    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
      Phaedrux Moderator @lui2004
      @lui2004 said in After Micro swiss DD upgrade,Extruder skips steps:
      you wrote somthing about 800 steps
      it was just an example, sorry for the confusion.
      For what it's worth, I use x64 microstepping on my Ender 3 to get the steps per mm up a bit on the stock extruder.
      lui2004undefined 1 Reply Last reply Reply Quote 0
      • lui2004undefined
        lui2004 @Phaedrux
        @Phaedrux no problem
        I have mount today the New stepper and the prints looks a lot better. 😊
        I got a free runout filament sensor and i have connect it on E0 stop but i dont know how to make the M591 for RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
        Ps: i got it i must switch the Red and Black wire
        Thanks
          See here https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_filament-out_sensors and here https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
          • lui2004undefined
            lui2004
            ok thanks i have install it with success !
            i connected on E0_stop and insert M591 in my config like this:
            ;Filament Sensors
            M591 D0 P2 C"!e0_stop" S1 ;Extruder 1(0)
            • lui2004undefined
              lui2004
              Last question 😁
              I want convert the x axis with linear rails mgn12 bit i dont found nothing for mounting for micro swiss direct drive, anyone habe a link to stl file?
              Thanks in advance 👍🏼
              Vetiundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti @lui2004
                @lui2004
                https://printermods.com/products/direct-drive-mod-for-creality-ender-3-cr-10
                lui2004undefined 1 Reply Last reply Reply Quote 1
                • lui2004undefined
                  lui2004 @Veti
                  @Veti
                  after i have changed the steppermotor this is my first benchy
                  i have a lot of stringing
                  my benchy:
                  this are my Simplify3D settings:
                  and my config.g
                  ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
                  G90                                      ; Send absolute coordinates...
                  M83                                      ; ...but relative extruder moves
                  M550 P"Ender 5"                          ; Set machine name
                  M552 S1                                  ; Enable network
                  M586 P0 S1                               ; Enable HTTP
                  M586 P1 S0                               ; Disable FTP
                  M586 P2 S0                               ; Disable Telnet
                  M569 P0 S1                               ; Physical drive 0 goes forwards
                  M569 P1 S1                               ; Physical drive 1 goes forwards
                  M569 P2 S0                               ; Physical drive 2 goes backwards
                  M569 P3 S1                              ; Physical drive 3 goes forwards
                  M584 X0 Y1 Z2 E3                               ; set drive mapping
                  M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
                  M92 X80.00 Y80.00 Z800.00 E278.17             ; set steps per mm
                  M566 X900.00 Y900.00 Z60.00 E4000.00      ; Set maximum instantaneous speed changes (mm/min)
                  M203 X15000.00 Y15000.00 Z600.00 E8000.00  ; Set maximum speeds (mm/min)
                  M201 X500.00 Y500.00 Z100.00 E5000.00          ; set accelerations (mm/s^2)
                  M906 X800 Y800 Z800 E1400 I30                   ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30                                  ; Set idle timeout
                  M208 X0 Y0 Z0 S1                         ; Set axis minima
                  M208 X220 Y220 Z300 S0                   ; Set axis maxima
                  M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                  M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                  M574 Z1 S2 									   ; configure Z-probe endstop for low end on Z
                  ;Filament Sensors
                  M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
                  M558 P9 C"^zprobe.in" H3 F60 T6000 A10 R0.75 S0.003            ; set Z probe type to bltouch and the dive height + speeds
                  G31 P500 X41.2 Y4.5 Z1.785                   ; set Z probe trigger value, offset and trigger height
                  M557 X41.2:221.2 Y4.5:219.5 S20                       ; define mesh grid
                  M671 X28.8:198.8:198:28.8 Y24:24:194:194
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                        ; map heated bed to heater 0
                  M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                  M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                  M143 H1 S300 								   ; set temperature limit for heater 1 to 300C
                  M307 H1 B0 S1.00
                  M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                  M563 P0 D0 H1                            ; Define tool 0 S3D
                  ;M563 P0 D0 H1 F0							; Für Prusa Slicer
                  G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
                  G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
                  M572 D0 S0.15 ; Pressure Advance
                  M501
                  • Vetiundefined
                    Veti
                    increase the retraction distance until the stringing stops
                    • lui2004undefined
                      lui2004
                      The retraction speed is ok ?
                      In the manual of micro swiss direct drive os wrotten maximum distance 1.5 and max speed 35 ,can i go higher without Problems?
                      • Vetiundefined
                        Veti
                        print this
                        https://www.thingiverse.com/thing:2563909
                        until you get no stringing.
                        stay with that retraction speed for now
                        • lui2004undefined
                          lui2004 @Veti
                          @Veti which max distance i should 2.0 or 2.5 ?
                          • Vetiundefined
                            Veti @lui2004
                            @lui2004
                            go up in 0.25 increments until the stringing stops
                            • lui2004undefined
                              lui2004
                              ok mate thanks
                              i still print the restraction stl
                              • lui2004undefined
                                lui2004 @Veti
                                @Veti i am now retraction distance of 3,5mm at stringing is always on prints
                                is 3.5mm to much for direct drive ?
                                • Vetiundefined
                                  Veti @lui2004
                                  @lui2004
                                  M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                                  did you change the thermistor when you switched to the micro swiss?
                                  Are you sure B3950 is correct?
                                  lui2004undefined 2 Replies Last reply Reply Quote 0
                                  • lui2004undefined
                                    lui2004 @Veti
                                    @Veti yes i have changed it like in the docu like this:
                                    i have changed only the bed its a silicon bed with 100k NTC3950
                                    M307 H1 B0 S1.00
                                    • lui2004undefined
                                      lui2004 @Veti
                                      @Veti i have checked the marlin source and there is for hotend thermistor:
                                      100k thermistor - best choice for EPCOS 100k (4.7k pullup)
                                      is config correct ?
                                      • Vetiundefined
                                        Veti
                                        what temperature are you printing at? what material?
                                        • lui2004undefined
                                          lui2004 @Veti
                                          @Veti 210°C its PLA
                                          • Vetiundefined
                                            Veti @lui2004
                                            @lui2004
                                            try printing at 200 and 190 and go down and start at 1 mm retraction again.
