    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
    • lui2004undefined
      lui2004
      This post is deleted!
      • lui2004undefined
        lui2004 @Veti
        @Veti nothing special, finetuning temptower,retract settings
        all seems fine but with the M207 i have problems
        • Vetiundefined
          Veti
          so without m207 its extruding again?
          lui2004undefined 1 Reply Last reply Reply Quote 0
          • lui2004undefined
            lui2004 @Veti
            @Veti yes with normal retractin from slicer all fine
            with M207 no extrusion , it will print only the base and not the 2 towers for retracting test
            Edit:
            now i have see what cause that no filament come out.
            after retract its during to much time to reload the filament
            i dont know which parameter can set to solve it
            • lui2004undefined
              lui2004
              @Phaedrux @Veti
              i forgot to check '' use realtive E distances '' in the printer Settings, now it works.
              do i need to go higher with my retract settings ?
              at this moment i got this settings for firmware retractions:
              M207 P0 S1.5 R0 F2100 T2100 Z0 ; Firmware Retraction
              or i need to print the retractions stl and post pictures ?
              thanks
              • Vetiundefined
                Veti
                start the print. if its stringing increase the retraction setting in the console while printing.
                • lui2004undefined
                  lui2004 @Veti
                  @Veti ok
                  with which one i begin ? retraction Speed,distance ... ?
                  Vetiundefined 1 Reply Last reply Reply Quote 0
                  • Vetiundefined
                    Veti @lui2004
                    distance
                    • lui2004undefined
                      lui2004 @Veti
                      @Veti ok
                      right now i am at:
                      M98 P"0:/macros/Tuning/Report Current Retraction Settings.g"
                      Tool 0 retract/reprime: length 0.25/0.25mm, speed 35.0/35.0mm/sec, Z hop 0.00m
                      without stringing,is it good ?
                      • Vetiundefined
                        Veti
                        you have to decide that by yourself if you are happy with the result.
                        • lui2004undefined
                          lui2004 @Veti
                          @Veti
                          it looks great !
                          but one question why with slicer retraction i have 1.5mm and with firmware retract i have 0.25mm ?
                          the distance are good ,now i will check with speed right ?
                          • Vetiundefined
                            Veti
                            yes you can, but 35mm/sec is a good speed for retraction
                            lui2004undefined 2 Replies Last reply Reply Quote 0
                            • lui2004undefined
                              lui2004 @Veti
                              @Veti
                              ok i will leave so !
                              i will reprint the benchy to check if its ok
                              • lui2004undefined
                                lui2004 @Veti
                                @Veti
                                i want print the benchy but the first layer adhesion is terrible what i can do now ? before it was all good
                                • Vetiundefined
                                  Veti
                                  can you post a picture of the result?
                                  • lui2004undefined
                                    lui2004 @Veti
                                    @Veti
                                    I dont have adhesion for the first layer so i dont have printed
                                    Indint know if i calibrate the EM again or z-offset
                                      Clean the bed maybe?
                                      • lui2004undefined
                                        lui2004 @Phaedrux
                                        @Phaedrux allready done with iso....
                                        I will check this 👍🏼
                                        • RyanPundefined
                                          RyanP @lui2004
                                          @lui2004
                                          Wish I had of caught this post before you went through everything. The MicroSwiss DD can't use a pancake style motor. This is due to the MS DD not being geared. Use a 42-34 Nema 17.
                                          I ran through all the same problems and was immediately fixed by putting the stock motor on, a 42-34.
                                          CR10S, August 2018
                                          Anycubic Photon S December 2019
                                          Ender 5 Feb 2020
                                          Ender 5 Plus May 2020
                                          Anycubic Photon Mono X Nov 2020
                                          https://3dimensiongames.com/
                                          lui2004undefined 1 Reply Last reply Reply Quote 1
                                          • Vetiundefined
                                            Veti
                                            you are right @RyanP
