    Problem with rear side of Test Cube
    2.4k
    • dmbgoundefined
      dmbgo
      @alankilian said in Problem with rear side of Test Cube:
      1/ Do you see filament extruding on the back cornets?
      2/ Do you hear your extruder struggling/clicking when that happens?
      3/ Can you rotate the cube 180-degrees to see if it then happens on the front?
      4/Can you rotate the entire printer 180-degrees to see if it changes due to airflow?
      5/Do you have an enclosure?
      1/ Back cornets?
      2/No clicking, extruding nicely when I move it up and extrude some filament.
      3/I should have mentioned that I had done that, it still happens on the rear (mainly)
      4/The pinter is on a wheeled trolley, I have tried that. Ambient temp is 18.4C atm.
      Regards David Maher
      • dmbgoundefined
        dmbgo
        "From what I have read ABS really needs a heated enclosure BUT I don't know if that is related to your problem. Frederick"
        Yes, I found that out a while ago, which is why I made the one in the pic. It is made from 50mm expanded foam, coated with thin fiberglass panels. The material came from an old coolroom.
        Regards David Maher
        • dmbgoundefined
          dmbgo
          But the issue remains. Any other helpful suggestions, they've been good so far?
          Regards David Maher
          • fcwiltundefined
            fcwilt @dmbgo
            @dmbgo said in Problem with rear side of Test Cube:
            Instead of printing a cube can you create a model of a disc, say, 50 mm in diameter and 5 mm thick?
            If you can print it using you normal settings.
            • dmbgoundefined
              dmbgo
              Here's a pic of the printer:
              Regards David Maher
              • dmbgoundefined
                dmbgo
                Sorry Fredrick, but my modelling capability is V low. Could you please suggest a model from thingiverse or somewhere?
                Regards David Maher
                • fcwiltundefined
                  fcwilt @dmbgo
                  Here you go.
                  Slice it normally but keep the layer cooling fan(s) off.
                  Disc 050 x 005.stl
                  • dmbgoundefined
                    dmbgo
                    Thanks Fredrick
                    Regards David Maher
                    • dmbgoundefined
                      dmbgo
                      Thanks Fredrick
                      Printing now
                      Regards David Maher
                      • fcwiltundefined
                        fcwilt @dmbgo
                        Printing now
                        I will check back in a bit.
                        • dmbgoundefined
                          dmbgo
                          Where are you Fredrick? If it is too late at night, we can leave it until tomorrow.
                          Regards David Maher
                          • fcwiltundefined
                            fcwilt @dmbgo
                            @dmbgo I'm here.
                            • dmbgoundefined
                              dmbgo
                              The disk is printing at 30 mm/s. It will probably take about 20mins more.
                              Regards David Maher
                              • fcwiltundefined
                                fcwilt @dmbgo
                                What does it look like so far?
                                • dmbgoundefined
                                  dmbgo
                                  Regards David Maher
                                  • fcwiltundefined
                                    fcwilt
                                    OK.
                                    I'll check back in 15 mins.
                                    • dmbgoundefined
                                      dmbgo
                                      The bed levelling is a bit out now, but I dont think it will affect the disc
                                      Regards David Maher
                                      • dmbgoundefined
                                        dmbgo
                                        Almost there...
                                        Regards David Maher
                                        • fcwiltundefined
                                          fcwilt @dmbgo
                                          Almost there...
                                          It's going as I expected.
                                          • dmbgoundefined
                                            dmbgo
                                            Just covering the top now.
                                            Regards David Maher
