Short to ground on drivers 0123
@Touchthebitum said in Short to ground on drivers 0123:
Driver 4: short-to-ground standstill, reads 53145, writes 17 timeouts 0, SG min/max 0/160
OK so it looks like drivers 0-3 are damaged, possibly by the moving pins around earlier but hard to say.
That said there is another issue that is causing a working motor to report short to ground (on driver 4). It may be that the damage to the other drivers is effecting them all. DC42 will have a better idea.
Because of that I will authorise a warranty return. please use reference this thread in the warranty form that your reseller (3dware.ch) will ask you to complete for us and be sure to fill out the serial number so we can match this board to this thread.
When you get your new board please triple check the wiring before powering everything up. I was a little concerned to see the tape holding the crimps on - intermittent disconnection of 1 wire of the 4 driver wires can damage the drivers.
Ok, thanks for your time and support.
I'll 10x check ;), I want to print -
Hello
I got the second Duet 3 and I'm getting mad with this board.
I checked 10 times the phases/continuity on every motor.
Before testing movements I made M122 (usb mode) and everything is ok. All drivers are ok.
I test y movement with my Panel Due movement button and I get "Error: short-to-ground reported by driver(s) 0 1"After that I made M122 and I get this :
m122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956L2-G43S8-6JKD6-3SJ6L-KA02G
Used output buffers: 1 of 40 (10 max)
Static ram: 154604
Dynamic ram: 162592 of which 44 recycled
Exception stack ram used: 200
Never used ram: 75776
Tasks: NETWORK(ready,1968) HEAT(blocked,1232) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1460) TMC(suspended,252) MAIN(running,5132) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:49 ago, cause: power up
Last software reset at 2020-08-02 08:21, reason: User, spinning module LinuxInterface, available RAM 75776 bytes (slot 1)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0443c000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 20.6, current 28.3, max 28.4
Supply voltage: min 0.2, current 0.2, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
12V rail voltage: min 0.1, current 0.2, max 0.3, under voltage events: 0
Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
Date/time: 2020-08-02 10:44:14
Slowest loop: 2.64ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.27ms; fastest: 0.01ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 104, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 12ms ago
RX/TX seq numbers: 843/844
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 4096
Configured SPI speed: 8000000 Hz
Full transfers per second: 11.04
Please I don't want to blow something.
What am I missing ?
I'm starting to regret my WORKING Duet2 Wifi.
I'm using the SBC mode with a Raspberry 4 8GBHere is my config file built with the online configurator:
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 12:20:30 GMT+0200 (heure d’été d’Europe centrale); General preferences
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode; Drives
M569 P0 S1 ; physical drive 0.0 goes forwards
M569 P1 S1 ; physical drive 0.1 goes forwards
M569 P2 S1 ; physical drive 0.2 goes forwards
M569 P3 S1 ; physical drive 0.3 goes forwards
M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X230 Y210 Z500 S0 ; set axis maxima; Endstops
M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
M574 Y2 S1 P"io2.in" ; configure active-high endstop for high end on Y via pin io2.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
M558 P9 C"^io6.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
M308 S1 P"temp0" Y"thermistor" T325000 B4138 ; configure sensor 1 as thermistor on pin temp0
M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
M106 P1 S1 H1 T200 ; set fan 1 value. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M564 H0; Miscellaneous
M564 H0 - Ethernet -
No 12/24V power reported? PSU connected and turned on? Note wiring order for power is the other way around from Duet 2. I see all previous M122 did have 24V. Check fuse.
Otherwise, can you post a picture of your Duet board and wiring, showing where steppers are connected?
Please also post the specs of the motors you are trying to connect.
Do you know what speed the PanelDue buttons are requesting axis movement?
@droftarts
Thanks for your reply.
I'm afraid to put current in this board ...
I tried one movement , one time and got short message on drivers ...Here is the last M122 with the PSU on :
m122
Static ram: 154604
Exception stack ram used: 272
Never used ram: 75704
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,192) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:48 ago, cause: power up
Error status: 0
MCU temperature: min 17.1, current 25.4, max 25.5
Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
Driver 0: standstill, reads 41634, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 41634, writes 14 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 41635, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 41635, writes 14 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 41639, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 41639, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-08-02 12:46:46
Slowest loop: 3.86ms; fastest: 0.14ms
=== Storage ===
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 1.39ms; fastest: 0.01ms
State: disabled
=== CAN ===
Messages sent 103, longest wait 0ms for type 0
Last transfer: 17ms ago
RX/TX seq numbers: 841/842
Buffer RX/TX: 0/0-0
Full transfers per second: 0.49
Motors are Blurolls 17HM19-2004S and was working on the Duet2 Wifi
I don't know the speed for movements on the Paneldue.No motor connected , move X and I got this :
02/08/2020 Ã 15:04:23 m122
Static ram: 154604
Exception stack ram used: 304
Never used ram: 75672
Tasks: NETWORK(ready,1968) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:00:54 ago, cause: power up
Error status: 0
MCU temperature: min 17.0, current 25.5, max 25.6
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: short-to-ground standstill, reads 3896, writes 17 timeouts 0, SG min/max 0/8
Driver 1: short-to-ground standstill, reads 3896, writes 17 timeouts 0, SG min/max 0/8
Driver 2: standstill, reads 3900, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 3900, writes 14 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 3904, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 3904, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-08-02 14:04:21
Slowest loop: 4.23ms; fastest: 0.14ms
=== Storage ===
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 38119ms
=== MainDDARing ===
Scheduled moves: 1, completed moves: 1, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 1.82ms; fastest: 0.01ms
State: disabled
=== CAN ===
Messages sent 127, longest wait 0ms for type 0
Last transfer: 16ms ago
RX/TX seq numbers: 1025/1026
Buffer RX/TX: 0/0-0
Full transfers per second: 0.35
- Ethernet -
@Touchthebitum can you try setting up the Duet in standalone mode, and test? Disconnect the RPi, create a fresh SD card, copy over your config. My theory: your RPi is causing the issue, possibly something on the SPI bus. No real evidence for this, just that I think it unlikely (though possible) that you’d have two broken boards in a row.
@droftarts
same results ... error on driver 0 and 1
It's a nightmare
I can't post anything since I don't have ethernet connection -
to the board in stand alone mode?
@bearer
No, I'm far from a router -
@bearer
No, I'm far from a routeryou can do all the tests over usb serial interface, or a direct (ethernet) connection to your computer with static ip addresses on both duet and computer when duet is in stand alone mode.
@bearer
Ok, what do you need as info or tests ? -
i suspect should repeat all the steps you did diagnosing the old board to see if the error persist when using the Duet as a stand alone board.
you could also configure your raspberry pi to be a wifi to ethernet bridge , but imho its easier to set a static up for a direct ethernet connection but all three options would work.
@bearer
I have a connected laptop to my board but I don't know ho to connect -
This is perplexing.
- Are there any other connectors in the leads that connect the motors to the Duet? If so, please post a photo of them.
- Please post a photo of the stepper motor wires where they go into the motor.
- Please use your multimeter to check that there is no continuity between any of the motor wires and the body of the motor.
- Use your multimeter to check that with the connectors fitted, the resistance across each phase is as expected (a few ohms, not a short circuit) and there is no continuity between the two motor phases. Your multimeter probes should be able to fit in the slots in the connector shells in order to make contact with the crimp pins inside.
to set a static IP address on the Duet, you have two options, config.g or USB. Both cases involves
M552 S1 P192.168.1.14
as shown in https://duet3d.dozuki.com/Wiki/Gcode#Section_M552_Set_IP_address_enable_disable_network_interfacethen you need to configure the correct network interface for the computer to use an address in the same network range. probably best to ask google how to do this for your operating system and version/language.
if you use the example above for the duet, set the PC to be IP address
192.168.1.15
with netmask255.255.255.0
and leave the other settings blank or at their defaults.if you have trouble with the computer let us know what operating system/version/language it is and maybe someone can help
No, it is direct wire from motor to the board
list item
I checked 10x and there is no continuity, resistance is ok
I tested the motors plugged with the multimeter and it is the same result like unplugged
no short between motor case and plugs
@bearer
Thanks, I used usb to make tests.First test : psu on, no connected motors, no movements:
m122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
Used output buffers: 1 of 40 (21 max)
Static ram: 154604
Dynamic ram: 162384 of which 44 recycled
Exception stack ram used: 308
Never used ram: 75876
Tasks: ETHERNET(blocked,472) NETWORK(ready,244) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4628) IDLE(ready,76)
Owned mutexes:
Last reset 00:14:54 ago, cause: power up
Error status: 0
MCU temperature: min 30.0, current 30.7, max 30.7
Supply voltage: min 0.2, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 0.1, current 12.1, max 12.4, under voltage events: 0
Driver 0: standstill, reads 42573, writes 11 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 42573, writes 11 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 42574, writes 11 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 42574, writes 11 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 42575, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 42576, writes 11 timeouts 0, SG min/max 0/0
Date/time: 2020-08-02 21:35:01
Slowest loop: 4.89ms; fastest: 0.16ms
=== Storage ===
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 2.6ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
HTTP is idle in state(s) 0
Trigger is idle in state(s) 0
Daemon is idle in state(s) 0
=== Network ===
Slowest loop: 5.26ms; fastest: 0.03ms
HTTP sessions: 1 of 8- Ethernet -
State: active
Socket states: 5 2 2 2 2 0 0 0
=== CAN ===
Messages sent 344, longest wait 0ms for type 0
Last transfer: 894436ms ago
RX/TX seq numbers: 0/1
Buffer RX/TX: 0/0-0
Second test : psu on, no connected motors, movement on x through the panel Due:
8/2/2020, 9:36:51 PM Error: short-to-ground reported by driver(s) 0 1
8/2/2020, 9:36:47 PM m122
Used output buffers: 1 of 40 (22 max)
Static ram: 154604
Tasks: ETHERNET(blocked,436) NETWORK(ready,244) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1424) TMC(blocked,60) MAIN(running,4628) IDLE(ready,76)
Owned mutexes:
Last reset 00:16:39 ago, cause: power up
Error status: 0
MCU temperature: min 30.6, current 31.9, max 32.0
12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
Driver 0: short-to-ground standstill, reads 56010, writes 3 timeouts 0, SG min/max 0/8
Driver 1: short-to-ground standstill, reads 56009, writes 3 timeouts 0, SG min/max 0/8
Driver 2: standstill, reads 56013, writes 0 timeouts 0, SG min/max not available
Driver 3: standstill, reads 56012, writes 0 timeouts 0, SG min/max not available
Driver 4: standstill, reads 56013, writes 0 timeouts 0, SG min/max not available
Driver 5: standstill, reads 56013, writes 0 timeouts 0, SG min/max not available
Date/time: 2020-08-02 21:36:46
Slowest loop: 17.09ms; fastest: 0.21ms
=== Storage ===
SD card longest read time 2.3ms, write time 12.3ms, max retries 0
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 984672ms
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
=== Network ===
Slowest loop: 19.59ms; fastest: 0.03ms
State: active
=== CAN ===
Messages sent 422, longest wait 0ms for type 0
Last transfer: 999813ms ago
- Ethernet -
@Touchthebitum rather than using the PanelDue (try with it disconnected in case it’s causing the problem), send Gcode moves via USB. First set a position for the X and Y axis with
G92 X0 Y0
, then sendG1 X10 F300
. You will need motors connected to driver 0 and 1, or you’ll get an error.Guide to setting up direct Ethernet connection here: https://duet3d.dozuki.com/Wiki/Setting_up_networking_on_Duet#Section_Wired_direct_connection
Edit: when the PanelDue is sending commands, they should be echoed on the USB (I think). If so, what command is being sent to move X?
@Touchthebitum, thanks for answering my previous questions. Two more:
- what is the stepper motor model number?
- what resistance do you measure across each phase?
I get 1.7 (stabilised) as resistance on every motor on both phase
I'll execute tests this morning
