Faulty Smart Effector
since today my smart effector seems to be faulty.
It continuously triggers even with the board alone (without heatsink, arms, fans ..), green trigger light and 1000 value in web control.
It flashes three times when turned on and then lights green all the time.
I can't see any damageHELP
Thanks
Thomas -
Thanks, but that is not the only thing that I tried several times but without any success.
post high resolution pictures of the front and back of the effector
I've already inspected the whole effector with a magnifying glass
There is nothing abnormally -
When and where did you purchase it?
Sep '19 at filafarm.de
I've already sent them a mail -
Photos? Maybe we can see something you can't?
Wiring?
Did anything change recently with the printer?
When was it working last? -
Is that a scratch on the second photo on the bottom edge?
yes, but it's there since I received it and it is only on the lacquer coat
What M672 are you using?
tried M672 S131:131 without success - even no flashing of the LED
and before you're asking
;### Z-Probe ### M558 P8 R0.2 F1200 H2 C"zprobe.in" G31 P100 X0 Y0 Z-0.19 ; Set Z probe trigger value, offset and trigger height M557 R180 S40 ; Define mesh grid
@tcj said in Faulty Smart Effector:
this is missing the zprobe.mod to control the sensitivity
try C"zprobe.in+zprobe.mod"
@Veti Thank you so much!
It works! -
@Lightpath said in Faulty Smart Effector:
@Veti said in Faulty Smart Effector:
This should be in the documentation.
Consider it done.
