Solved Duet3 config Frustration
@Phaedrux
Thanks!
I will most likely go through this again once the configurator has been fixed and compare the code. Is there a thread I can watch to be notified when it has been updated? -
Reading this might also be useful for the setup.https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
@BlueDust said in Duet3 config Frustration:
You could watch the config tool forum to get notified of new posts. Announcements about it should probably go there.
@BlueDust Starting from RRFv3 you must create heaters and fans on the I/O mapping page before you can configure them in the following pages. I agree this split isn't ideal but it was necessary to keep RRFv2 and RRFv3 supported at the same time (for Duet 2 series). We'll make this more intuitive and extensive in the following version soon.
Be aware that
out0
toout3
are no heaters by default unless you assign them first on the I/O mapping page - you could use them for different functions as well. Likewise there are no fans before you define them there. Once you map heaters, you can assign them to tools on the Tools page as well.If the issue with invalid endstop pins is still present (i.e. it's empty + white without error highlighting), please let me know how you can reproduce it and I'll fix it.
@chrishamm said in Duet3 config Frustration:
If you are referring to the the highlighted...
It occurs when I load a previously saved JSON file back into the configurator.
@Phaedrux
I am powering a SBC/RPi4 from my Duet3, and curious if I should be doing this.
I saw posts about possible power problems, and RPis not working properly when powered from the Duet3. Is this something I should be concerned about (and power the Rpi4 from another source) or is it just a problem with a specific version of Duet3 (that's planned to be fixed)?
I read through at least one thread, but didn't come away with confirmed answer... (may have just missed it)Thanks!
You might be able to get away with it if you're not using any other usb peripherals on the pi, but for max stability it's probably best to power them independently.
Also, for what it's worth, it might be best to get everything setup and running in standalone mode before adding the Pi into the mix. This just means using the SD card in the Duet with the pi disconnected as you would with any other duet. Then when you want to add the pi, remove the SD card, connect the pi, and then upload your config again through the web interface.
@Phaedrux said in Duet3 config Frustration:
I am not currently planning to use anything else on the Pi4...
The only thing I am using the Pi4 right now is for ease of updating, so I will consider removing it if I have any trouble that appears to be outside of the config.
Thanks!
@Rushmere3D said in Duet3 config Frustration:
This page seems to be more on the RepRap v2.x and less on v3.x that is on the Duet3.
One of the items I do not fully understand is what F1:2 means. Is that two different fans as lined up on the Configurator website (Fan0 to 3)? Or is that just the location of a single fan as they could be on any number of external (or internal) boards?
The fan wiki page only shows one number after F.
Does this mean fan 0 and fan 3 (F0:3 )? If yes, that doesn't make any sense as I set 0 and 1 to Left Extruder, and Fan 2 and 3 to the Right Extruder in the configurator. I did have to make a change, because config right out of the configurator turned the hotend cooling fan on the right extruder, when I heated up the left hotend. I was able to fix the left hot end cooling fan to enable when it hit 40c, but now not sure why the right hotend fan will not go on at all. And do not understand how to read the F0:3 attribute.
All I know for sure is that this tool isn't working.
M563 P1 S"RightExtruder" D0 H0 F0:3But the fans work fine on the Left Extruder.
M563 P0 S"Left Extruder" D1 H1 F1:2Thanks!
While I understand it can be tedious, I think it is better to configure things manually.
Your case highlights the "confusion" that people encounter when using the config tool that in all honesty only does "half a job" when it comes to setting up RRF-3.
I have a terrible memory (old age is a sick sick joke) so I keep an instance of The Duet G-Code Pinned to open every time I open my browser and with that I read, read & read that page and test so I can manually write my own config.g files, and I add my own explanation (worded in a way I understand) to the end of each G-Code line to remind me
Maybe a pictorial guide for some of some of the basic tasks is required, as I have found documentation to be scattered, sparse in places and some omissions in documentation, that was written by someone that assumes the reader already knows and understands some things.
For example when configuring a tool-board (lc-1) I have never actually found the correct info anywhere.
See below, it took me a bit of time to work out on my own that I was required to add "121" to the C parameter to get the config to know I was trying to direct it to the tool-board. if thats listed in documentation I have yet to find it.M950 F0 C"121.out1" ; The part cooling fan (fan0) is mapped/connected to out1 on the tool-board LC1 with the address being 121
@CaLviNx said in Duet3 config Frustration:
"121
I am not using any external boards... but that is besides the point to my questions.
How did you figure out the address to the tool board was 121?
"121
I couldn't get the duet-3 to recognize a tool-board was there (the LED was flashing the correct way so there was comms) but I couldn't figure out why the DWC was showing errors, so I did a search here to see if there was anyone having the same issue, I found a post on here about someone changing the tool-board address which made me think "I wonder" and I went and added the 121 portion to all my C parameter sections and by magic my errors disappeared.
https://duet3d.dozuki.com/Wiki/Duet_3_Tool_Board#Section_Commissioning_a_new_Tool_Board
Don't ask me why it's 121, but it is documented in the tool board page.
That is 100% correct
But no-where does it actually state (that I could find) that to get the main board and tool-board to communicate with each other, that you should use that address in the C parameter of each required G-Code Command.
That is exactly what I mean about guides that "assume" that the user has prior experience with a certain types of technology, if the user has never used or encountered the tech & what is required to get it up and running how can they know if its not specifically mentioned.
Now this is not having a go, and as an Engineer I understand the trap we can fall into, when someone asks about something (something we perceive as so simple we never give it a second thought) something that we have used and understood for years so much so that when some one asks about it we are like "eh why dont you know that, that's easy"
Yes its easy for some of us because we have been used to it (and been used to using a certain technologies for a long time) but for those who might not have ever used it before we need to change out our approach, and look at it from their perspective.
That is exactly what I mean about guides that "assume" that the user has prior experience with a certain types of technology, if the user has never used or encountered what is required how can they know if its not specifically mentioned.
No argument there. I'm in the same boat. The tool board canbus expansion paradigm probably makes more sense to those in the target market who may already be familiar with canbus, but for the neophyte it's not intuitive. I don't have access to the hardware myself so I haven't used it to know what the major sticking points between documentation and reality are yet. Best I can do is take complaints and suggestions for improvement and update as we go.
A single sentence in the documentation explaining the requirement could save people (me included) hours of frustration.
And with the can-bus tech becoming more common possibly someone could write a small section in the documentation with a brief description of the tech and how it is used/works, requirements etc.
I know and understand that when I write technical curriculum material it is a fine line of trying to get the technical point across in such a way that is not going to make the students eyes roll to the back of his/her head and they pass out, But we always make a point of giving a brief on how the technology (or specific component) works to try to provide a solid foundation on the subject.
Well there is this: https://duet3d.dozuki.com/Wiki/CAN_connection
I'll see about linking to that page from the other duet 3 hardware pages.
M563 P0 S"Left Extruder" D1 H1 F1:2I have made a handful of changes to Fx:x on both the left and right extruders and haven't seen any changes or swaps of the fans. Always works/can't break it making those changes. I don't know what they do.
Saying that, I fixed the right fan. It was unplugged. I thought I wrapped electrical wire around all the fan wire connections to make sure they didn't come apart while moving (connections are inside of the cable sleeve, and not seen without unwrapping the sleeve)... Will fix that.
@BlueDust Thanks, it's fixed now:
I have noticed another weird temp thing a few times, but I am not 100% sure how to reproduce it...
It seems that if I manually set (have yet to print anything), the temp on two extruders, I can only get the temp to heat up on one of them. Even though there is a temp listed, it does increase. I have to click on it a 2nd time and click enter.
I just did this...
I set the temp on two different tools (active and standby) . On the tool that was off, and moved it to standby, and then moved to Active, it wouldn't increase while in either standby or active. I had to click the temp and hit enter (didn't re-input the temp a 2nd time).Is this a bug or expected? If this is a possible bug, I will have to pay more attention what I am doing when manually playing with the temps incase I see this again.
