    Triangular wave and print area
    1.8k
    • Leblondundefined
      Leblond
      • Leblondundefined
        Leblond
        no improvement
        • Vetiundefined
          Veti
          it seems to be very consistent.
          can you turn the glass 90 degrees?
          Leblondundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD
            Is the X carriage on wheels?
            I'm not familiar with the printer and can't tell from the photos I've seen,
            Almost looks like an eccentric wheel causing the nozzle to rise & fall with each rotation
            • Leblondundefined
              Leblond
              • Leblondundefined
                Leblond
                Yes, the trolley is on rails and has eccentrics
                • peter247undefined
                  peter247 @Leblond
                  @Leblond
                  I've had the same problem once , it was the x axis wheels and stopped the ripple with linear rails , but I guess getting better would have fixed it too.
                  Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                  • Leblondundefined
                    Leblond @Veti
                    @Veti yes I have already tried to rotate it 90 degrees, but no improvement
                    • Leblondundefined
                      Leblond @peter247
                      @peter247 in practice they had?
                        Phaedrux Moderator @Leblond
                        @Leblond said in Triangular wave and print area:
                        I don't think he's talking about eccentric nuts to adjust wheel tension, I think he means the wheel itself may be out of round.
                        Is the spacing between the peaks equivalent to a full rotation of the wheel?
                        Leblondundefined 2 Replies Last reply Reply Quote 0
                        • Leblondundefined
                          Leblond @Phaedrux
                          @Phaedrux ok, but I tried to move it manually without the belt to see if it was free and so it was, do you think the bearings need to be changed?
                            Well the real question is does mesh compensation work to produce a good first layer?
                            Do a test print once with mesh enabled and another with it disabled. You should be able to tell if the mesh is accurate or not.
                            bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                            • Leblondundefined
                              Leblond @Phaedrux
                              @Phaedrux ok I will try in the meantime I disassembled the x axis turned the bearings
                              "just to give it a try while I was waiting for some advice from you" and now I've reassembled it and put it back to making a cold mesh to see if anything has changed, then I'll try to print to see if the mesh works or not, tomorrow I will post the results with and without mesh, for the moment thanks @Phaedrux.
                              • Leblondundefined
                                Leblond @Phaedrux
                                @Phaedrux looking at the graphic mesh and checking the coordinates of X which are spaced by 20mm, in 60mm the wheel should make a full turn, I did a free test: I lowered the probe stem I raised the Z axis until it touches the flat, at this point I moved the X axis by 60mm and about 30mm it raised and then lowered in the remaining 30mm, you know you were right the bearings are gone
                                • Vetiundefined
                                  Veti
                                  have you decided what to do about it?
                                  new bearings or linear rail conversion?
                                  • Leblondundefined
                                    Leblond @Veti
                                    @Veti think about changing bearings? some idea?
                                    Vetiundefined 1 Reply Last reply Reply Quote 0
                                    • Leblondundefined
                                      Leblond @Veti
                                      @Veti converting it would cost me time would i have to create the pieces and have them made
                                      • Vetiundefined
                                        Veti @Leblond
                                        @Leblond
                                        depends on where you live
                                        A good place to start are the original openparts store
                                        https://openbuildspartstore.com/metal-v-wheel-kit/
                                        https://openbuildspartstore.com/ball-bearing-625-2rs-5x16x5/
                                        (check that the size is the same as yours)
                                        alternative these are recommended for the voron 2 printer and are supposed to be high quality
                                        https://www.aliexpress.com/item/32991204773.html
                                        look for high quality bearings ABEC-7 or above ( ABEC-9)
                                        • Leblondundefined
                                          Leblond @Veti
                                          @Veti I live in Italy, ok I look at it thanks
                                          • Vetiundefined
                                            Veti @Leblond
                                            the parts you can print yourself.
                                            eg (there are many others for the troxy)
                                            https://www.thingiverse.com/thing:3855641
                                            the rails would need to be ordered
