    Triangular wave and print area
    1.7k
    • Vetiundefined
      Veti @Leblond
      @Leblond said in Triangular wave and print area:
      1.7 A
      so running them at 75% rounding to nearest 100 is 1300.
      • Leblondundefined
        Leblond
        ok I took them to 1.3 and I'm doing the test again later
        • Leblondundefined
          Leblond
          25/10/2020, 20:56:11 G32 bed probe heights: 0.198 0.195 0.195 0.198 0.195 0.200 0.195 0.200 0.192 0.195, mean 0.196, deviation from mean 0.002
          25/10/2020, 20:55:37 G32 bed probe heights: 0.183 0.180 0.180 0.183 0.183 0.183 0.183 0.180 0.180 0.183, mean 0.181, deviation from mean 0.001
          25/10/2020, 20:55:04 G32 bed probe heights: 0.183 0.178 0.173 0.170 0.178 0.173 0.173 0.178 0.178 0.173, mean 0.175, deviation from mean 0.004
          25/10/2020, 20:54:31 M98 P"0:/macros/Calibrazione a punto singolo/Calibrazione x 10"
          G32 bed probe heights: 0.195 0.192 0.192 0.195 0.192 0.195 0.195 0.195 0.188 0.195, mean 0.194, deviation from mean 0.002
          • Leblondundefined
            Leblond
            I'm retrying cold-meshing the plate to see if we've made any improvements
            • Leblondundefined
              Leblond
              • Leblondundefined
                Leblond
                no improvement
                • Vetiundefined
                  Veti
                  it seems to be very consistent.
                  can you turn the glass 90 degrees?
                  Leblondundefined 1 Reply Last reply Reply Quote 0
                  • OwenDundefined
                    OwenD
                    Is the X carriage on wheels?
                    I'm not familiar with the printer and can't tell from the photos I've seen,
                    Almost looks like an eccentric wheel causing the nozzle to rise & fall with each rotation
                    • Leblondundefined
                      Leblond
                      • Leblondundefined
                        Leblond
                        Yes, the trolley is on rails and has eccentrics
                        • peter247undefined
                          peter247 @Leblond
                          @Leblond
                          I've had the same problem once , it was the x axis wheels and stopped the ripple with linear rails , but I guess getting better would have fixed it too.
                          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                          • Leblondundefined
                            Leblond @Veti
                            @Veti yes I have already tried to rotate it 90 degrees, but no improvement
                            • Leblondundefined
                              Leblond @peter247
                              @peter247 in practice they had?
                                Phaedrux Moderator @Leblond
                                I don't think he's talking about eccentric nuts to adjust wheel tension, I think he means the wheel itself may be out of round.
                                Is the spacing between the peaks equivalent to a full rotation of the wheel?
                                Leblondundefined 2 Replies Last reply Reply Quote 0
                                • Leblondundefined
                                  Leblond @Phaedrux
                                  @Phaedrux ok, but I tried to move it manually without the belt to see if it was free and so it was, do you think the bearings need to be changed?
                                    Well the real question is does mesh compensation work to produce a good first layer?
                                    Do a test print once with mesh enabled and another with it disabled. You should be able to tell if the mesh is accurate or not.
                                    bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                                    • Leblondundefined
                                      Leblond @Phaedrux
                                      @Phaedrux ok I will try in the meantime I disassembled the x axis turned the bearings
                                      "just to give it a try while I was waiting for some advice from you" and now I've reassembled it and put it back to making a cold mesh to see if anything has changed, then I'll try to print to see if the mesh works or not, tomorrow I will post the results with and without mesh, for the moment thanks @Phaedrux.
                                      • Leblondundefined
                                        Leblond @Phaedrux
                                        @Phaedrux looking at the graphic mesh and checking the coordinates of X which are spaced by 20mm, in 60mm the wheel should make a full turn, I did a free test: I lowered the probe stem I raised the Z axis until it touches the flat, at this point I moved the X axis by 60mm and about 30mm it raised and then lowered in the remaining 30mm, you know you were right the bearings are gone
                                        • Vetiundefined
                                          Veti
                                          have you decided what to do about it?
                                          new bearings or linear rail conversion?
                                          • Leblondundefined
                                            Leblond @Veti
                                            @Veti think about changing bearings? some idea?
