    Cura uses concentric circles to fill will be a layer of lag
    25
    1.8k
    • FLYundefined
      FLY
      After testing, the DUET2 motherboard will not vibrate when the heating is not turned on. When the heating is turned on, it will vibrate even if the set temperature is 0. What I get roughly means that as long as the E extruder is involved, it will vibrate.
      Test version 3.3 b1/3.3 b2
      • FLYundefined
        FLY @dc42
        @dc42 There is no advance squeeze setting found in my config,So duet officially needs to be tested
        • FLYundefined
          FLY @dc42
          @dc42 When the E command is close to 0, the gcode parser should ignore the value of E and only keep the XY parameter, which should solve this problem
          engikeneerundefined 1 Reply Last reply Reply Quote 0
          • engikeneerundefined
            engikeneer @FLY
            @fly post your config.g file (copy the text and use the code snippet tool). That way we can see any issues in there, and have a go at recreating the problem.
            i3 clone with a bunch of mods
            FLYundefined 1 Reply Last reply Reply Quote 0
            • FLYundefined
              FLY @engikeneer
              @engikeneer It has nothing to do with the configuration file, gcode parsing problem. You can test the gcode I sent, or modify the filling mode of cura.
              • FLYundefined
                FLY
                This is the configuration tested on my duet2 motherboard on ender3
                ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat Apr 17 2021 11:41:47 GMT+0800 (中国标准时间)
                M550 P"My Printer" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M569 P1 S0 ; physical drive 1 goes forwards
                M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                M84 S30
                M208 X230 Y210 Z200 S0 ; set axis maxima
                M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                • FLYundefined
                  FLY
                  This is the configuration I used on a large machine, using the stm32 motherboard, and using an external driver
                  ; Configuration file for Fly-E3 (firmware version 3)
                  ; generated by RepRapFirmware Configuration Tool v3.2.1-LPC on Mon Jan 18 2021 15:03:24 GMT+0800 (中国标准时间)
                  M569 P0 S1 T5.0:2.0:5:0.4 R1 ; physical drive 0 goes forwards using default driver timings
                  M569 P1 S0 T5.0:2.0:5:0.4 R1 ; physical drive 1 goes backwards using default driver timings
                  M569 P2 S1 T1.0:1.0:0.2:0.2 ; physical drive 2 goes forwards using A4988 driver timings
                  M569 P3 S0 T1.0:1.0:0.2:0.2 ; physical drive 3 goes forwards using A4988 driver timings
                  M569 P4 S0 T1.0:1.0:0.2:0.2
                  M584 X0 Y1 Z2 E3:4 ; set drive mapping
                  M92 X266.67 Y266.67 Z1600.00 E92.65:92.65 ; 脉冲
                  M566 X500.00 Y500.00 Z10.00 E80.00:80.00 ; 最大速度变化mm/秒
                  M203 X30000.00 Y30000.00 Z600.00 E4800.00:4800.00 ;最大速度 (mm/min)
                  M201 X700.00 Y700.00 Z100.00 E700.00:700.00 ; 加速度 (mm/s^2)
                  M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X600 Y600 Z63 S0 ; set axis maxima
                  M574 X2 S1 P"!xstopmax" ; configure active-high endstop for high end on X via pin !xstop
                  M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                  M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
                  M558 P9 H4.5 F360 T8000 C"^probe" ; disable Z probe but set dive height, probe speed and travel speed
                  M557 X15:565 Y15:565 S28 ;
                  G31 P1000 X-30. 5 Y-3 Z2.891 ;
                  M950 S0 C"servo0" ;
                  M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
                  M307 H0 R0.162 C136.2 D3.10 S1.00 V0.0 ; disable bang-bang mode for the bed heater and set PWM limit
                  M307 H1 R2.457 C230.3 D4.65 S1.00 V0.0 ; disable bang-bang mode for heater and set PWM limit
                  M563 P1 D1 H1 F0 ; define tool 1
                  G10 P1 R0 S0
                  M575 P1 S0 B57600
                  T0 ; select first tool
                  M280 P0 S160
                    engikeneer @FLY
                    @fly I just ran your gcode files on my machine. CoreXY with Duet Wifi on RRF3.2.2.
                    other.gcode seems to have printed fine - smooth & no jerking motion at all.
                    second-lap.gcode does produce a vibrating motion like you describe. If however, I slow it down a lot (e.g. to 20%), the motion it smooth, but I can see the circle it prints isn't quite perfect (you can see the facets from the stl file and the line width varies a little)
                    I think that the issue you are seeing is related to some non-uniform extrusion rate as DC42 suggested. You can see in the snippet of the gcode you posted that the extrusion rate is varying. It jumps from ~0.01438mm to 0.00005mm in one line (line 16 to 17), so it goes from extruding to stopping, then back to extruding again in three lines of gcode (in about 10ms of time at a motion speed of 4800mm/min). I calculate that as a speed change of about 160mm/min inboth directions for your extruder (-160mm/min then +160mm/min) which is higher than your jerk setting of 120mm/min (and 80mm/min on the other printer). There are some even higher jumps in the problem file looking at your graphs. The extruder has to be able to keep up with the motion requested and will slow/stop the xyz motion if it can't. Again, as DC42 said, if you have any pressure advance set (I do), this may make things worse as the pressure advance will be applied on top of the extisting fluctuations. All this is the Duet behaving as expected I think.
                    So your options are:
                    • Increase your extruder jerk (M566) significantly so that it doesn't impact/limit the motion planning
                    • Change your slicer settings so the gcode they output is more consistent (e.g. alter your line widths so the additional line is a more consitent size like @mrehorstdmd suggested)
                    • Change your stl file. It might be that the facets on the inner/outer surfaces are making the rim thickness of your part vary, hence the problem line has all these non-uniform extrusion rates.
                      Seems like expected behaviour from Cura actually. How it handles single width fill lines is pretty abysmal.
                      You can try this version of Cura that has some fixes for that behaviour. https://github.com/smartavionics/Cura/releases
                      Or try Prusa Slicer which has really good gap fill behaviour by comparison.
                      • FLYundefined
                        FLY @engikeneer
                        @engikeneer The M83 command is used in the gcode of RRF, which is not 0.01438mm to 0.00005mm. After extruding 0.01438mm, it will extrude 0.00005mm relative to 0.01438mm.
                        Modifying the speed and acceleration of the extruder is invalid. I have tried it many times.
                        Running this kind of gcode in marlin firmware will not have this use case, so I think the firmware program may also have bugs.
                        • giostarkundefined
                          giostark @mrehorstdmd
                          @mrehorstdmd said in Cura uses concentric circles to fill will be a layer of lag:
                          @fly Try tweaking the line width and reslice.
                          @phaedrux said in Cura uses concentric circles to fill will be a layer of lag:
                          Also if Cura is an amazing program is not perfect. I'm agree...the issue is in Cura. I lost age to try to figure it out and even on the Ultimaker forum there is no solution.
                          Just try to use different width for internal or external lines (or for the nozzle in general - 0,41 etc - , find the right combo and save the profile for this specific part). Sometime we expect that the program is capable to slice as better as we can image but it is not.
                          The vibration is generated by the slicer because the mess of micro variations. For my delta I can confirm this. (hundreds of attempts)
                          The concentric patter is the worst in Cura. (just in case, disable "spiralized", it is good for vase but not for thick wall with infill)
                            engikeneer @FLY
                            @fly my calculations are still correct. To extrude 0.01438mm in the short segments yor gcode has at 4800mm/min, the extruder has to be moving at about 160mm/min. For the next line, to extrude 0.00005mm, the extruder has to be moving at about 0mm/min. Then on the following line it is back up to 160mm/min. It never goes backwards, but that is a significant change in speed required (both decelerating then accelerating) and is larger than your extruder jerk.
                            How comparable are your extruder accel, speed & jerk settings on your Marlin machine?
                            There may be some differences in how Marlin and RRF work (e.g. are you using the Marlin junction deviation?), but fundamentally RRF will respect the motion limits for every axis (including the extruder) and will slow down the motion if these are being violated.
                              Looks like Cura is finally addressing this issue with a slicing engine overhaul. Beta available now with variable line width.
                              https://support.ultimaker.com/hc/en-us/articles/360018439500-Ultimaker-Cura-Arachne-engine-beta-version
                              giostarkundefined 1 Reply Last reply Reply Quote 2
                              • giostarkundefined
                                giostark @Phaedrux
                                Interesting phaedrux ! Soon as possible I'll try it. Now I'm stuck in other troubles that keep me far from the 3D printing world but I'll have to put me in soon or later. I also have near 4K of coreXY in pieces that wait just to be assembled.
                                  jay_s_uk @FLY
                                  @fly
                                  I can confirm that this appears to be fixed in Cura 4.9 beta.
                                  This is a snip-it of infill from cura 4.8. I ran it through Arc welder. 80% concentric infill
                                  ;TYPE:FILL
                                  G3 X114.491 Y161.707 I-0.437 J-48.369 E0.09073 F3000
                                  G1 X114.491 Y161.708 E0.00003
                                  G3 X112.776 Y161.573 I2.616 J-44.197 E0.04541
                                  G1 X112.776 Y161.574 E0.00003
                                  G3 X111.066 Y161.378 I5.309 J-53.877 E0.04543
                                  G1 X111.066 Y161.379 E0.00003
                                  G3 X108.528 Y160.977 I6.489 J-49.181 E0.06786
                                  G1 X108.528 Y160.978 E0.00003
                                  G1 X107.692 Y160.815 E0.02248
                                  G1 X107.692 Y160.814 E0.00003
                                  G3 X101.451 Y159.114 I9.691 J-47.883 E0.17088
                                  G1 X101.451 Y159.115 E0.00003
                                  G3 X99.830 Y158.525 I16.258 J-47.191 E0.04555
                                  G1 X99.83 Y158.526 E0.00003
                                  G1 X99.434 Y158.371 E0.01122
                                  G1 X99.434 Y158.37 E0.00003
                                  G3 X92.106 Y154.756 I17.921 J-45.575 E0.21591
                                  G1 X92.106 Y154.757 E0.00003
                                  G1 X91.742 Y154.536 E0.01124
                                  G1 X91.742 Y154.535 E0.00003
                                  G3 X78.125 Y142.167 I25.749 J-42.029 E0.48848
                                  G1 X78.124 Y142.168 E0.00004
                                  G3 X75.241 Y137.890 I39.556 J-29.768 E0.13622
                                  G1 X75.242 Y137.89 E0.00003
                                  G3 X69.278 Y122.752 I42.239 J-25.385 E0.43148
                                  G1 X69.279 Y122.752 E0.00003
                                  G3 X69.105 Y121.905 I72.866 J-15.410 E0.02282
                                  G1 X69.106 Y121.905 E0.00003
                                  G3 X68.621 Y118.934 I49.398 J-9.589 E0.07949
                                  G1 X68.622 Y118.934 E0.00003
                                  G3 X68.426 Y117.224 I55.533 J-7.231 E0.04544
                                  G1 X68.427 Y117.224 E0.00003
                                  G3 X68.292 Y115.509 I44.062 J-4.331 E0.04541
                                  G1 X68.293 Y115.509 E0.00003
                                  G3 X68.293 Y109.491 I48.658 J-3.009 E0.15896
                                  G1 X68.292 Y109.491 E0.00003
                                  G3 X68.427 Y107.776 I44.197 J2.616 E0.04541
                                  G1 X68.426 Y107.776 E0.00003
                                  G3 X68.622 Y106.066 I53.877 J5.309 E0.04544
                                  G1 X68.621 Y106.066 E0.00003
                                  G3 X69.021 Y103.533 I49.888 J6.580 E0.06772
                                  G1 X69.02 Y103.533 E0.00003
                                  G3 X70.886 Y96.451 I48.980 J9.119 E0.19368
                                  G1 X70.885 Y96.451 E0.00003
                                  G1 X71.004 Y96.108 E0.00958
                                  G1 X71.045 Y96.067 E0.00153
                                  G1 X71.045 Y95.994 E0.00193
                                  G1 X71.172 Y95.641 E0.0099
                                  G1 X71.173 Y95.641 E0.00003
                                  G3 X71.494 Y94.849 I6.106 J2.014 E0.02269
                                  G1 X71.494 Y94.779 E0.00185
                                  G1 X71.629 Y94.434 E0.00978
                                  G1 X71.63 Y94.434 E0.00003
                                  G3 X75.242 Y87.110 I45.520 J17.897 E0.21581
                                  G1 X75.241 Y87.11 E0.00003
                                  G1 X75.462 Y86.746 E0.01124
                                  G1 X75.463 Y86.746 E0.00003
                                  G3 X78.124 Y82.832 I41.949 J25.658 E0.12497
                                  G1 X78.125 Y82.833 E0.00004
                                  G3 X92.106 Y70.243 I39.455 J29.756 E0.49970
                                  G1 X92.106 Y70.244 E0.00003
                                  G3 X98.235 Y67.119 I25.448 J42.338 E0.18176
                                  G1 X98.235 Y67.12 E0.00003
                                  G3 X107.248 Y64.278 I19.269 J45.397 E0.24985
                                  G1 X107.248 Y64.279 E0.00003
                                  G3 X111.066 Y63.621 I10.367 J48.747 E0.10232
                                  G1 X111.066 Y63.622 E0.00003
                                  G3 X112.776 Y63.426 I7.231 J55.533 E0.04544
                                  G1 X112.776 Y63.427 E0.00003
                                  G3 X114.491 Y63.292 I4.331 J44.062 E0.04541
                                  G1 X114.491 Y63.293 E0.00003
                                  G3 X120.509 Y63.293 I3.009 J48.705 E0.15896
                                  G1 X120.509 Y63.292 E0.00003
                                  G3 X122.224 Y63.427 I-2.616 J44.197 E0.04541
                                  G1 X122.224 Y63.426 E0.00003
                                  G3 X123.934 Y63.622 I-5.309 J53.877 E0.04543
                                  G1 X123.934 Y63.621 E0.00003
                                  G3 X126.472 Y64.023 I-6.489 J49.181 E0.06786
                                  G1 X126.472 Y64.022 E0.00003
                                  G1 X127.308 Y64.185 E0.02248
                                  G1 X127.308 Y64.186 E0.00003
                                  G3 X133.549 Y65.886 I-9.704 J47.930 E0.17087
                                  G1 X133.549 Y65.885 E0.00003
                                  G3 X135.170 Y66.475 I-16.258 J47.191 E0.04555
                                  G1 X135.17 Y66.474 E0.00003
                                  G1 X135.566 Y66.629 E0.01122
                                  G1 X135.566 Y66.63 E0.00003
                                  G3 X142.890 Y70.242 I-17.897 J45.520 E0.21579
                                  G1 X142.89 Y70.241 E0.00003
                                  G1 X143.254 Y70.462 E0.01124
                                  G1 X143.254 Y70.463 E0.00003
                                  G3 X147.168 Y73.124 I-25.658 J41.949 E0.12498
                                  G1 X147.167 Y73.125 E0.00004
                                  G3 X159.757 Y87.106 I-29.686 J39.391 E0.49967
                                  G1 X159.756 Y87.106 E0.00003
                                  G3 X162.881 Y93.235 I-42.338 J25.448 E0.18176
                                  G1 X162.88 Y93.235 E0.00003
                                  G3 X165.722 Y102.248 I-45.311 J19.242 E0.24987
                                  G1 X165.721 Y102.248 E0.00003
                                  G3 X166.574 Y107.772 I-48.297 J10.286 E0.14760
                                  G1 X166.573 Y107.772 E0.00003
                                  G3 X166.707 Y115.509 I-48.955 J4.718 E0.20448
                                  G1 X166.708 Y115.509 E0.00003
                                  G3 X166.573 Y117.224 I-44.197 J-2.616 E0.04541
                                  G1 X166.574 Y117.224 E0.00003
                                  G3 X166.378 Y118.934 I-53.877 J-5.309 E0.04544
                                  G1 X166.379 Y118.934 E0.00003
                                  G3 X165.979 Y121.467 I-49.888 J-6.580 E0.06772
                                  G1 X165.98 Y121.467 E0.00003
                                  G1 X165.815 Y122.308 E0.02262
                                  G1 X165.814 Y122.308 E0.00003
                                  G3 X165.008 Y125.674 I-47.136 J-9.507 E0.09140
                                  G1 X165.009 Y125.674 E0.00003
                                  G3 X164.114 Y128.549 I-48.374 J-13.482 E0.07949
                                  G1 X164.115 Y128.549 E0.00003
                                  G3 X163.525 Y130.170 I-45.295 J-15.568 E0.04555
                                  G1 X163.526 Y130.17 E0.00003
                                  G1 X163.371 Y130.566 E0.01122
                                  G1 X163.37 Y130.566 E0.00003
                                  G3 X159.758 Y137.890 I-45.520 J-17.897 E0.21581
                                  G1 X159.759 Y137.89 E0.00003
                                  G1 X159.538 Y138.254 E0.01124
                                  G1 X159.537 Y138.254 E0.00003
                                  G3 X156.876 Y142.168 I-41.949 J-25.658 E0.12497
                                  G1 X156.875 Y142.167 E0.00004
                                  G3 X142.894 Y154.757 I-39.386 J-29.680 E0.49970
                                  G1 X142.894 Y154.756 E0.00003
                                  G3 X136.765 Y157.881 I-25.448 J-42.338 E0.18176
                                  G1 X136.765 Y157.88 E0.00003
                                  G3 X127.752 Y160.722 I-19.269 J-45.397 E0.24985
                                  G1 X127.752 Y160.721 E0.00003
                                  G3 X123.934 Y161.379 I-10.367 J-48.747 E0.10232
                                  G1 X123.934 Y161.378 E0.00003
                                  G3 X122.224 Y161.574 I-7.231 J-55.533 E0.04544
                                  G1 X122.224 Y161.573 E0.00003
                                  G3 X120.509 Y161.708 I-4.331 J-44.062 E0.04541
                                  G1 X120.509 Y161.707 E0.00003
                                  G3 X117.926 Y161.798 I-2.993 J-48.256 E0.06823
                                  G0 F9000 X117.942 Y161.198
                                  G2 X117.517 Y161.200 I-0.442 J-48.698 E8.06554 F3000
                                  G1 X117.942 Y161.198 E0.01122
                                  This is that same layer infill from Cura 4.9 beta. Again ran through arc welder. All settings the same.
                                  ;TYPE:FILL
                                  G3 X120.509 Y161.708 I-0.425 J-49.298 E8.10794 F3000
                                  G3 X117.926 Y161.798 I-3.012 J-49.328 E0.06823
                                  G2 X117.517 Y161.200 I-0.442 J-48.698 E8.06558 F3000
                                  I air printed both, the stuttering is present with the first full gcode but not the second.
                                  • IndeX4Dundefined IndeX4D referenced this topic
