    Is it possible to tweak the bed heater algorithm?
    516
    • KTWundefined
      KTW
      My printer is practically unusable at this point, since the bed heater algorithm faults it almost every time i turn on the printer.
      Is it possible to change the check, so I don't need to perform a M303+M307 every single time I need to use the printer?
      Always the same error:
      Error: Heater 0 fault: temperature rising much more slowly than the expected 0.2°C/sec
        jay_s_uk @KTW
        @KTW either save the outputted values into your config.g or use M500 to save the values into config-override (ensuring you have M501 at the end of your config)
        • KTWundefined
          KTW
          If only it was this easy.
          I am already doing this every time. 🙂
          • deckingmanundefined
            deckingman @KTW
            @KTW Not sure if it'll work in this case but you could try M570 to adjust the fault detection parameters. So e.g. M570 H0 P10 T5 S300 would set the time to 10 seconds, the excursion value to 5 degrees and cancel the print after 5 minutes of exceeding those values.
            KTWundefined 1 Reply Last reply Reply Quote 0
            • matt3oundefined
              matt3o
              I also had to tweak my values. It is feasible but depends on your bed. What are you tuning params?
                jay_s_uk
                or roll back to 3.1.1 to use the other algorithms and then don't tune with the new ones.
                I had to do that on the heated bed on one of my printers
                • KTWundefined
                  KTW @matt3o
                  @matt3o
                  M303 H0 S70
                  M307 H0 R0.363 C315.930:315.930 D5.30 S1.00 V24.4 B0
                  matt3oundefined 1 Reply Last reply Reply Quote 0
                  • KTWundefined
                    KTW @deckingman
                    @deckingman
                    Thank you, I will try this.
                      deckingman @KTW
                      @KTW If that doesn't work, you could also try increasing the "D" (dead time) parameter in your M307. Try (say) 10 secs instead of the 5.3 that the tuning algorithm calculated.
                        @KTW please post your entire config.g file, also the config-override.g file if you have one.
                        • matt3oundefined
                          matt3o @KTW
                          @KTW said in Is it possible to tweak the bed heater algorithm?:
                          @matt3o
                          M303 H0 S70
                          if it were my printer I would try
                          M307 H0 R0.3 C400 D6.5 S1.00 V24.4 B0
                          if you are on SSR you don't need V
                          • KTWundefined
                            KTW @dc42
                            @dc42 here is my config files.
                            I have added the command "M570 H0 P10 T5 S300" suggested by @deckingman and this seems to have helped.
                            config-override.g
                            config.g
                              What kind of a heated bed is it?
                              • KTWundefined
                                KTW @Phaedrux
                                @Phaedrux
                                It's a 220V silicone heater,
                                similar to this one:
                                https://makersupplies.dk/en/heatbed/823-heatbed-silicone-heatbed-300x300mm-220v-350w.html
                                • matt3oundefined
                                  matt3o @KTW
                                  @KTW as far as I understand the problem is that the sensor is integrated, for some reason RRF can't cope with that.
                                    See the reason here: https://forum.duet3d.com/topic/22155/error-heater-0-fault-temperature-rising-much-more-slowly/9?_=1616081192454
                                    There is still room for improvement on the new algorithm to better take into account the thermal mass of the bed plate itself.
