    Bed mesh compensation not applied to all the tools
    1.4k
    • duetloverundefined
      duetlover
      T-1 and ALL G29 commented => same results... 😞
      If it could help, here is the part of gcode file when T3 is selected for the first time :
      G1 X199.790 Y94.848 E0.0216
      G1 X197.752 Y92.810 E0.1258
      G1 X198.247 Y92.810 E0.0216
      G1 X199.790 Y94.353 E0.0952
      G1 X199.790 Y93.858 E0.0216
      G1 X198.742 Y92.810 E0.0647
      G1 X199.237 Y92.810 E0.0216
      G1 X199.790 Y93.363 E0.0341
      G1 X199.790 Y92.868 E0.0216
      G1 X199.732 Y92.810 E0.0036
      G1 E-4.0000 F4200
      ; layer 7, Z = 2.167
      T3
      G91
      G1 Z5 F600
      G90
      G1 X200.600 Y107.666
      ; feature outer perimeter
      ; tool H0.250 W0.010
      G1 Z6.667 F120
      G1 X99.205 Y91.805 F120
      G1 Z1.917 F120
      G1 X200.795 Y91.805 E0.1056 F300
      G1 X200.795 Y108.195 E0.0170
      G1 X99.205 Y108.195 E0.1056
      G1 X99.205 Y91.805 E0.0170
      When T2 is selected again after T3 bed levelling is running again.
      sebkritikelundefined 1 Reply Last reply Reply Quote 0
      • sebkritikelundefined
        sebkritikel @duetlover
        @sylvain said in Bed mesh compensation not applied to all the tools:
        G1 E-4.0000 F4200
        T3
        G91
        G1 Z5 F600
        G90
        G1 Z6.667 F120
        G1 Z1.917 F120
        I do not know, I'm sorry. It looks OK to me.
        Just conjecture, but G10 and the taper command couldn't possibly be causing this right? I see no reason for that to be the case...
        G10 P3 X-0.5	Y36.7	Z-35.26				; T3
        I recognize Z-35.26 is necessary.
        @sylvain could you try commenting out M376 H15?
        Large(ish?) IDEX - 6HC, 1HCL
        Stratasys Dimension 1200es to 6HC Conversion
          Phaedrux Moderator @sebkritikel
          @sebkritikel said in Bed mesh compensation not applied to all the tools:
          Worth a shot.
          Also, are you sure you've got G29 S1 enabled somewhere else now? Should be in the slicer start gcode or start.g at least.
            duetlover
            Commenting M376 solved the issue !
            Thanks !
              Thanks !
              Very interesting! @Phaedrux if this is truly the cause, I wouldn't say this is expected behavior correct? Expected behavior would be G10 tool offsets having no impacts on mesh taper?
                @sebkritikel I'll check with DC42 as I really have no idea.
                sebkritikelundefined 1 Reply Last reply Reply Quote 1
                  sebkritikel @Phaedrux
                  @Phaedrux said in Bed mesh compensation not applied to all the tools:
                  For what its worth, I just tested it on my machine and can confirm G10 Z offsets will interact with with taper values set via M376, similar to what slyvain is seeing.
                  Duet2 Wifi+Duex5
                  3.2-beta2 (2020-10-05b2)
                  Set M376 H15
                  With T0, with no offsets in G10, moved over built plate at Z=6mm. Could see ballscrews moving for compensation
                  Put an artificial offset on T1 (IDEX) of G10 P1 Y.22 U.00 5 Z-20
                  Selected T1, bed moved down to account for Z-20 offset. Still read 6mm.
                  Moved T1 over build plate - no ballscrew/stepper movement for bed compensation.
                  Homed all axes, reset T1 offsets to G10 P1 Y.22 U.00 5 Z.3
                  Moved T1 over build plate (at Z=6mm), could see ballscrews/stepper moving for compensation.
                    duetlover
                    Happy to have contribute to find a bug 😉
                      sebkritikel @sebkritikel
                      Duet2 Wifi+Duex5
                      Set M376 H15
                      @dc42 this comment should summarize the thread, while tested on an IDEX machine, should be easy to verify on a toolchanger.
                      • dcw259undefined
                        dcw259
                        I've had the same problem with mesh bed compensation and tapering.
                        Tool offsets were around 6.5mm for T0 and T1 and 3mm for T2 and T3
                        With M376 H5 (taper off until 5mm) I barely noticed any z adjustments on T2 and T3 and absolutely none on the first two tools.
                        To confirm, I tried M376 H15 and can see z moving cleanly on all tools.
                        As it seems, tools offsets is not a part of the calculation behind M376
                        Hardware: Duet3 MB6HC + 2x Duet 3 EXP3HC
                        Firmware: MB RRF3.1.1 + EXP RRF3.1.0
                          @sylvain @sebkritikel @dcw259, I confirm that mesh compensation taper does not work properly when the tool has a Z offset.
                          I can squeeze a fix into RRF 3.2 stable, but the fix needs to be tested first. Are any of you running RRF 3.2RC2 and would be open to running an internal build that includes a proposed fix?
                            sebkritikel @dc42
                            @dc42 said in Bed mesh compensation not applied to all the tools:
                            I am currently running 3.2-beta3.2, but I can upgrade through RRF 3.2RC2 and/or upgrade to an internal build to test the fix.
                              @sebkritikel, if you are running 3.2beta3.2 then I recommend you upgrade to 3.2-RC2 anyway.
