    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
    • lui2004undefined
      lui2004 @Veti
      @Veti @Phaedrux
      I have changed the nozzle and Calibrated all, all works fine now.
      I can print PLA with 200°C! Thanks
      i have another question i have Bed compensation in use: none is this normal ? i thin it should be mesh or not ?
      if you need config.g or slicer start.gcode or anything else tell me i will post it
      Vetiundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @lui2004
        @lui2004
        for that your G29 needs to be executed after the G28 in the slicer start code
        lui2004undefined 1 Reply Last reply Reply Quote 0
        • lui2004undefined
          lui2004 @Veti
          @Veti
          my start.gcode looks like that:
          T0
          G90                ;absolute positioning
          M107              ;start with the fan off
          M83  	       ; extruder relative mode
          M104 S[first_layer_temperature] ; set extruder temp
          M140 S[first_layer_bed_temperature] ; set bed temp
          ; Homing & leveling
          G28
          M561 ; Clear any bed transform that might be in place
          G1 X73 Y106 F4000 ; Go to bed center before probing
          ;Wait for Temperature
          M109 S[first_layer_temperature] ; wait for extruder temp
          M190 S[first_layer_bed_temperature] ; wait for bed temp
          G30 ; Find the Z=0
          G29 S1         ; Load the height map from the last time I used G29 to probe the bed.
          G1 X5 Y10 Z0.2 F3000 ; get ready to prime
          G92 E0 ; reset extrusion distance
          G1 X160 E15 F600 ; prime nozzle
          G1 X180 F5000 ; quick wipe
          • Vetiundefined
            Veti
            this should activate the mesh compensation
            do you have a heightmap it can load?
            • lui2004undefined
              lui2004 @Veti
              @Veti
              yes of course!
              RepRapFirmware height map file v2 generated at 2020-12-15 08:54, min error -0.019, max error 0.070, mean 0.019, deviation 0.021
              xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
              41.20,219.00,15.00,195.00,-1.00,20.00,20.00,9,10
                0.055,  0.048,  0.046,  0.056,  0.070,  0.048,  0.050,  0.068,  0.048
                0.030,  0.029,  0.036,  0.050,  0.070,  0.037,  0.037,  0.050,  0.024
                0.007,  0.005,  0.009,  0.026,  0.037,  0.007,  0.006,  0.020,  0.004
               -0.008, -0.001,  0.001,  0.015,  0.031,  0.001, -0.001,  0.014, -0.005
               -0.004, -0.014, -0.008,  0.002,  0.019, -0.010, -0.006,  0.011, -0.004
                0.002,  0.005,  0.004,  0.012,  0.024, -0.003,  0.005,  0.025,  0.002
                0.005, -0.005, -0.009, -0.006,  0.006, -0.019, -0.011,  0.015, -0.003
                0.021,  0.020,  0.002,  0.009,  0.030, -0.000,  0.012,  0.034,  0.017
                0.027,  0.014,  0.006,  0.017,  0.031,  0.006,  0.020,  0.045,  0.031
                0.036,  0.034,  0.019,  0.030,  0.061,  0.041,  0.039,  0.056,  0.035
              • Vetiundefined
                Veti
                did you check the mesh during the print?
                if yes have a look at the generated g code if there is something after the G29 that would invalidate it.
                • lui2004undefined
                  lui2004 @Veti
                  @Veti
                  during the print it is also Bed compensation in use: none
                  this a little part from the generated g.code:
                  ; generated by PrusaSlicer 2.3.0-beta2+win64 on 2020-12-15 at 07:58:45 UTC
                  ; external perimeters extrusion width = 0.45mm
                  ; perimeters extrusion width = 0.45mm
                  ; infill extrusion width = 0.48mm
                  ; solid infill extrusion width = 0.45mm
                  ; top infill extrusion width = 0.40mm
                  ; first layer extrusion width = 0.40mm
                  M107
                  ;TYPE:Custom
                  T0
                  M104 S205 ; set extruder temp
                  M140 S55 ; set bed temp
                  ; Homing & leveling
                  G28
                  M109 S205 ; wait for extruder temp
                  M190 S55 ; wait for bed temp
                  G30 ; Find the Z=0
                  G21 ; set units to millimeters
                  G90 ; use absolute coordinates
                  M83 ; use relative distances for extrusion
                  ; Filament gcode
                  ;LAYER_CHANGE
                  ;Z:0.2
                  ;HEIGHT:0.2
                  G10 ; retract
                  G1 Z0.200 F7800.000
                  G1 X70.563 Y70.965
                  G11 ; unretract
                  ;TYPE:Skirt
                  G1 F900.000
                  G1 X71.065 Y70.492 E0.01957
                  G1 X71.368 Y70.349 E0.00952
                  G1 X71.629 Y70.293 E0.00756
                  G1 X148.407 Y70.297 E2.17871
                  G1 X148.632 Y70.349 E0.00657
                  G1 X148.935 Y70.492 E0.00951
                  G1 X149.437 Y70.965 E0.01957
                  G1 X149.650 Y71.366 E0.01287
                  G1 X149.707 Y71.629 E0.00764
                  G1 X149.707 Y148.371 E2.17768
                  G1 X149.650 Y148.634 E0.00764
                  G1 X149.437 Y149.035 E0.01287
                  • Vetiundefined
                    Veti
                    that is strange.
                    if you issue G29 S1 in the console what does the compensation say?
                    • lui2004undefined
                      lui2004 @Veti
                      @Veti
                      if i activeted via console i got:
                      Bed compensation in use: mesh
                      • Vetiundefined
                        Veti
                        i dont see anything in the g code that would deactivate the mesh compensation.
                        • lui2004undefined
                          lui2004 @Veti
                          @Veti
                          Strange Things 😁
                          Can i post my config and homing files to check if its all ok ?
                          • Vetiundefined
                            Veti @lui2004
                            @lui2004
                            sure
                            you could also execute each line one by one from the start g code and check after each line if mesh compensation is on.
                            • lui2004undefined
                              lui2004 @Veti
                              @Veti
                              ok thanks a lot 😉
                              bed.g:
                              ; bed.g
                              ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
                              ;M561 ; clear any bed transform
                              ;G29  ; probe the bed and enable compensation
                              G28 ; home
                              M401 ; deploy Z probe
                              G30 P0 X45 Y24 Z-99999 ; hinten rechts
                              G30 P1 X198.8 Y24 Z-99999 ; hinten links
                              G30 P2 X198 Y194 Z-99999 ; vorne links
                              G30 P3 X45 Y194 Z-99999 S4 ; vorne rechts and report adjustments needed
                              M402 ; retract probe
                              config-override.g:
                              ; config-override.g file generated in response to M500 at 2020-12-14 19:28
                              ; Heater model parameters
                              M307 H0 A153.1 C665.9 D6.9 S1.00 V24.2 B0
                              M307 H1 A384.5 C134.9 D2.9 S1.00 V24.3 B0
                              ; Workplace coordinates
                              G10 L2 P1 X0.00 Y0.00 Z0.00
                              G10 L2 P2 X0.00 Y0.00 Z0.00
                              G10 L2 P3 X0.00 Y0.00 Z0.00
                              G10 L2 P4 X0.00 Y0.00 Z0.00
                              G10 L2 P5 X0.00 Y0.00 Z0.00
                              G10 L2 P6 X0.00 Y0.00 Z0.00
                              G10 L2 P7 X0.00 Y0.00 Z0.00
                              G10 L2 P8 X0.00 Y0.00 Z0.00
                              G10 L2 P9 X0.00 Y0.00 Z0.00
                              config.g:
                              G90                                      ; Send absolute coordinates...
                              M83                                      ; ...but relative extruder moves
                              M550 P"Ender 5"                          ; Set machine name
                              M552 S1                                  ; Enable network
                              M586 P0 S1                               ; Enable HTTP
                              M586 P1 S0                               ; Disable FTP
                              M586 P2 S0                               ; Disable Telnet
                              M569 P0 S1                               ; Physical drive 0 goes forwards
                              M569 P1 S1                               ; Physical drive 1 goes forwards
                              M569 P2 S0                               ; Physical drive 2 goes backwards
                              M569 P3 S1                              ; Physical drive 3 goes forwards
                              M584 X0 Y1 Z2 E3                               ; set drive mapping
                              M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
                              M92 X79.92 Y79.84 Z797.61 E277.89             ; set steps per mm
                              M566 X900.00 Y900.00 Z60.00 E4000.00      ; Set maximum instantaneous speed changes (mm/min)
                              M203 X30000.00 Y30000.00 Z600.00 E8000.00  ; Set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z200.00 E8000.00          ; set accelerations (mm/s^2)
                              M906 X800 Y800 Z800 E1400 I30                   ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                  ; Set idle timeout
                              M208 X0 Y0 Z0 S1                         ; Set axis minima
                              M208 X235 Y235 Z300 S0                   ; Set axis maxima
                              M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                              M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                              M574 Z1 S2 									   ; configure Z-probe endstop for low end on Z
                              ;Filament Sensors
                              M591 D0 P2 C"!e0_stop" S1   			   ;Extruder 1(0)
                              M950 S0 C"exp.heater7"                         ; create servo pin 0 for BLTouch
                              M558 P9 C"^zprobe.in" H5 F120 T6000           ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X41.2 Y4.5 Z2.786                  ; set Z probe trigger value, offset and trigger height
                              ;M557 X41.2:221.2 Y4.5:219.5 S20                       ; define mesh grid
                              M557 X41.2:219 Y15:195 S20
                              M671 X28.8:198.8:198:28.8 Y24:24:194:194
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                              M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                              M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                              M140 H0                                        ; map heated bed to heater 0
                              M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8; configure sensor 1 as thermistor on pin e0temp
                              M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                              M143 H1 S280 								   ; set temperature limit for heater 1 to 300C
                              M307 H1 B0 S1.00
                              M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                              M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                              M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                              M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                              M563 P0 D0 H1                            ; Define tool 0 S3D
                              G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
                              G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
                              M572 D0 S0.05 ; Pressure Advance
                              M207 P0 S0.45 R0 F2100 T2100 Z0 ; Firmware Retraction
                              M204 P500 T2000
                              M501
                              homeall.g:
                              ; homeall.g
                              ; called to home all axes
                              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:12 GMT+0200 (Mitteleuropäische Sommerzeit)
                              G91 ; relative mode
                              G1 H2 Z4 F200 ; raise head 4mm
                              G1 H1 X-240 Y-240 F3000 ; move up to 240mm in the -X and -Y directions until the homing switches are triggered
                              G1 H2 X4 Y4 F600; move slowly 6mm in +X and +Y directions
                              G1 H1 X-10 Y-10 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered
                              G90 ; back to absolute mode
                              G1 X73 Y106 F2000 ; put head over the centre of the bed, or wherever you want to probe
                              G30 ; lower head, stop when probe triggered and set Z to trigger height
                              homex.g:
                              ; homex.g
                              ; called to home the X axis
                              G91 ; relative mode
                              G1 H2 Z4 F200 ; raise head to avoid dragging nozzle over the bed
                              G1 H1 X-240 F3000 ; move up to 240mm in the +X direction, stopping if the homing switch is triggered
                              G1 X-4 F600 ; move slowly 4mm in the -X direction
                              G1 H1 X10 ; move slowly 10mm in the +X direction, stopping at the homing switch
                              G1 H2 Z-4 F200 ; lower the head again
                              homey.g:
                              ; homey.g
                              ; called to home the Y axis
                              G91 ; relative mode
                              G1 H1 Y-240 F3000 ; move up to 240mm in the -X direction, stopping if the homing switch is triggered
                              G1 X4 F600 ; move slowly 4mm in the +X direction
                              G1 H1 X-10 ; move slowly 10mm in the -X direction, stopping at the homing switch
                              homez.g:
                              ; homez.g
                              ; called to home the Z axis
                              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:37 GMT+0200 (Mitteleuropäische Sommerzeit)
                              G91               ; relative positioning
                              G1 H2 Z5 F6000    ; lift Z relative to current position
                              G90               ; absolute positioning
                              G1 X73 Y106 F6000 ; go to first probe point
                              G30               ; home Z by probing the bed
                              • Vetiundefined
                                Veti
                                remove M401 and M402 from Bed.g
                                are you sure those measurements are correct and backlash did not play a part in it?
                                • lui2004undefined
                                  lui2004 @Veti
                                  @Veti
                                  i have remove the M 401 and 402 from bed.g
                                  i dont think because after a restart and start printing it will use mesh.
                                  the rest of config is fine ?
                                  • Vetiundefined
                                    Veti @lui2004
                                    @lui2004
                                    config otherwise looks fine.
                                    as i said execture each step from the beginning of the g code file and see with M122 after each if mesh is enable, to see where it gets disabled.
                                      Phaedrux Moderator @lui2004
                                      @lui2004 said in After Micro swiss DD upgrade,Extruder skips steps:
                                      It's a minor thing, but you should remove the H2 from that line in your homeall.
                                      Were you perhaps printing an older gcode file that didn't have G29 S1 in it?
                                      lui2004undefined 2 Replies Last reply Reply Quote 0
                                      • lui2004undefined
                                        lui2004 @Phaedrux
                                        @Phaedrux
                                        how does it look ? like this:
                                        G1 X4 Y4 F600; move slowly 6mm in +X and +Y directions
                                          Yes.
                                          The H2 means to move without regard to endstop, which is fine for the Z axis because it hasn't been homed yet, but in the case of the X Y axis it should already be homed, so normal movement should work fine. If for some reason the homing move failed, the H2 would still allow the axis to move, which can make for a confusing error.
                                          • lui2004undefined
                                            lui2004 @Phaedrux
                                            @Phaedrux said in After Micro swiss DD upgrade,Extruder skips steps:
                                            after a restart it works all fine with mesh active
