Unsolved Short to ground on drivers 0123
@Phaedrux Tape is only a protection to avoid shorts contact. Contacts were good since I made continuity tests and resistance tests and I always had signal.
Were there any other error messages along with the short to ground errors?
@Phaedrux No, M122 had not error messages. Only those ground-short messages
When are where was the Duet 3 purchased?
Please send M122 and post the resulting output here.
m122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956L2-G43S8-6J9F4-3S46N-TU2QD
Used output buffers: 1 of 40 (10 max)
Static ram: 154604
Dynamic ram: 162592 of which 44 recycled
Exception stack ram used: 224
Never used ram: 75752
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:44 ago, cause: power up
Last software reset at 2020-07-27 15:14, reason: User, spinning module LinuxInterface, available RAM 75704 bytes (slot 0)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443c000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 19.4, current 27.7, max 27.8
Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
Driver 0: standstill, reads 22474, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 22474, writes 14 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 22475, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 22475, writes 14 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 22478, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 22479, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-07-27 15:15:01
Slowest loop: 3.63ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 1.02ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 72, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 18ms ago
RX/TX seq numbers: 583/584
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 4096
Configured SPI speed: 8000000 Hz
Full transfers per second: 30.27
- Ethernet -
Thanks. Please try commanding the motors to move (without any motors connected) and repeat that. I am looking for the driver status to change.
Error: short-to-ground reported by driver(s) 0 1
27/07/2020 à 21:40:14 m122
Static ram: 154604
Exception stack ram used: 280
Never used ram: 75696
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:47 ago, cause: power up
Error status: 0
MCU temperature: min 20.8, current 29.0, max 29.1
Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0
Driver 0: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/0
Driver 1: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/63
Driver 2: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-07-27 20:36:50
Slowest loop: 3.82ms; fastest: 0.14ms
=== Storage ===
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 34018ms
=== MainDDARing ===
Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 0.88ms; fastest: 0.01ms
State: disabled
=== CAN ===
Messages sent 100, longest wait 0ms for type 0
Last transfer: 17ms ago
RX/TX seq numbers: 808/809
Buffer RX/TX: 0/0-0
Full transfers per second: 3.50
- Ethernet -
I have a similar issue, getting "Warning: motor phase A may be disconnected reported by driver(s)" on all drive ports with what were working stepper motors. Only possible mistake i made is connect one stepper motor to 3 pins instead of 4 ie offset one pin. Would this cause all drivers to die?
@percyb said in Short to ground on drivers 0123:
Impossible because I tested all phases before plugging motor and I checked if these big crimps went on the right place when connectind them on the Duet,
ref https://forum.duet3d.com/post/100507 and you should probably start your own topic if the error persist after disconnecting your motors (when powered down ofc)
@bearer said in Short to ground on drivers 0123:
I think we should think about a warranty process. I don't know what to add to the discussion. I repeat, it is not the first printer I build and I'm aware of risks. Before this Duet3 I used a Duet2 and was perfect (no errors messages) with the same motors. This board never worked and I directly plugged the SAME motors that I plugged to my Duet2. So there is a problem.
My shop told me to see with this forum, what I did.
Now, I choosed a Genuine board because I believe in the right intelectual properties and know-how.
Please, give me a clear answer and we can go on.
Thanks -
@Touchthebitum said in Short to ground on drivers 0123:
that was not directed at you; I'm sure dc42 is trying to evaluate the information you've provided already
Thanks
Thanks for your patience, DC42 is away right now but I can help.
Looking at your latest M122 report it looks like driver 01 and 1 are damaged. its not completely clear if 2 and 3 are damaged - the motors connected to those ones could have an issue.
Can you try the following please
check the wiring of one of your stepper with a voltmeter. they should be wired in two pairs, 1-2 and 3-4 (i.e. pin 1 to 2 should read a few Ohms, pin 3 to 4 should read a few ohms but there should be no connection between pin the pairs).
with just that motor you have check tried it plugged into Driver 2, command a movement, send M122 and see what it says, we are looking at this part:
Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0 Driver 0: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/0 Driver 1: short-to-ground standstill, reads 39652, writes 17 timeouts 0, SG min/max 0/63 Driver 2: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0 Driver 3: standstill, reads 39656, writes 14 timeouts 0, SG min/max 0/0 Driver 4: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0 Driver 5: standstill, reads 39660, writes 11 timeouts 0, SG min/max 0/0
- Repeat for driver 3 and driver 4.
Lets see those three excerpts from M122.
Hello
I tested pairs and got 2ohms on each pair and nothing between the two pairs
For the moves of drivers 3-4 I made z move on the duet panel Due
For the driver 4 , I don't have yet a connected extruder
Error: short-to-ground reported by driver(s) 2
28/07/2020 à 12:31:08 m122
Static ram: 154604
Exception stack ram used: 376
Never used ram: 75600
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,196) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:01:08 ago, cause: power up
Error status: 0
MCU temperature: min 20.6, current 29.8, max 29.9
Driver 0: standstill, reads 8684, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 8684, writes 14 timeouts 0, SG min/max 0/0
Driver 2: short-to-ground standstill, reads 8681, writes 17 timeouts 0, SG min/max 0/8
Driver 3: standstill, reads 8685, writes 14 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 8688, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 8689, writes 11 timeouts 0, SG min/max 0/0Error: short-to-ground reported by driver(s) 2
28/07/2020 à 12:33:42 M122
Used output buffers: 1 of 40 (13 max)
Static ram: 154604
Exception stack ram used: 360
Never used ram: 75616
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1460) TMC(blocked,68) MAIN(running,4536) IDLE(ready,76)
Owned mutexes:
Last reset 00:01:04 ago, cause: power up
Error status: 0
MCU temperature: min 32.1, current 32.5, max 32.6
Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, reads 56891, writes 0 timeouts 0, SG min/max not available
Driver 1: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
Driver 2: short-to-ground standstill, reads 56888, writes 2 timeouts 0, SG min/max not available
Driver 3: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 56890, writes 0 timeouts 0, SG min/max not available
Date/time: 2020-07-28 11:33:45
Slowest loop: 3.63ms; fastest: 0.21msDriver number 4 : there is no extruder tool message
you will need to update your configuration temporarily to use the test motor on driver 3, and then again on driver 4 - use the M584 command in config.g:
(To test driver 3) :
M584 X0.0 Y0.1 Z0.3 E0.2 ; Temporary drive mapping to test driver 3 as Z
(To test driver 4) :
M584 X0.0 Y0.1 Z0.4 E0.2 ; Temporary drive mapping to test driver 4 as Z
This post is deleted! -
@T3P3Tony said in Short to ground on drivers 0123:
Driver 3
m122
Static ram: 154604
Exception stack ram used: 368
Never used ram: 75608
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:31 ago, cause: software
Last software reset at 2020-07-28 13:51, reason: User, spinning module LinuxInterface, available RAM 75720 bytes (slot 3)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 33.6, current 34.2, max 34.4
Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, reads 26013, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 26013, writes 14 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 26013, writes 14 timeouts 0, SG min/max 0/0
Driver 3: short-to-ground standstill, reads 26011, writes 17 timeouts 0, SG min/max 0/8
Driver 4: standstill, reads 26017, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 26018, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-07-28 13:52:03
Slowest loop: 4.13ms; fastest: 0.14msDriver 4 MOTOR IS MOVING DURING TEST
Error: short-to-ground reported by driver(s) 4
28/07/2020 à 14:54:51 m122
Static ram: 154604
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:50 ago, cause: power up
Last software reset at 2020-07-28 13:53, reason: User, spinning module LinuxInterface, available RAM 75608 bytes (slot 0)
Error status: 0
MCU temperature: min 28.3, current 34.6, max 34.7
Driver 0: standstill, reads 53146, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 53146, writes 14 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 53147, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 53150, writes 11 timeouts 0, SG min/max 0/0
Driver 4: short-to-ground standstill, reads 53145, writes 17 timeouts 0, SG min/max 0/160
Driver 5: standstill, reads 53151, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-07-28 13:54:55
Slowest loop: 4.15ms; fastest: 0.13msIt is the first time I see a motor moving on this board
