    My wish : Inputs debouncing
    Firmware wishlist
    9
    34
    1.9k
    • BoAundefined
      BoA
      I have a button connected to one of io inputs, and trigger set on it. I noticed that tigger macro is executed more than once, and I suspect this is because lack of debouncing on inputs.
      Second option would be to ignore trigger in case it is actually executed.
      G4 S1 at the end of trigger macro does not help at all.
      • A Former User?
        A Former User @BoA
        @BoA said in My wish : Inputs debouncing:
        you could perhaps start the macro with a M581 P-1 Tn to disable it immediately, ** if ** that is fast enough. (if needed you could dwell and re-enable it at the end of the macro as well)
        • whopping pochardundefined
          whopping pochard
          It does seem like there ought to be debounce enabled in the software! A very quick search on GitHub showed debounce on rotary encoder input and fan rpm input, but none that I could see associated with basic switch inputs.
          There are also debounce ICs if you want to hit it with the hardware hammer.
          • A Former User?
            A Former User
            might help to be specific about board and pin in use + type of switch.
            the duet2 has filter caps on all the endstop inputs, duet3 lists them as DNP
            BoAundefined 1 Reply Last reply Reply Quote 0
            • BoAundefined
              BoA @A Former User
              @bearer It is DUET3, pin is io8.in
              Button type - GQ30PF-11E/G/24V/S - NC contacts used for io pin, and NO for PSU "priming" before M80 executed.
              • fcwiltundefined
                fcwilt @BoA
                Firmware version?
                It's hard to believe that the firmware doesn't de-bounce the inputs - it's simple code.
                BoAundefined alankilianundefined 3 Replies Last reply Reply Quote 0
                • BoAundefined
                  BoA @fcwilt
                  @fcwilt Firmware 3.2 - running standalone
                  @fcwilt said in My wish : Inputs debouncing:
                  Perhaps it does. It is a big button, perhaps more bouncy than others. Not sure. But I have trigger executed twice with one push. I might have some spare time this weekend to hook a scope on the pin and see what is going on exactly if that would help.
                  • fcwiltundefined
                    fcwilt @BoA
                    @BoA Thanks for the info.
                    It's possible that, if there is de-bounce code, it made an assumption about how long the bouncing would last. There's a trade off - the more bouncing you code for the slower the response time.
                    It would be interesting to see how your button performs.
                      AFAIR, changes on an input pin that activates a trigger are already disabled until the trigger macro has finished executing, because that was the intention. But I could be mistaken.
                      • alankilianundefined
                        alankilian @fcwilt
                        Weeeellllll........ Not simple at all in fact.
                        Here are two articles about debouncing:
                        http://www.ganssle.com/debouncing.htm
                        http://www.ganssle.com/debouncing-pt2.htm
                        As @fcwilt says, it's a tradeoff between response-time and repetition rate and how long the bounce lasts.
                        Still, I think it should be possible to implement without using up too much RAM or CPU time.
                        There's some simple debouncing in the filament monitor code, but it's not configurable.
                        • BoAundefined
                          BoA @dc42
                          @dc42 It looks like it is queued somehow.
                          My current trigger macro:
                          M300 P200
                          if state.gpOut[1].pwm < 1
                          	M42 P1 S1.0
                          else
                          	M42 P1 S0.75
                          G4 S5
                          	M81 S1
                          else
                          	M80
                          so it should not trigger more often that ~5s, and trigger should not be active when macro executing. Meanwhile I just tested by just pressing button twice - second time about 1s after. And I got a first "beep", and after about 5s second "beep".
                          So it looks that condition for trigger are checked during macro execution, and second trigger event is somehow queued.
                          • A Former User?
                            A Former User @BoA
                            i recall seeing someting similar ages ago
                            • fcwiltundefined
                              fcwilt @alankilian
                              @alankilian said in My wish : Inputs debouncing:
                              I thought you said debouncing wasn't simple 😉
                              • BoAundefined
                                BoA
                                I connected scope and that are the results.
                                Pressing button - nice a smooth (this is NC, so disconnecting contacts very good behavior)
                                But releasing button (where contacts meeting again) is.. well... not good, but below 1ms in total.
                                • o_lampeundefined
                                  o_lampe
                                  What, if you use the NO button pin? (if available).
                                  The bouncing is filtered at the begin of a macro, as somebody mentioned.
                                  • dragonnundefined
                                    dragonn
                                    Could you just add a capicator parallel to the button?
                                    Sometimes the best solution is doing it in hardware
                                    o_lampeundefined 1 Reply Last reply Reply Quote 1
                                    • o_lampeundefined
                                      o_lampe @dragonn
                                      @dragonn said in My wish : Inputs debouncing:
                                      An RC combo would be best
                                      • A Former User?
                                        A Former User @o_lampe
                                        @o_lampe said in My wish : Inputs debouncing:
                                        there is already series resistance on the inputs, and a footprint for a cap if so inclined
                                        • BoAundefined
                                          BoA
                                          I know this can be fixed in hardware, and I know how. The point was to fix it is SW which do not change input pin characteristics. And debouncing is not a rocket science to implement.
                                          Also I am not very happy with though that I would have to take board out just to solder small cap, or even less happy to connect cap. hanging on wires.
                                          But this is wish list, so... that is my wish (granted or not).
                                          dragonnundefined 1 Reply Last reply Reply Quote 0
                                          • dragonnundefined
                                            dragonn @BoA
                                            That depends on you application architecture, many embedded system without RTOS use something like a simple event loop and implementing debouncing in isn't so simple as it sounds. RRF works on RTOS but it started without it so probably most of the system is a event loop.
                                            It can be of course done, they are many ways to do it. I just wanted to say that something simple from user stand point isn't often so simple in the software 😜
                                            fcwiltundefined BoAundefined 2 Replies Last reply Reply Quote 0
