    Closed Loop Motor Setup
    61
    6.9k
    • alankilianundefined
      alankilian @moe.adams9093
      @moe-adams9093 For sure. I'll send you my email address in a message.
      Toastinatorundefined 1 Reply Last reply Reply Quote 0
      • Toastinatorundefined
        Toastinator @alankilian
        @alankilian @moe-adams9093 Just Read all your messages since my Last message.
        @moe-adams9093 That is exactly what i have been seeing, Its a continuous Layer shift through the layers. Some Worse then others. Im hoping We can Resolve this. But Its not the end of the world. Just the end of $200.
        @alankilian I sort of agree with you about Closed Loop Not Really adding any benefit, To me, Its more of a "Lets do everything we can to prevent a layer shift" (Although I can see as the motor increases the Torque, It just pops the print off the bed)
        Im still in it for the rest of the People. This is a popular Motor for people to have. Getting it working should help quite a few.
          Toastinator @3DPMicro
          @3dpmicro That's what I Heard! But Its really Expensive. Im Buying PEEK Pellets for Roughly $45/Kg, Then The Power costs to produce the Filament when I get everything Set up.
          Ill give it a shot when My Voron Gets Built. I Got CNC Aluminum Parts for the Voron Gantry So it can Handle the High Temperatures
          PEKK is Something like $800/Kg I think PEEK is Slightly Cheaper Around $700/Kg. Only went with PEEK Because For Some Reason, Its $45/Kg for Pellets.
          Know a Place to get Reasonably Price PEKK Pellets?
          mendenmhundefined 1 Reply Last reply Reply Quote 0
          • taylo708undefined
            taylo708
            I run these same motors on my printers, took me a long time to get them working correctly but I think I am close. I was getting inconsistent layer shifting until I started going crazy with the T parameters.
            • mendenmhundefined
              mendenmh @Toastinator
              @toastinator I was generally of the opinion that printing with something cheap, like solid gold, was easier than going for high-end PEKK and PEEK. 🙂
              • 3DPMicroundefined
                3DPMicro
                @toastinator he's only showing pekk/cf pellets
                https://www.3dxtech.com/products/pellets-colorants/ but you could inquire about unmodified Pekk although pekk/cf is my favorite by far. Second in modulus only to peek/Cf but is easy (relative) to print, makes good looking parts and can use all the way up to 260c.20210120_192926.jpg
                Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
                Toastinatorundefined 1 Reply Last reply Reply Quote 1
                  @3dpmicro Looks Really Good, Do you use a ruby Nozzle for that? Or Just a Plain Hardened Steel Nozzle? Thanks for the advice, Ill look into it
                  @mendenmh You could be Right, But I love a challange!
                  @taylo708 Are you Using a Duet 3 With Duet 3 Expansion 1XD Boards for these Motors? I went Crazy on the T Parameters with no Luck
                  taylo708undefined 3DPMicroundefined 2 Replies Last reply Reply Quote 0
                  • taylo708undefined
                    taylo708 @Toastinator
                    @toastinator Yes I am using Duet 3 with 3 expansion boards. I run them on x,y and z axis.
                    Toastinatorundefined Thunderrunnaundefined 2 Replies Last reply Reply Quote 0
                    • 3DPMicroundefined
                      3DPMicro @Toastinator
                      @toastinator said in Closed Loop Motor Setup:
                      Slice engineering nozzle. Guaranteed not to wear out.....we'll see
                      Forgot to mention you want PEKK "C" not "A"
                        Toastinator @taylo708
                        @taylo708 Ok, Im only Using on X/Y Axis. My Z Axis has 3 Motors. Im Almost done Printing the Parts for my Voron 2.4 Build. When I get the Motors back, I Should be totally done and can Start Digging into why these are doing what they are doing.
                        @3DPMicro Gotcha Thanks, Have been Looking at the Slice Magnum Setup for a while
                        alankilianundefined 1 Reply Last reply Reply Quote 0
                          alankilian @Toastinator
                          @toastinator I'm not mailing you the motors and logic analyzer today because:
                          There's SNOW coming down!
                          • Neuromorphismundefined
                            Neuromorphism
                            Thank you to everyone who is working on this. I just received the JSS integrated steppers yesterday. Driving them from the external driver headers on a Duet 2 Maestro. Also will be used for CoreXY, in my case an FT6 conversion. That print quality example is concerning but I guess now that I have the motors I'll give them a try in the printer and see how it works for me. Running RRF 2.05, all I had to do was flip the enable polarity and the motor worked (though poorly for long move commands). Changed timings to 2:2:2:2 and now it works smoothly.
                            • Thunderrunnaundefined
                              Thunderrunna @taylo708
                              @taylo708 Is there any chance you could dm your config.g file and also wiring diagram for these motors on duet 3 and 1xd boards?
                              im rebuilding a printer that contains these motors on x and y and then z has an mks tb6600 driver.
                              im probably missing something simple but new to the whole duet ecosystem after playing around with marlin for so long.
                              Cheers
                              • A Former User?
                                A Former User
                                @Toastinator Hello, I tried to install ESS ProTuner software from that link but i think it's deleted from OneDrive. Could you tell me where can I find this software because I checked everywhere but i
