    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.1k
    • jschallundefined
      jschall @Phaedrux
      @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
      Is your DWC version also at 3.1.1?
      Post the result of M122?
      https://gist.github.com/jschall/49fc6d654a912f81ac897d64064325a4
        Check the General > Settings tab in DWC to see what version it's at.
        M122 looks ok.
        • jschallundefined
          jschall
          Duet Web Control 3.1.1
          • jschallundefined
            jschall @bot
            @bot I tried to build PrusaSlicer before and gave up because of ridiculously huge numbers of dependencies on cutting edge versions of everything.
            Edgars Batnaundefined 1 Reply Last reply Reply Quote 0
            • jschallundefined
              jschall @bot
              @bot do you think you could build the linux .appimage for that and send it to me?
              botundefined 1 Reply Last reply Reply Quote 0
              • botundefined
                bot @jschall
                @jschall I do not have access to a linux machine, and have never built an app image... I've only built this on windows.
                However, I found the SuperSlicer (fork of PS) build instructions fantastic.
                https://github.com/supermerill/SuperSlicer/blob/master/doc/How to build - Linux et al.md
                Give that a shot.
                *not actually a robot
                jschallundefined 1 Reply Last reply Reply Quote 0
                • jschallundefined
                  jschall @bot
                  @bot said in RRF 2.03 pressure advance causes 20% overextrusion:
                  That's just identical to the PrusaSlicer build instructions.
                  Hmm, even a windows build would be fine. Can run it under a VM.
                  • botundefined
                    bot @jschall
                    @jschall here's the windows build I run day-to-day:
                    https://github.com/n8bot/PrusaSlicer/releases/tag/v2.3.0-alpha0-n8pmis
                    It's almost the latest PS master branch, but the latest changes they made to the master branch aren't useful so those aren't included yet. (waiting for the seam painter to actually work, not just paint meaninglessly)
                    • jschallundefined
                      jschall @bot
                      @bot What's the difference between that and the n8_precision_minus_infill_support branch?
                      • botundefined
                        bot @jschall
                        That release is the n8_precision_minus_infill_support branch.
                        I copied and pasted the description from a previous release hastily, so it might have said the wrong thing.
                        The previous releases work fine, too, but this one enables better support placement (PS ignores some "thin" support regions which prevents some support from appearing) and also prevents the solid infill from "auto-adjusting" the width by ~1 micron, which was annoying in some cases but not important to "fix."
                        There are other releases there, too.
                        The two main things I think you'll like are the resolution change, and the decimal precision changes. Fixes extrusion rate problems.
                        Edit: Also, you might need some .DLLs from MS Visual Studio redistributable. Let me know if/which ones you need I can send them too.
                        • jschallundefined
                          jschall @bot
                          @bot ah ok.
                          It is complaining about vcruntime140_1.dll, but I've already installed the visual c++ 2015 redistributable...
                          • botundefined
                            bot @jschall
                            @jschall Yup, that's the one. See this post: https://forum.duet3d.com/post/170901
                            I uploaded the .dll for someone previously, but it's named as .stl. just rename it .dll and put it in the prusaslicer folder or wherever.
                            I also just updated the release to include that .dll. I hope that doesn't break a EULA. oh well.
                            • jschallundefined
                              jschall @bot
                              @bot
                              Got it running. Doesn't work in VirtualBox anyway because no opengl 2.0+ support. So, I ran it in WINE and it works fine. Extrusion amount looks about right.
                              • Edgars Batnaundefined
                                Edgars Batna @jschall
                                @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
                                They have "noob guide" now. It's basically how it should be built, not really for noobs, but for anyone with a little bit of sanity left. I'm wondering why they even bother with having a guide; the steps can be semi-easily compressed into a batch file. Maybe they take pride in memorizing random things...
                                • jschallundefined
                                  jschall
                                  Good to see "Detect thin walls" still sucks just as much as ever.
                                  • botundefined
                                    bot
                                    Haha. Yeah. There's lots of "fun" things going on in PrusaSlicer. There definitely needs to be a huge refactoring, IMO. Many features need to be removed, or re-considered in the context of other newer features.
                                      Phaedrux Moderator @jschall
                                      Still better than Cura. 😀
                                      jschallundefined 1 Reply Last reply Reply Quote 1
                                      • jschallundefined
                                        jschall @Phaedrux
                                        @Phaedrux Really? Cura seems to do way way better than PrusaSlicer when slicing things with thin walls. Also it has support for coasting which is super important on my ender3 v2s that don't frigging work with linear advance...
                                        I just hate Cura's interface. Hard to be worse.
                                        Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                                        • oliofundefined
                                          oliof
                                          Superslicer has something like coasting iirc
                                            @jschall I find Cura falls apart faster than super Slicer on thin walls. In Cura you're forced to use 2 walls. The master build of Cura has the option of trying to replace one of those wall passes with a travel move, but it rarely seems to work well. At least the gap fill in Slic3r has a lot more leeway with regards to wall thickness. It's true that on the really thin side the walls just don't get extruded at all, but it seems to be a lot more forgiving. Cura will print the thin walls but it's usually well over extruded.
