    Source for optical endstop switch?
    572
    • Falkiaundefined
      Falkia
      Anyone with a source for optical endstop switch that will work with 3.3V on Duet wifi?
      Printer: "Deltacus" Delta with 510mm bed diameter and 925mm build height. Powered by Duet 2 WiFi. Duet Smart Effector with E3D Volcano.
      alankilianundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Falkia
        @falkia THESE will work.
        You power the LED side with 5 Volts and pull the output up to 3.3 Volts.
        Are you looking for something particular?
        There are lots of optical interrupters so I'm sure we can find something for you.
        HERE'S a data sheet showing quite a few from this series.
        Falkiaundefined 1 Reply Last reply Reply Quote 0
        • mrehorstdmdundefined
          mrehorstdmd @Falkia
          @falkia I use these
          See: https://drmrehorst.blogspot.com/2020/01/ummd-gets-opto-endstops.html
          • JamesMundefined
            JamesM
            Both of these have worked for me with my duet 2 wifi boards but the second one is marked unavailable right now.
            https://www.amazon.com/gp/product/B07PMW2QMT/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
            https://www.amazon.com/gp/product/B07JMDLD84/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
            • Falkiaundefined
              Falkia @alankilian
              @alankilian
              This one have the connector in the direction that will fit the design of the printer I'm building. The specification doesn't say much.
              Do you think it will work?
              https://www.amazon.com/Opto-optical-Endstop-stop-Switch/dp/B06XHQ33DM
              SupraGuyundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
              • SupraGuyundefined
                SupraGuy @Falkia
                @falkia Those look exactly like the one that I'm using for my X axis.
                AFAIK, those were specced for 5V, but don't seem to have any difficulty at all on 3V3. I bought mine yonks ago before I even had a Duet, intending to use them with a RAMPS 1.4, but ... didn't. So they sat in a drawer while I used a mechanical endstop for a long time, until I got tired of it clicking. (Well, it was losing the little lever arm for the switch that finally did it, truth be told.) Then I replaced it with the optical, and it's been fine.
                As I recall, for the Duet I had to change the wiring order for the connector, I just popped 2 wires out and switched them around. As I recall, these come wired for GND, SIG, +5V, and the Duet is GND, +3V3, SIG, so the VCC and SIG wires needed to be swapped. The lower voltage didn't seem to bother it at all.
                Lead screw driven printer, powered by Duet 2 Wifi
                MPCNC powered by Duet 2 Wifi
                CoreXY printer driven by Duet 3 6HC
                LowRider CNC powered by Duet 2 Wifi
                  mrehorstdmd @Falkia
                  @falkia The one I linked above has a comparator chip that switches hard on/off when the endstop is triggered. Without that you have to rely on software debounce in the controller board (which may be there- I don't know).
                  • Falkiaundefined
                    Falkia @mrehorstdmd
                    @mrehorstdmd Looks good, unfortunately they seems to be unavailable everywhere.
                    MJLewundefined mrehorstdmdundefined 2 Replies Last reply Reply Quote 0
                    • MJLewundefined
                      MJLew @Falkia
                      @falkia Most (non-3D) broken or superseded printers have at least a couple of optical endstops, so scavenging is a good option.
                        mrehorstdmd @Falkia
                        @falkia search for LM393...
                        https://www.aliexpress.com/item/1005001651270935.html?spm=a2g0o.productlist.0.0.120761f3O2a3po&algo_pvid=b475fd98-2845-4e75-ba60-0e102e0381e3&algo_expid=b475fd98-2845-4e75-ba60-0e102e0381e3-9&btsid=0b0a556416180597947542620edafc&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                        https://www.aliexpress.com/item/1005001733350770.html?spm=a2g0o.productlist.0.0.120761f3O2a3po&algo_pvid=b475fd98-2845-4e75-ba60-0e102e0381e3&algo_expid=b475fd98-2845-4e75-ba60-0e102e0381e3-19&btsid=0b0a556416180597947542620edafc&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                        https://www.aliexpress.com/item/1005001548473877.html?spm=a2g0o.productlist.0.0.120761f3O2a3po&algo_pvid=c6edec3c-e556-44bc-ba69-2e6ec6ec53f9&algo_expid=c6edec3c-e556-44bc-ba69-2e6ec6ec53f9-11&btsid=0b0a555716180598980513323eca36&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                        • Falkiaundefined
                          Falkia
                          Thanks for all inputs. I ordered These. Supply voltage 3-6V and with LM393. Not the cheapest ones but located in Europe (shipping from China takes forever nowadays). I hope they will work. 🤔
