    Feature Request - workpiece angle compensation CNC
    Firmware wishlist
    11
    54
    2.7k
    • CanDo415undefined
      CanDo415 @CanDo415
      @jay_s_uk
      i modified it quite a bit. some points are still not ready.
      I'm not shure how to ent the if passage.
      end if seems not to work
      var y_1 = 0
      var x_1 = 0
      var x_2 = 0
      var x_3 = 0
      var x_4 = 0
      var x_5 = 0
      var delta_x = 0
      var y_2 = 0
      var y_3 = 0
      var y_4 = 0
      var y_5 = 0
      var delta_y = 0
      var z0 = 0
      var d_probe = 0
      var m_1 = 0
      var m_2 = 0
      var m_1_tan_rads = 0
      var m_1_tan_deg = 0
      M291 P"position probe over front left corner of workpiece" S2 X1 Y1 Z1	; Pop up box asking for operator input
      M558 F300																		; Set the initial probing speed
      G38.2 Z-60 P0 K0																; Probe the material as a first pass
      M558 F50																		; Set the final probing speed
      G38.4 Z50 P0 K0        ; Move away from workpiece in Z
      M400																			        ; Make sure all movement is complete
      set var.z0=move.axes[2].machinePosition	                			    		                ; Record the stop position y_first_measurement
      M400																			        ; Make sure all data recording is complete
      G1 Z{move.axes[2].machinePosition+5}										; Move along the workpiece in X
      G1 X{move.axes[0].machinePosition-20}										; Move 5mm away from the material
      G1 Y{move.axes[1].machinePosition+5}										; Move 5mm away from the material
      G1 Z{move.axes[2].machinePosition-3}											; Move along the workpiece in X
      M558 F1000																		; Set the initial probing speed
      G38.2 X100 P0 K0																; Probe the material as a first pass
      G38.4 X-10 P0 K0        ; Move away from workpiece in X
      set var.y_1=move.axes[1].machinePosition							    		        ; Record the stop position y_first_measurement
      set var.x_1=move.axes[0].machinePosition							    		        ; Record the stop position x_first_measurement
      G1 X{move.axes[0].machinePosition-5}											; Move 5mm away from the material
      G1 Z{move.axes[2].machinePosition+10}										; Move along the workpiece in X
      G1 X{move.axes[0].machinePosition+15}										; Move 5mm away from the material
      G1 Y{move.axes[1].machinePosition-20}										; Move 5mm away from the material
      G1 Z{move.axes[2].machinePosition}	    										; Move along the workpiece in X
      G38.2 Y100 P0 K0																; Probe the material as a first pass
      G38.4 Y-10 P0 K0															        ; Probe the material again
      set var.y_2=move.axes[1].machinePosition								    	        ; Record the stop position y_first_measurement
      set var.x_2=move.axes[0].machinePosition					    				        ; Record the stop position x_first_measurement
      G1 Y{move.axes[1].machinePosition-50}										; Move 5mm away from the material
      G1 X{move.axes[0].machinePosition+50}										; Move along the workpiece in X
      set var.y_3=move.axes[1].machinePosition								    	        ; Record the stop position y_second_measurement
      set var.x_3=move.axes[0].machinePosition								    	        ; Record the stop position x_second_measurement
      M291 P"Probe Diameter" R"enter diameter of probe" S5 L0 H10			; Pop up box asking for operator input diameter of
      set var.d_probe=input															; set the diameter of the probe
      ;calculation
      set var.delta_y={var.y_3-var.y_2}
      set var.delta_x={var.x_3-var.x_2}
      set var.m_1={var.delta_y/var.delta_x}											; m of the staight P2-P3
      set var.m_2={(-var.delta_x)/var.delta_y}										        ; m of perpendicilar to straight P2-P3
      set var.m_1_tan_rads=atan(var.m_1)
      set var.m_1_tan_deg=degrees(var.m_1_tan_rads)
      ;calc the corner of workpeace
      set var.x_4=((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))
      set var.y_4=(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))+(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)
      If var.y_2>var.y_3																; workpiece Zero coordinates
      set var.x_5=var.x_4+(COS(ARCTAN(var.m_1))+COS(ARCTAN(var.m_2)))*var.d_probe/2
      set var.y_5=var.y_4+(SIN(ARCTAN(var.m_1))+SIN(ARCTAN(var.m_2)))*var.d_probe/2
      If var.y_2<var.y_3
      set var.x_5=var.x_4+(COS(ARCTAN(var.m_1))-COS(ARCTAN(var.m_2)))*var.d_probe/2
      set var.y_5=var.y_4+(SIN(ARCTAN(var.m_1))-SIN(ARCTAN(var.m_2)))*var.d_probe/2
      ;move over workpiece zero and set tool x&y to 0
      G1 Y{move.axes[1].machinePosition-1}											        ; Move 1mm away from the material
      G1 Z{move.axes[2].machinePosition+10}											; Move above workpiece
      ;G68 A0 B0 R{-var.m_1_tan_deg}        ; set Rotation
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @CanDo415
        @CanDo415
        You have to indent the lines you want to be part of the conditional statement, thats a place to start at least.
        CanDo415undefined 1 Reply Last reply Reply Quote 0
        • CanDo415undefined
          CanDo415 @Exerqtor
          @Exerqtor
          like:
          end if
          If var.y_2<var.y_3
          end if
          Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @CanDo415
            @CanDo415
            No like:
            if var.y_2 > var.y_3																; workpiece Zero coordinates
              set var.x_5 = var.x_4 + (COS(ARCTAN(var.m_1)) + COS(ARCTAN(var.m_2))) * var.d_probe / 2
              set var.y_5 = var.y_4 + (SIN(ARCTAN(var.m_1)) + SIN(ARCTAN(var.m_2))) * var.d_probe / 2
            if var.y_2 < var.y_3
              set var.x_5 = var.x_4 + (COS(ARCTAN(var.m_1)) - COS(ARCTAN(var.m_2))) * var.d_probe / 2
              set var.y_5 = var.y_4 + (SIN(ARCTAN(var.m_1)) - SIN(ARCTAN(var.m_2))) * var.d_probe / 2
            • CanDo415undefined
              CanDo415 @Exerqtor
              @Exerqtor
              i tried this before in another case... everything unter the 2nd if wasnt done if the if doesn't match.
              the problem of the missing end if
              Exerqtorundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @CanDo415
                @CanDo415
                Then you simply must have done something wrong in the other case you're mentioning.
                As reference to conditional construct have look at this.
                  jay_s_uk @CanDo415
                  @CanDo415 as @Exerqtor said, there's no end if.
                  Things have to be indented to be part of the if
                    dc42 administrators @CanDo415
                    @CanDo415 you also need to replace SIN by sin, COS by cos, ARCTAN by atan etc. See https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#functions.
                    CanDo415undefined 1 Reply Last reply Reply Quote 1
                    • CanDo415undefined
                      CanDo415 @dc42
                      thanks so far.
                      Error promt is:
                      M292 S3
                      Error: Bad command: If (var.y_2) >= (var.y_3)
                      Error: in file macro line 179 column 8: meta command: expected "'"
                      Makro:
                      G68 A0 B0 R0
                      var y_1 = 0
                      var x_1 = 0
                      var x_2 = 0
                      var x_3 = 0
                      var x_4 = 0
                      var x_5 = 0
                      var delta_x = 0
                      var y_2 = 0
                      var y_3 = 0
                      var y_4 = 0
                      var y_5 = 0
                      var delta_y = 0
                      var z0 = 0
                      var d_probe = 0
                      var z_probe = 0
                      var m_1 = 0
                      var m_2 = 0
                      var m_1_rads = 0
                      var m_1_deg = 0
                      var buff1 = 0
                      var buff2 = 0
                      var buff3 = 0
                      var speed = 1500
                      M291 P"probe Diameter" R"enter diameter of probe" S5 							; Pop up box asking for operator input diameter of
                      set var.d_probe = input															; set the diameter of the probe
                      M291 P"probe size in z" R"enter z-size of probe" S5 							; Pop up box asking for operator input diameter of
                      set var.z_probe = input															; set the size of the probe in z-direction (mostly same as diameter, for plate probes 0)
                      M558 F{var.speed/5}																; Set the initial movement speed
                      G38.2 Z-10 P0 K0																; Probe the material on top
                      set var.z0 = move.axes[2].machinePosition										; Record the stop position z_first_measurement
                      G1 Z{move.axes[2].machinePosition+5}											; Lift probe 5mm
                      G1 X{move.axes[0].machinePosition-20} Y{move.axes[1].machinePosition+5}			; Move 20mm to the left of the initial point and 5mm deeper into the material direction
                      G1 Z{var.z0 - 1 - var.z_probe / 2}												; Move to probe depth
                      M558 F{var.speed}																; Set the initial movement speed
                      G38.2 X1000 P0 K0																; Probe the material as a first pass
                      set var.y_1 = move.axes[1].machinePosition										; Record the stop position y_first_measurement
                      set var.x_1 = move.axes[0].machinePosition										; Record the stop position x_first_measurement
                      G1 Z{var.z0+5}																	; Move 5mm above material
                      G1 X{move.axes[0].machinePosition+15} Y{move.axes[1].machinePosition-20}		; Move to point 2
                      G38.2 Y1000 P0 K0																; Probe the material as a first pass
                      set var.y_2 = move.axes[1].machinePosition										; Record the stop position y_second_measurement
                      set var.x_2 = move.axes[0].machinePosition										; Record the stop position x_second_measurement
                      G1 Y{move.axes[1].machinePosition-20}											; Move 10mm away from the material
                      G1 X{move.axes[0].machinePosition+50}											; Move 50mm along the workpiece in X
                      set var.y_3 = move.axes[1].machinePosition										; Record the stop position y_third_measurement
                      set var.x_3 = move.axes[0].machinePosition										; Record the stop position x_third_measurement
                      ;calculation
                      set var.delta_y = {var.y_3-var.y_2}
                      set var.delta_x = {var.x_3-var.x_2}
                      set var.m_1 = {var.delta_y/var.delta_x}											; m of the staight P2-P3
                      set var.m_2 = {(-var.delta_x)/var.delta_y}										; m of perpendicilar to straight P2-P3
                      set var.m_1_rads = atan(var.m_1)												; workpiece rotation in rad
                      set var.m_1_deg = degrees(var.m_1_rads)											; workpiece rotation in degrees
                      ;calc the corner of workpiece
                      ;set var.x_4 = {((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))}
                      ;set var.y_4 = {(-(var.x_3-var.x_2)/(var.y_3-var.y_2))<>*((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))<>/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))+(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)}
                      set var.buff1 = {var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1}
                      set var.buff2 = {var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)}
                      set var.buff3 = {((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))}
                      set var.x_4 = {(var.buff1-var.buff2)/var.buff3}
                      set var.buff1 = {(-(var.x_3-var.x_2)/(var.y_3-var.y_2))}
                      set var.buff2 = {((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))}
                      set var.buff3 = {(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))+(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)}
                      set var.y_4 = {var.buff1*var.buff2/var.buff3}
                      If (var.y_2) >= (var.y_3)																; workpiece Zero coordinates
                      set var.x_5 = {var.x_4+(cos(atan(var.m_1))+cos(atan(var.m_2)))*var.d_probe/2}
                      set var.y_5 = {var.y_4+(sin(atan(var.m_1))+sin(atan(var.m_2)))*var.d_probe/2}
                      echo 'X= '{var.x_5}', Y= '{var.y_5}
                      If (var.y_2) < (var.y_3)
                      set var.x_5 = {var.x_4+(cos(atan(var.m_1))-cos(atan(var.m_2)))*var.d_probe/2}
                      set var.y_5 = {var.y_4+(sin(atan(var.m_1))-sin(atan(var.m_2)))*var.d_probe/2}
                      ;echo X= {var.x_5}, Y= {var.y_5}
                      ;move above workpiece zero and set tool x&y to 0
                      G1 Z{var.z0 + 5}																; Move above workpiece
                      G1 X{var.x_5} Y{var.y_5}														; go to Zero
                      G10 X0 Y0																		; set x&y to Zero
                      G68 A0 B0 R{-var.m_1_deg}														; set Rotation
                      X seems to be working, on a psitive angle.
                      Y is getting some wrong outputs
                        @CanDo415 replace all If by if.
                        • CanDo415undefined
                          CanDo415 @dc42
                          i don't know why. sometimes it works. sometimes it fails.
                          getting Error: line 89 column 20: meta command: unknown value 'atan'
                          i have no idea.
                          the calculation seems to be correct. but using G10 moves the tool right down to Y=0
                          G68 A0 B0 R0
                          var y_1 = 0
                          var x_1 = 0
                          var x_2 = 0
                          var x_3 = 0
                          var x_4 = 0
                          var x_5 = 0
                          var delta_x = 0
                          var y_2 = 0
                          var y_3 = 0
                          var y_4 = 0
                          var y_5 = 0
                          var delta_y = 0
                          var z0 = 0
                          var d_probe = 0
                          var z_probe = 0
                          var m_1 = 0
                          var m_2 = 0
                          var m_1_rads = 0
                          var m_1_deg = 0
                          var m_2_rads = 0
                          var m_2_deg = 0
                          var buff1 = 0
                          var buff2 = 0
                          var buff3 = 0
                          var speed = 1500
                          ;calculation
                          set var.m_2 = {-(var.delta_x/var.delta_y)}										; m of perpendicilar to straight P2-P3
                          set var.m_2_rads = atan(var.m_2)												; workpiece rotation in rad
                          set var.m_2_deg = degrees(var.m_2_rads)											; workpiece rotation in degrees
                          var a = 0
                          set var.a= {var.y_3-var.y_2}
                          ;if var.a >= 0														            	; workpiece Zero coordinates
                          set var.x_5 = {var.x_4+(cos(var.m_1_deg)+cos(var.m_2_deg))*var.d_probe/2}
                          set var.y_5 = {var.y_4+(sin(var.m_1_deg)+sin(var.m_2_deg))*var.d_probe/2}
                          ;echo 'X= '{var.x_5}', Y= '{var.y_5}
                          ;if var.a < 0
                          ;set var.x_5 = {var.x_4+(cos(atan(var.m_1))-cos(atan(var.m_2)))*var.d_probe/2}
                          ;set var.y_5 = {var.y_4+(sin(atan(var.m_1))-sin(atan(var.m_2)))*var.d_probe/2}
                          G1 X{var.x_5}
                          G1 Y{var.y_5}														            ; go to Zero
                          ;G10 L20 X0 Y0																	; set x&y to Zero
                          ;G68 A0 B0 R{-var.m_1_deg}														; set Rotation
                          infiniteloopundefined 1 Reply Last reply Reply Quote 0
                          • infiniteloopundefined
                            infiniteloop @CanDo415
                            @CanDo415
                            @Exerqtor already pointed you at the proper doc - better read it completely. In the section Expressions, it says:
                            … when RepRapFirmware is running in CNC mode, any use of ( ) to enclose a subexpression or function parameter list must be within an expression enclosed in { }
                            Within your macro, you apply the curly braces inconsistently, Instead of
                            set var.m_1_rads = atan(var.m_1) ;  may not work in CNC mode, (var.m_1) is regarded as a comment
                            write
                            set var.m_1_rads = {atan(var.m_1)}
                            Same is true for other function calls like degrees().
                            In general, if writing macros, you should study the GCode meta commands completely and in-depth.
                            • CanDo415undefined
                              CanDo415 @infiniteloop
                              thank you all. finally it works as inteded.
                              G68 A0 B0 R0
                              G10 L20 X{move.axes[0].machinePosition} Y{move.axes[1].machinePosition} Z{move.axes[2].machinePosition}
                              var y_1 = 0
                              var x_1 = 0
                              var x_2 = 0
                              var x_3 = 0
                              var x_4 = 0
                              var x_5 = 0
                              var delta_x = 0
                              var y_2 = 0
                              var y_3 = 0
                              var y_4 = 0
                              var y_5 = 0
                              var delta_y = 0
                              var z0 = 0
                              var d_probe = 0
                              var z_probe = 0
                              var m_1 = 0
                              var m_2 = 0
                              var m_1_rads = 0
                              var m_1_deg = 0
                              var m_2_rads = 0
                              var m_2_deg = 0
                              var buff1 = 0
                              var buff2 = 0
                              var buff3 = 0
                              var buff4 = 0
                              var speed = 1500
                              G1 X{move.axes[0].machinePosition-20-var.d_probe/2} Y{move.axes[1].machinePosition+5}           	; Move 20mm to the left of the initial point and 5mm deeper into the material direction
                              G1 X{move.axes[0].machinePosition+15+var.d_probe/2} Y{move.axes[1].machinePosition-20-var.d_probe/2}	; Move to point 2
                              ;calculation
                              set var.m_1_rads = {atan(var.m_1)}								    	            			; workpiece rotation in rad
                              set var.m_1_deg = {degrees(var.m_1_rads)}	            										; workpiece rotation in degrees
                              set var.m_2_rads = {atan(var.m_2)}						            			    			; workpiece rotation in rad
                              set var.m_2_deg = {degrees(var.m_2_rads)}							            				; workpiece rotation in degrees
                              set var.buff3 = {(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))}
                              set var.buff4 = {(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)}
                              set var.y_4 = {var.buff1*var.buff2/var.buff3+var.buff4}
                              var a = 0
                              if var.a < 0														            	            ; workpiece Zero coordinates
                              if var.a > 0
                              if var.a =0
                                  set var.x_5 = {var.x_1+var.d_probe/2}
                                  set var.y_5 = {var.y_2+var.d_probe/2}
                              echo "ZERO X = ", var.x_5," ; Y = ", var.y_5
                              M400
                                @CanDo415 the reason is that standard CNC GCode uses ( and ) to enclose comments, which is an unfortunate choice. In order to be compatible with this, RRF does the same when in CNC mode unless the ( ) are themselves inside { }.
