    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.0k
    • A Former User?
      A Former User
      Is the thermistor the white sleeved wirng or the red fiberglass insulated wiring? i'd guess the latter as the heater appears to be a cartridge poking out the other end.
      Blacksheep99undefined 1 Reply Last reply Reply Quote 0
      • Blacksheep99undefined
        Blacksheep99 @A Former User
        @bearer Sorry, it's the red wiring. The white ones are attached to the cartridge.
        • A Former User?
          A Former User
          Thats what I thought but the pictures seemed focused on the white wiring, I guess its hard to get a good angle on the thermistor then?
            @bearer It's not too easy especially with the double print head. I'll try again now. I may take one apart if that would be helpful.
            • A Former User?
              A Former User
              If the wires just disappear into some black goo like the heater then i doubt we can identify them visually. But given the construction, a glass bead ntc is the most likely candidate if you want to replace it - but if the mounting is just some sort of adhesive or not idk.
                Blacksheep99
                Pretty much
                • Vetiundefined
                  Veti
                  well you can try your ir thermometer to see if the temperature is close
                    Blacksheep99 @Veti
                    @Veti On the heater block? As in wire up to the board and heat to 220? measure resistance ....
                    • Vetiundefined
                      Veti
                      sorry i was under the impression you had an ir thermometer
                        Blacksheep99 @Veti
                        @Veti I have one of these
                        https://www.amazon.co.uk/gp/product/B01AT9TON0/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
                        So heat in the oven and then if it measures 220 check resistance. Sorry if I'm been dense
                        • Vetiundefined
                          Veti
                          unless you have an all metal hotend, go for 200
                          let it stay at that for a min or so and measure the temperature on the nozzle with the ir thermometer.
                          • A Former User?
                            A Former User
                            need to set the correct emissivity for the nozzle to get an reasonably accurate reading, but by the looks of it thats likely to be less accurate then just picking a beta value
                              Blacksheep99
                              Small update. I had a bit of time and I wanted to just test a few things. I decided to run the bed heater with the 'default' setting from the config tool. This is what I started with.
                              code_text
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on pin bedtemp
                              M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
                              M307 H0 B0 S1.00                                ; disable bang-bang mode for the bed heater and set PWM limit
                              M140 H0                                         ; map heated bed to heater 0
                              M143 H0 S80                                     ; set temperature limit for heater 0 to 80C
                              M308 S1 P"e0temp" Y"thermistor" T137000 B3478   ; configure sensor 1 as thermistor on pin e0temp
                              M950 H1 C"e0heat" T1                            ; create nozzle heater output on e0heat and map it to sensor 1
                              M307 H1 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
                              M143 H1 S250                                    ; set temperature limit for heater 1 to 250C
                              M308 S2 P"e1temp" Y"thermistor" T137000 B3478   ; configure sensor 2 as thermistor on pin e1temp
                              M950 H2 C"e1heat" T2                            ; create nozzle heater output on e1heat and map it to sensor 2
                              M307 H2 B0 S1.00                                ; disable bang-bang mode for heater  and set PWM limit
                              M143 H2 S250
                              I ran the autotune for the bed. It gave me this override and I added the M501 to the end of my config
                              ; config-override.g file generated in response to M500 at 2021-01-07 19:46
                              ; Heater model parameters
                              M307 H0 R0.307 C525.917:525.917 D13.65 S1.00 V24.2 B0
                              M307 H1 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0
                              M307 H2 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0
                              ; Workplace coordinates
                              G10 L2 P1 X0.00 Y0.00 Z0.00
                              G10 L2 P2 X0.00 Y0.00 Z0.00
                              G10 L2 P3 X0.00 Y0.00 Z0.00
                              G10 L2 P4 X0.00 Y0.00 Z0.00
                              G10 L2 P5 X0.00 Y0.00 Z0.00
                              G10 L2 P6 X0.00 Y0.00 Z0.00
                              G10 L2 P7 X0.00 Y0.00 Z0.00
                              G10 L2 P8 X0.00 Y0.00 Z0.00
                              G10 L2 P9 X0.00 Y0.00 Z0.00
                              M486 S-1
                              During the bed test and after with my own tests using a IR thermometer gun I was getting within 1-2c of what the Duet was reporting so I was quite pleased to see that.
                              I disconnected the bed and decided to see what the hotend was reporting. I've removed the hot end part of the carriage from the printer. I connected the heater and sensors to the E0 connections. For these purposes I have used Dupont wires, with bootlace and other supplied connector. Upon starting the board up I got this error.
                              Error: Temperature reading fault on heater 0: sensor open circuit
                              I've searched the error and it seems to tell me that there is no connection, there are reports of blown fuses but I don't believe that to be the issue. I have checked for resistance across the connections and it seems there's a connection.
                              I've now left it as I don't want to do any damage. Any advice on what I need to check? Thanks.
                              Pics
                                Blacksheep99
                                I've already realised my mistake! I connected to the wrong part of the board. I used E0 Heat when I should use E0 Temp!
                                I'll leave the other post up as it's what I've been doing and also may serve as a lesson to others.... 😄
                                • Vetiundefined
                                  Veti
                                  @Blacksheep99 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                                  i suggest you try the most common ones for the thermistors.
                                  thats B 3950
                                  epocs 100k
                                  semitec 104-gt2
                                  your settings seems very wrong.
                                    Blacksheep99 @Veti
                                    @Veti Thanks. I'm thinking the easiest thing would be to buy two new thermistors for the hot end. Could you recommend ones available on amazon uk? I do have the offer of a k type thermocouple meter from a friend.
                                    I think the bed seems to behave and I doubt I'll need to go above 60c so I'm less concerned about that.
                                    Tonight I hope to look at the servo and probe. I intend to add a microswitch and use that as the X stop so the probe has a single purpose.
                                    • Vetiundefined
                                      Veti
                                      not amazon but e3d
                                      https://e3d-online.com/products/100k-ohm-ntc-thermistor-semitec?_pos=6&_sid=d490c2b6e&_ss=r
                                      https://e3d-online.com/products/fibreglass-sleeving-for-insulating-thermistors-100mm?_pos=11&_sid=d490c2b6e&_ss=r
                                      but we dont know if it will fit, because of the black gunk we cant see a thing
                                        Blacksheep99 @Veti
                                        @Veti Thanks. I'll look at E3D. If I take one of the hot ends apart would that be the way to go? I take when buying the thermistor I'd also need some kind of sleeve and is there a thermal paste of some nature? I've never built a hot end so it's new to me.
                                        • Vetiundefined
                                          Veti
                                          the sleeve i linked
                                          however the hotend is different from most other hotends so you will have to see how to fix it
                                          maybe you could also mount a standard e3d block on there.
                                            Blacksheep99 @Veti
                                            @Veti Sorry, I overlooked the 2nd link.
                                            I did wonder about that. I'm going to take one apart and have a closer look.
