    Feature Request - workpiece angle compensation CNC
    Firmware wishlist
    11
    54
    2.9k
    • CanDo415undefined
      CanDo415 @droftarts
      @droftarts
      jay corrected it already.
      the problem shifted to the degrees command
      • OwenDundefined
        OwenD @jay_s_uk
        @jay_s_uk said in Feature Request - workpiece angle compensation CNC:
        @CanDo415 i've made another change but I don't think its going to fix the issue.
        I don't know why "degrees" throws an error though as its a built in command
        degrees() is a function
        You've used curly braces instead of parentheses
        set var.y_x_tan_deg=degrees{var.y_x_tan_rads}
        try
        set var.y_x_tan_deg=degrees(var.y_x_tan_rads)
        jay_s_ukundefined CanDo415undefined 2 Replies Last reply Reply Quote 2
          jay_s_uk @OwenD
          @OwenD i knew it would be something about the way its been formatted
          updated the original again
          • CanDo415undefined
            CanDo415 @OwenD
            @OwenD
            thank you for showing up the problem
            CanDo415undefined 1 Reply Last reply Reply Quote 0
            • CanDo415undefined
              CanDo415 @CanDo415
              G68 A0 B0 R{-var.y_x_tan_rads}
              the "-" seems important. otherwise the system gets turned the wrong way round
              • CanDo415undefined
                CanDo415 @CanDo415
                @jay_s_uk
                i modified it quite a bit. some points are still not ready.
                I'm not shure how to ent the if passage.
                end if seems not to work
                var y_1 = 0
                var x_1 = 0
                var x_2 = 0
                var x_3 = 0
                var x_4 = 0
                var x_5 = 0
                var delta_x = 0
                var y_2 = 0
                var y_3 = 0
                var y_4 = 0
                var y_5 = 0
                var delta_y = 0
                var z0 = 0
                var d_probe = 0
                var m_1 = 0
                var m_2 = 0
                var m_1_tan_rads = 0
                var m_1_tan_deg = 0
                M291 P"position probe over front left corner of workpiece" S2 X1 Y1 Z1	; Pop up box asking for operator input
                M558 F300																		; Set the initial probing speed
                G38.2 Z-60 P0 K0																; Probe the material as a first pass
                M558 F50																		; Set the final probing speed
                G38.4 Z50 P0 K0        ; Move away from workpiece in Z
                M400																			        ; Make sure all movement is complete
                set var.z0=move.axes[2].machinePosition	                			    		                ; Record the stop position y_first_measurement
                M400																			        ; Make sure all data recording is complete
                G1 Z{move.axes[2].machinePosition+5}										; Move along the workpiece in X
                G1 X{move.axes[0].machinePosition-20}										; Move 5mm away from the material
                G1 Y{move.axes[1].machinePosition+5}										; Move 5mm away from the material
                G1 Z{move.axes[2].machinePosition-3}											; Move along the workpiece in X
                M558 F1000																		; Set the initial probing speed
                G38.2 X100 P0 K0																; Probe the material as a first pass
                G38.4 X-10 P0 K0        ; Move away from workpiece in X
                set var.y_1=move.axes[1].machinePosition							    		        ; Record the stop position y_first_measurement
                set var.x_1=move.axes[0].machinePosition							    		        ; Record the stop position x_first_measurement
                G1 X{move.axes[0].machinePosition-5}											; Move 5mm away from the material
                G1 Z{move.axes[2].machinePosition+10}										; Move along the workpiece in X
                G1 X{move.axes[0].machinePosition+15}										; Move 5mm away from the material
                G1 Y{move.axes[1].machinePosition-20}										; Move 5mm away from the material
                G1 Z{move.axes[2].machinePosition}	    										; Move along the workpiece in X
                G38.2 Y100 P0 K0																; Probe the material as a first pass
                G38.4 Y-10 P0 K0															        ; Probe the material again
                set var.y_2=move.axes[1].machinePosition								    	        ; Record the stop position y_first_measurement
                set var.x_2=move.axes[0].machinePosition					    				        ; Record the stop position x_first_measurement
                G1 Y{move.axes[1].machinePosition-50}										; Move 5mm away from the material
                G1 X{move.axes[0].machinePosition+50}										; Move along the workpiece in X
                set var.y_3=move.axes[1].machinePosition								    	        ; Record the stop position y_second_measurement
                set var.x_3=move.axes[0].machinePosition								    	        ; Record the stop position x_second_measurement
                M291 P"Probe Diameter" R"enter diameter of probe" S5 L0 H10			; Pop up box asking for operator input diameter of
                set var.d_probe=input															; set the diameter of the probe
                ;calculation
                set var.delta_y={var.y_3-var.y_2}
                set var.delta_x={var.x_3-var.x_2}
                set var.m_1={var.delta_y/var.delta_x}											; m of the staight P2-P3
                set var.m_2={(-var.delta_x)/var.delta_y}										        ; m of perpendicilar to straight P2-P3
                set var.m_1_tan_rads=atan(var.m_1)
                set var.m_1_tan_deg=degrees(var.m_1_tan_rads)
                ;calc the corner of workpeace
                set var.x_4=((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))
                set var.y_4=(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))+(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)
                If var.y_2>var.y_3																; workpiece Zero coordinates
                set var.x_5=var.x_4+(COS(ARCTAN(var.m_1))+COS(ARCTAN(var.m_2)))*var.d_probe/2
                set var.y_5=var.y_4+(SIN(ARCTAN(var.m_1))+SIN(ARCTAN(var.m_2)))*var.d_probe/2
                If var.y_2<var.y_3
                set var.x_5=var.x_4+(COS(ARCTAN(var.m_1))-COS(ARCTAN(var.m_2)))*var.d_probe/2
                set var.y_5=var.y_4+(SIN(ARCTAN(var.m_1))-SIN(ARCTAN(var.m_2)))*var.d_probe/2
                ;move over workpiece zero and set tool x&y to 0
                G1 Y{move.axes[1].machinePosition-1}											        ; Move 1mm away from the material
                G1 Z{move.axes[2].machinePosition+10}											; Move above workpiece
                ;G68 A0 B0 R{-var.m_1_tan_deg}        ; set Rotation
                Exerqtorundefined 1 Reply Last reply Reply Quote 0
                • Exerqtorundefined
                  Exerqtor @CanDo415
                  @CanDo415
                  You have to indent the lines you want to be part of the conditional statement, thats a place to start at least.
                  • CanDo415undefined
                    CanDo415 @Exerqtor
                    @Exerqtor
                    like:
                    end if
                    If var.y_2<var.y_3
                    end if
                    Exerqtorundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    • Exerqtorundefined
                      Exerqtor @CanDo415
                      @CanDo415
                      No like:
                      if var.y_2 > var.y_3																; workpiece Zero coordinates
                        set var.x_5 = var.x_4 + (COS(ARCTAN(var.m_1)) + COS(ARCTAN(var.m_2))) * var.d_probe / 2
                        set var.y_5 = var.y_4 + (SIN(ARCTAN(var.m_1)) + SIN(ARCTAN(var.m_2))) * var.d_probe / 2
                      if var.y_2 < var.y_3
                        set var.x_5 = var.x_4 + (COS(ARCTAN(var.m_1)) - COS(ARCTAN(var.m_2))) * var.d_probe / 2
                        set var.y_5 = var.y_4 + (SIN(ARCTAN(var.m_1)) - SIN(ARCTAN(var.m_2))) * var.d_probe / 2
                      • CanDo415undefined
                        CanDo415 @Exerqtor
                        @Exerqtor
                        i tried this before in another case... everything unter the 2nd if wasnt done if the if doesn't match.
                        the problem of the missing end if
                        Exerqtorundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                        • Exerqtorundefined
                          Exerqtor @CanDo415
                          @CanDo415
                          Then you simply must have done something wrong in the other case you're mentioning.
                          As reference to conditional construct have look at this.
                            jay_s_uk @CanDo415
                            @CanDo415 as @Exerqtor said, there's no end if.
                            Things have to be indented to be part of the if
                              dc42 administrators @CanDo415
                              @CanDo415 you also need to replace SIN by sin, COS by cos, ARCTAN by atan etc. See https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#functions.
                              CanDo415undefined 1 Reply Last reply Reply Quote 1
                              • CanDo415undefined
                                CanDo415 @dc42
                                thanks so far.
                                Error promt is:
                                M292 S3
                                Error: Bad command: If (var.y_2) >= (var.y_3)
                                Error: in file macro line 179 column 8: meta command: expected "'"
                                Makro:
                                G68 A0 B0 R0
                                var y_1 = 0
                                var x_1 = 0
                                var x_2 = 0
                                var x_3 = 0
                                var x_4 = 0
                                var x_5 = 0
                                var delta_x = 0
                                var y_2 = 0
                                var y_3 = 0
                                var y_4 = 0
                                var y_5 = 0
                                var delta_y = 0
                                var z0 = 0
                                var d_probe = 0
                                var z_probe = 0
                                var m_1 = 0
                                var m_2 = 0
                                var m_1_rads = 0
                                var m_1_deg = 0
                                var buff1 = 0
                                var buff2 = 0
                                var buff3 = 0
                                var speed = 1500
                                M291 P"probe Diameter" R"enter diameter of probe" S5 							; Pop up box asking for operator input diameter of
                                set var.d_probe = input															; set the diameter of the probe
                                M291 P"probe size in z" R"enter z-size of probe" S5 							; Pop up box asking for operator input diameter of
                                set var.z_probe = input															; set the size of the probe in z-direction (mostly same as diameter, for plate probes 0)
                                M558 F{var.speed/5}																; Set the initial movement speed
                                G38.2 Z-10 P0 K0																; Probe the material on top
                                set var.z0 = move.axes[2].machinePosition										; Record the stop position z_first_measurement
                                G1 Z{move.axes[2].machinePosition+5}											; Lift probe 5mm
                                G1 X{move.axes[0].machinePosition-20} Y{move.axes[1].machinePosition+5}			; Move 20mm to the left of the initial point and 5mm deeper into the material direction
                                G1 Z{var.z0 - 1 - var.z_probe / 2}												; Move to probe depth
                                M558 F{var.speed}																; Set the initial movement speed
                                G38.2 X1000 P0 K0																; Probe the material as a first pass
                                set var.y_1 = move.axes[1].machinePosition										; Record the stop position y_first_measurement
                                set var.x_1 = move.axes[0].machinePosition										; Record the stop position x_first_measurement
                                G1 Z{var.z0+5}																	; Move 5mm above material
                                G1 X{move.axes[0].machinePosition+15} Y{move.axes[1].machinePosition-20}		; Move to point 2
                                G38.2 Y1000 P0 K0																; Probe the material as a first pass
                                set var.y_2 = move.axes[1].machinePosition										; Record the stop position y_second_measurement
                                set var.x_2 = move.axes[0].machinePosition										; Record the stop position x_second_measurement
                                G1 Y{move.axes[1].machinePosition-20}											; Move 10mm away from the material
                                G1 X{move.axes[0].machinePosition+50}											; Move 50mm along the workpiece in X
                                set var.y_3 = move.axes[1].machinePosition										; Record the stop position y_third_measurement
                                set var.x_3 = move.axes[0].machinePosition										; Record the stop position x_third_measurement
                                ;calculation
                                set var.delta_y = {var.y_3-var.y_2}
                                set var.delta_x = {var.x_3-var.x_2}
                                set var.m_1 = {var.delta_y/var.delta_x}											; m of the staight P2-P3
                                set var.m_2 = {(-var.delta_x)/var.delta_y}										; m of perpendicilar to straight P2-P3
                                set var.m_1_rads = atan(var.m_1)												; workpiece rotation in rad
                                set var.m_1_deg = degrees(var.m_1_rads)											; workpiece rotation in degrees
                                ;calc the corner of workpiece
                                ;set var.x_4 = {((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))}
                                ;set var.y_4 = {(-(var.x_3-var.x_2)/(var.y_3-var.y_2))<>*((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))<>/(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))+(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)}
                                set var.buff1 = {var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1}
                                set var.buff2 = {var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)}
                                set var.buff3 = {((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))}
                                set var.x_4 = {(var.buff1-var.buff2)/var.buff3}
                                set var.buff1 = {(-(var.x_3-var.x_2)/(var.y_3-var.y_2))}
                                set var.buff2 = {((var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)-(var.y_2-((var.y_3-var.y_2)/(var.x_3-var.x_2)*var.x_2)))}
                                set var.buff3 = {(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))+(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)}
                                set var.y_4 = {var.buff1*var.buff2/var.buff3}
                                If (var.y_2) >= (var.y_3)																; workpiece Zero coordinates
                                set var.x_5 = {var.x_4+(cos(atan(var.m_1))+cos(atan(var.m_2)))*var.d_probe/2}
                                set var.y_5 = {var.y_4+(sin(atan(var.m_1))+sin(atan(var.m_2)))*var.d_probe/2}
                                echo 'X= '{var.x_5}', Y= '{var.y_5}
                                If (var.y_2) < (var.y_3)
                                set var.x_5 = {var.x_4+(cos(atan(var.m_1))-cos(atan(var.m_2)))*var.d_probe/2}
                                set var.y_5 = {var.y_4+(sin(atan(var.m_1))-sin(atan(var.m_2)))*var.d_probe/2}
                                ;echo X= {var.x_5}, Y= {var.y_5}
                                ;move above workpiece zero and set tool x&y to 0
                                G1 Z{var.z0 + 5}																; Move above workpiece
                                G1 X{var.x_5} Y{var.y_5}														; go to Zero
                                G10 X0 Y0																		; set x&y to Zero
                                G68 A0 B0 R{-var.m_1_deg}														; set Rotation
                                X seems to be working, on a psitive angle.
                                Y is getting some wrong outputs
                                  @CanDo415 replace all If by if.
                                  • CanDo415undefined
                                    CanDo415 @dc42
                                    i don't know why. sometimes it works. sometimes it fails.
                                    getting Error: line 89 column 20: meta command: unknown value 'atan'
                                    i have no idea.
                                    the calculation seems to be correct. but using G10 moves the tool right down to Y=0
                                    G68 A0 B0 R0
                                    var y_1 = 0
                                    var x_1 = 0
                                    var x_2 = 0
                                    var x_3 = 0
                                    var x_4 = 0
                                    var x_5 = 0
                                    var delta_x = 0
                                    var y_2 = 0
                                    var y_3 = 0
                                    var y_4 = 0
                                    var y_5 = 0
                                    var delta_y = 0
                                    var z0 = 0
                                    var d_probe = 0
                                    var z_probe = 0
                                    var m_1 = 0
                                    var m_2 = 0
                                    var m_1_rads = 0
                                    var m_1_deg = 0
                                    var m_2_rads = 0
                                    var m_2_deg = 0
                                    var buff1 = 0
                                    var buff2 = 0
                                    var buff3 = 0
                                    var speed = 1500
                                    ;calculation
                                    set var.m_2 = {-(var.delta_x/var.delta_y)}										; m of perpendicilar to straight P2-P3
                                    set var.m_2_rads = atan(var.m_2)												; workpiece rotation in rad
                                    set var.m_2_deg = degrees(var.m_2_rads)											; workpiece rotation in degrees
                                    var a = 0
                                    set var.a= {var.y_3-var.y_2}
                                    ;if var.a >= 0														            	; workpiece Zero coordinates
                                    set var.x_5 = {var.x_4+(cos(var.m_1_deg)+cos(var.m_2_deg))*var.d_probe/2}
                                    set var.y_5 = {var.y_4+(sin(var.m_1_deg)+sin(var.m_2_deg))*var.d_probe/2}
                                    ;echo 'X= '{var.x_5}', Y= '{var.y_5}
                                    ;if var.a < 0
                                    ;set var.x_5 = {var.x_4+(cos(atan(var.m_1))-cos(atan(var.m_2)))*var.d_probe/2}
                                    ;set var.y_5 = {var.y_4+(sin(atan(var.m_1))-sin(atan(var.m_2)))*var.d_probe/2}
                                    G1 X{var.x_5}
                                    G1 Y{var.y_5}														            ; go to Zero
                                    ;G10 L20 X0 Y0																	; set x&y to Zero
                                    ;G68 A0 B0 R{-var.m_1_deg}														; set Rotation
                                    • infiniteloopundefined
                                      infiniteloop @CanDo415
                                      @CanDo415
                                      @Exerqtor already pointed you at the proper doc - better read it completely. In the section Expressions, it says:
                                      … when RepRapFirmware is running in CNC mode, any use of ( ) to enclose a subexpression or function parameter list must be within an expression enclosed in { }
                                      Within your macro, you apply the curly braces inconsistently, Instead of
                                      set var.m_1_rads = atan(var.m_1) ;  may not work in CNC mode, (var.m_1) is regarded as a comment
                                      write
                                      set var.m_1_rads = {atan(var.m_1)}
                                      Same is true for other function calls like degrees().
                                      In general, if writing macros, you should study the GCode meta commands completely and in-depth.
                                      • CanDo415undefined
                                        CanDo415 @infiniteloop
                                        thank you all. finally it works as inteded.
                                        G68 A0 B0 R0
                                        G10 L20 X{move.axes[0].machinePosition} Y{move.axes[1].machinePosition} Z{move.axes[2].machinePosition}
                                        var y_1 = 0
                                        var x_1 = 0
                                        var x_2 = 0
                                        var x_3 = 0
                                        var x_4 = 0
                                        var x_5 = 0
                                        var delta_x = 0
                                        var y_2 = 0
                                        var y_3 = 0
                                        var y_4 = 0
                                        var y_5 = 0
                                        var delta_y = 0
                                        var z0 = 0
                                        var d_probe = 0
                                        var z_probe = 0
                                        var m_1 = 0
                                        var m_2 = 0
                                        var m_1_rads = 0
                                        var m_1_deg = 0
                                        var m_2_rads = 0
                                        var m_2_deg = 0
                                        var buff1 = 0
                                        var buff2 = 0
                                        var buff3 = 0
                                        var buff4 = 0
                                        var speed = 1500
                                        G1 X{move.axes[0].machinePosition-20-var.d_probe/2} Y{move.axes[1].machinePosition+5}           	; Move 20mm to the left of the initial point and 5mm deeper into the material direction
                                        G1 X{move.axes[0].machinePosition+15+var.d_probe/2} Y{move.axes[1].machinePosition-20-var.d_probe/2}	; Move to point 2
                                        ;calculation
                                        set var.m_1_rads = {atan(var.m_1)}								    	            			; workpiece rotation in rad
                                        set var.m_1_deg = {degrees(var.m_1_rads)}	            										; workpiece rotation in degrees
                                        set var.m_2_rads = {atan(var.m_2)}						            			    			; workpiece rotation in rad
                                        set var.m_2_deg = {degrees(var.m_2_rads)}							            				; workpiece rotation in degrees
                                        set var.buff3 = {(((var.y_3-var.y_2)/(var.x_3-var.x_2))-(-(var.x_3-var.x_2)/(var.y_3-var.y_2)))}
                                        set var.buff4 = {(var.y_1-(-(var.x_3-var.x_2)/(var.y_3-var.y_2))*var.x_1)}
                                        set var.y_4 = {var.buff1*var.buff2/var.buff3+var.buff4}
                                        var a = 0
                                        if var.a < 0														            	            ; workpiece Zero coordinates
                                        if var.a > 0
                                        if var.a =0
                                            set var.x_5 = {var.x_1+var.d_probe/2}
                                            set var.y_5 = {var.y_2+var.d_probe/2}
                                        echo "ZERO X = ", var.x_5," ; Y = ", var.y_5
                                        M400
                                          @CanDo415 the reason is that standard CNC GCode uses ( and ) to enclose comments, which is an unfortunate choice. In order to be compatible with this, RRF does the same when in CNC mode unless the ( ) are themselves inside { }.
