===
Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 28.84ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 1 of 8- Ethernet -
State: active
Error counts: 0 0 0 0 0
Socket states: 5 2 2 2 2 0 0 0
=== CAN ===
Messages sent 613, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 153531ms ago
RX/TX seq numbers: 0/1
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
Edit: when the PanelDue is sending commands, they should be echoed on the USB (I think). If so, what command is being sent to move X?
I don't see anything regarding echo on the command
- Ethernet -
@droftarts
Hello
Same results with YAT and USB commands without connected Panel Due. Error short on driver 0 1 ...
I don't know what to say anymore.... -
@Touchthebitum please email me info@duet3d.com and I will arrange a return directly
