    BL-Touch blinking after retract?
    355
    • Chriss
      Chriss last edited by
      Hi *,
      I'm testing my new build and I saw a strange behavior of the BL-Touch during this drill:
      The BL-Touch (3.1 original) starts blinking after a retract or after it got triggered. It is working fine beside that, so z is fine and I can re-home Z with the blinking probe. But I understand that this blinking indicate a problem, doesn't it?
      The BL-Touch is configured to the Toolboard 1LC, which is connected to a Mini 5+. All of the hardware is n 3.2.
      M950 S0 C"121.io0.out"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H5 F120 T6000               ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      I'm unable to see any problem with the wiring. Could that be caused by a wrong calibration with the screw at the back of the BL-Touch?
      Cheers, Chriss
      Veti Stephen6309 2 Replies Last reply Reply Quote 0
      • Veti
        Veti @Chriss last edited by
        @Chriss said in BL-Touch blinking after retract?:
        yes.
        have you run the bltouch self test?
        Chriss 1 Reply Last reply Reply Quote 0
        • Chriss
          Chriss @Veti last edited by
          @Veti
          There is a self test?
          Do you mean something like that: https://github.com/JimBrown/MarlinTarantula/wiki/How-to-test-the-BLTouch-Z-probe
          I performed that drill and the blinking is gone now. :? Hmmmm.... I'm a bit confused now.
          Cherrs, Chriss
          Veti 1 Reply Last reply Reply Quote 0
          • Veti
            @Chriss
            that probably means that the grub screw is close enough to cause problems.
            but if it is working now..
            i personally dont like the bltouch.
            Chriss 2 Replies Last reply Reply Quote 0
            • Chriss
              @Veti said in BL-Touch blinking after retract?:
              Yes, I will keep an eye on it. The next step will be a calibration if the screw than.
              Me neither, but I was not able to find a better solution. 😞 I tried the IR-Probe from dc42 and that thing gave me even more problems, so I switched all of my printers back to BL-Touches. 😞
              Cheers, Chriss
              • Veti
                i use this on my ender 3
                • Chriss
                  @Veti
                  I had a ir-probe on my CR-10 pro v2 with a PEI sheet and I was unable to get reliable results. I gave up there after to many crashes of the nozzle to the bed.
                  The results on my CoreXY with a bright PrintBite+ where also not very reliable. I lost on one of them the IR-Diode, whether by temperature or by a crash. One simply died for "whatever" reason.
                  So I simply gave up, I will give them a next chance sometime in the future but I'm done with them for now.
                  Cheers, Chriss
                  • Veti
                    Veti last edited by
                    sorry i mean to post a link
                    https://www.thingiverse.com/thing:3303618
                    • Chriss
                      @Veti
                      Or V2: https://www.thingiverse.com/thing:3756428
                      That is basically a home made bl-touch if I understand both correctly.
                      Well, is that technically a better solution? I do not see any benefits here when I compare it with the BL-Touch.
                      Cheers, Chriss
                      Veti JadonM 2 Replies Last reply Reply Quote 0
                      • Veti
                        @Chriss
                        it has the advantage that if the pin does not drop, probing will fail.
                        the bltouch will ram into the bed.
                        its very accurate.
                        not susceptible to interference.
                        price
                        fcwilt 1 Reply Last reply Reply Quote 0
                        • fcwilt
                          fcwilt @Veti last edited by
                          @Chriss
                          its very accurate.
                          price
                          I wish somebody had this ready to buy - I would like to try one.
                          • Chriss
                            The problem is back... 😞 I think that I need to find a real solution now. Screw?
                            I think that it must be flush with the top end of the device if my memory is correct here.
                            Cheers, Chriss
                              If the probe is overwise working you could add the commands to reset errors and retract the pin to the end of config.g and the start of your homing files so that the probe is prepared to be used.
                              • Stephen6309
                                Stephen6309 @Chriss last edited by
                                @Chriss Have you updated the boot loader for the 1LC?
                                https://github.com/Duet3D/Duet3Bootloader/releases
                                Chriss 1 Reply Last reply Reply Quote 1
                                • JadonM
                                  JadonM @Chriss last edited by
                                  I have both a genuine BLTouch 3.1 and this on a few of my production printers, which run almost all day most days. Believe it or not, the homemade version is faster, more accurate, and has not caused a single inconvenience. Not once in the almost-year that I've used it have I had to tinker with it or worry about it. It just works!
                                  I wish I could say the same about my BLTouch! 😃
                                  • Chriss
                                    Chriss @Stephen6309 last edited by
                                    @Stephen6309 said in BL-Touch blinking after retract?:
                                    Not yet.... Can that really make a difference? At the end is the bootloader only loading the firmware... well, I will give it a try.
                                    @Phaedrux Yes, the probe seams to work correctly. The probe is at duty since 3 days and I still work on the hardware. So there is not sooo much to say about the long term experience with that one.
                                    I will update the bootloader and I change the tiny bugger with the one in my CR10 with a duet2, just to know which device is the source.
                                    So it seems that this is not a soooo comon problem. 😞
                                    Cheers, Chriss
                                    • Chriss
                                      Chriss @Chriss last edited by Chriss
                                      @Phaedrux
                                      It seams that the problem is solved now. I upgraded the bootloader of the toolboard to 2.2. I do not understand how that should have influence here but I'm not a embedded device programmer.
                                      To my future me:
                                      Firmware Update howto:
                                      https://duet3d.dozuki.com/Wiki/Updating_the_bootloader_on_Duet_3_expansion_and_tool_boards
                                      Cheers, Chriss
                                      • Veti
                                        Veti last edited by
                                        there was a bug that debug information was written to the pwm pin during the bootloader process. this causes problems with bltouch.
                                        • Chriss
                                          @Veti Good to know. 🙂
                                          It is a much better solution to fix that than try to work around. The trick with the resets produced a lot of other problems. That seemed to me like a endless process. Anyway, happy now. I'm so happy that I can start with the fist first tests with hot filament. 🙂
