    Analyze Thermistor?
    30
    1.2k
    • fcwiltundefined
      fcwilt
      When confronted with a machine with existing thermistors without specifications is they any way to test them or any device that can test them to determine their characteristics and thus the values need to configure them for RRF 3?
      Thanks.
      droftartsundefined DigiDundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @fcwilt
        @fcwilt Measure resistance at 0C (stick between ice cubes), 25C (or room temperature) and 100C (stick in boiling water) then use https://www.thinksrs.com/downloads/programs/therm calc/ntccalibrator/ntccalculator.html
        Or just replace them!
        • fcwiltundefined
          fcwilt @droftarts
          @droftarts said in Analyze Thermistor?:
          Thanks much.
          The one in the extruder looks like a common cartridge type but I won't know for sure until I take the extruder assembly a part which I am putting off for now.
          The heated bed is a bit of a mystery - I see no way to access the thermistor - I cannot even locate where in the bed it is. I suppose I could forgo the heater in the bed and stick a Keenovo on the underside. Or order a piece of tool plate cut to size. Putting that off for now too.
          • Vetiundefined
            Veti
            @fcwilt said in Analyze Thermistor?:
            my first place to go is look at the marlin config if it exists.
              @fcwilt what printer is it?
              • fcwiltundefined
                fcwilt @Veti
                @Veti said in Analyze Thermistor?:
                That is a good idea - it did come with a SD card that might have that information.
                • Vetiundefined
                  Veti
                  https://github.com/MarlinFirmware/Configurations/tree/import-2.0.x/config/examples
                  fcwiltundefined 1 Reply Last reply Reply Quote 1
                  • fcwiltundefined
                    fcwilt @droftarts
                    This one:
                    Link to printer
                    • fcwiltundefined
                      fcwilt @Veti
                      @Veti
                      Thanks.
                        @fcwilt Looks like github repo is here, this is the best line I could find quickly: https://github.com/my3dltd/F1-B-V2-NANO/blob/31874e09f71b465f56eeb7b6ba4938376e794848/robin_nano35_cfg.txt#L168
                        • Vetiundefined
                          Veti
                          that does make sense. its an ultimaker 2 clone.
                          ultimaker 2 uses thermocouples. so this clone does too.
                          • fcwiltundefined
                            fcwilt
                            Thanks for the help.
                            I will investigate these resources later today.
                            engikeneerundefined 1 Reply Last reply Reply Quote 0
                            • engikeneerundefined
                              engikeneer @fcwilt
                              @fcwilt for a quick & dirty check, you could always stick the bed in your oven, set the temperature to ~80deg and leave the wires dangling out the door. Even better if you have a reliable thermistor/thermocouple setup to put in to get an accurate reading of how hot the oven is. Repeat for a few temps and see how different the generated parameters are?
                              i3 clone with a bunch of mods
                              • fcwiltundefined
                                fcwilt @Veti
                                Well I treated them as thermistors in RRF3 and they seem to work.
                                At least I was able to complete M303 but I used the B value from a thermistor I knew which is not likely to be correct.
                                • fcwiltundefined
                                  fcwilt @engikeneer
                                  @engikeneer said in Analyze Thermistor?:
                                  I do have an good meter for measuring temps.
                                    Is the text config file a new thing in Marlin? It still only seems to set the hot end temp sensor, but it is Thermistor #1, so you should be able to look that up in Marlin. Really they should be posting their full Marlin source, where I guess the bed sensor is hard coded.
                                    • fcwiltundefined
                                      fcwilt @droftarts
                                      I will see what I can find but the web sites are sometimes a bit confusing.
                                        @fcwilt can you use the Robin Nano electronics with the STM32 port of RRF? I don’t see it in @gloomyandy ’s wiki. https://teamgloomy.github.io/getting_started.html
                                        droftartsundefined gloomyandyundefined fcwiltundefined 3 Replies Last reply Reply Quote 0
                                          droftarts administrators @droftarts
                                          Looks like the Robin Nano uses STM32F103VET6, so I guess not.
                                          • gloomyandyundefined
                                            gloomyandy @droftarts
                                            Robin Nano
                                            Short answer is no, not supported.
                                            Longer answer is that there are different versions 1.x/2.x uses the STM32F1 mcu which we don't support. 3.x has an STM32F4 which we do support. However it uses a different SPI unit for SD card access to all of the other currently supported boards (plus a bunch of other differences). Given that we normally read the SD card to get a config file that describes the hardware this means it won't currently work. There are changes in the (currently unreleased) V3.3 version of the port that may make it possible to support the V3 board, but it is not something we have tested so far.
