    BtnCmd-DWC Plugin - Customise DWC - v01.04.00 29-05-25
    Plugins for DWC and DSF
    27
    245
    40.0k
    • cosmowaveundefined
      cosmowave @MintyTrebor
      @mintytrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.13 11-07-22:
      Have an input panel to set the variable value (in your case retraction length)
      Have a button to run a macro that sets retraction length using the global variable
      Yes... Thats my actual use case
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
      MintyTreborundefined 1 Reply Last reply Reply Quote 0
      • o_lampeundefined o_lampe referenced this topic
      • MintyTreborundefined
        MintyTrebor @cosmowave
        Released Beta 0.10.14
        Changes:
        • Bug fixes and improvements to the Global Variable Input Panel, specifically addressing the alignment issues of switches, and right aligned variable values.
        https://github.com/MintyTrebor/BtnCmd/releases
        NodeDSF - Native Node-Red integration with Duet boards.
        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
        ReleaseMgr - Duet update info inside DWC.
        Repo
        moth4017undefined 1 Reply Last reply Reply Quote 2
        • moth4017undefined
          moth4017 @MintyTrebor
          @MintyTrebor
          Thanks for the update
            MintyTrebor @moth4017
            Released Beta 0.10.15
            Changes:
            • New Panels : Jobs List, Macro List, Events List
            • Alt Web Cam Panel - New option to add a button on the webcam image to open an external page - use to open config pages for various webcam services, eg Motion.
            • Global Setting : Auto Start BtnCmd - Automatically switch to BtnCmd when DWC loads
            • Global Setting : Change DWC Top Bar Color
            Repo
            • falco22undefined
              falco22
              Hello, first of all, excellent plugin! I have a question. configure the plugin as I want, but when sending to print, it automatically goes to the default status screen of the webcontrol. Is it possible to stay in the custom tabs? I hope it has been understood.
                MintyTrebor @falco22
                @falco22 If you are referring to the Job list Panel - then it will be using standard DWC behaviour to switch views on job start.
                Repo
                falco22undefined 1 Reply Last reply Reply Quote 0
                • falco22undefined
                  falco22 @MintyTrebor
                  @MintyTrebor said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.15 06-11-22:
                  No, I mean, when I print a file, it goes directly to the status panel in dwc, and I would like it to stay in the Btncmd panel
                  cosmowaveundefined 1 Reply Last reply Reply Quote 0
                    cosmowave @falco22
                    @falco22 I think, you don't understand correctly what @MintyTrebor means...
                    He means, that the job panel in DWC, where you start the job, is not under his control.
                    After starting a job it is standard for DWC to jump to status screen. MintyTrebor can only change the BtnCmd plugin.
                    • CrazyCreatorundefined
                      CrazyCreator
                      What ist the right MQTT Message and MQTT Topic for switching my shelly switch?
                      Or can i find a tutorial for creating this button in BtnCmd?
                      http://www.crazycreatorcube.com
                        MintyTrebor @CrazyCreator
                        @CrazyCreator I do not own a shelly switch so I cannot advise.
                        BtnCmd Wiki is available for reference.
                        Have you tried using a http post/get button using the commands you identified yourself in your post: https://forum.duet3d.com/post/300999?
                        Repo
                        Nightowlundefined stuartofmtundefined 2 Replies Last reply Reply Quote 0
                        • Nightowlundefined
                          Nightowl @MintyTrebor
                          Hi @MintyTrebor
                          I looked at this earlier on in my CNC career(!) but have just started to 'play' with it to set up my own screens.
                          I've stumbled on a couple of minor issues, which are probably of my own making, but how would you like me to ask you about them? On this forum or via PM?
                          Thank you 👍
                          Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
                          I'm still on my learning curve, so take everything I say with caution!
                          RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
                          MintyTreborundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                            MintyTrebor @Nightowl
                            @Nightowl Here is fine
                            Repo
                            Nightowlundefined 1 Reply Last reply Reply Quote 0
                              jay_s_uk @Nightowl
                              @Nightowl we also have a BtnCmd support channel on the Teamgloomy discord if you're into that type of thing https://discord.gg/uS97Qs7
                              • Nightowlundefined
                                OK thanks, @MintyTrebor
                                It's probably me, but when I try to design my own page, it looks like this, in design mode:
                                ....but like this, when I Save and Exit:
                                Weeble (does it have to be all caps?) reverts to Layout 1 and the Machine Movement window moves back to the LH upper corner.
                                PS Sorry for the delay in responding. It seems I'm not receiving notifications from this thread (but I am subscribed!)
                                • Nightowlundefined
                                  Nightowl @jay_s_uk
                                  Thanks, @jay_s_uk, I'll check it out.
                                    @Nightowl said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.15 06-11-22:
                                    It's probably me
                                    I think it is 😉
                                    The red text indicates you are creating a custom panel, not a page/tab layout. A custom panel is a way for you to design your own panel that can be used in multiple page/tab layouts.
                                    When in edit mode there are two options
                                    Create & Edit custom panels (red)
                                    Create & Edit Layouts (Green)
                                    This is all covered in the wiki
                                    If you enter Create & Edit Layouts mode (green) you can rename the tab and place the movement panel wherever you like. You should also find if you select add custom panel there will probably be one called "WEEBLE" which will the the custom panel you have created.
                                    Repo
                                    • Nightowlundefined
                                      I think it is
                                      Ha! Told you! 😵
                                      I'll get on it tomorrow - I'm frazzled at the moment (with other stuff!)
                                      • stuartofmtundefined
                                        stuartofmt @MintyTrebor
                                        @CrazyCreator
                                        I own multiple shelly switches, I recommend them. I use one to remotely turn on / off my printer.
                                        Use http get i.e. just "request" the url's you already identified. Post is not needed.
                                        CrazyCreatorundefined 1 Reply Last reply Reply Quote 0
                                          CrazyCreator @stuartofmt
                                          @stuartofmt said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.15 06-11-22:
                                          What is your configuration on BtnCmd Settings?
                                          And this is the config for the button
                                          With this config i can switch the status of my shelly. 😉 but i see a error in DWC
                                          and how can i use this in my gcode for power off the printer after print?
                                          stuartofmtundefined MintyTreborundefined 2 Replies Last reply Reply Quote 0
                                            stuartofmt @CrazyCreator
                                            @CrazyCreator said in BtnCmd-DWC Plugin-Custom Layouts & Buttons - v0.10.15 06-11-22:
                                            @stuartofmt said in [BtnCmd-DWC Plugin-Custom Layouts &
                                            My post was simply to remove any ambiguity about Get v Post. I do not have BtnCmd setup at the moment as I am in the process of rebuilding.
                                            @MintyTrebor can likely resolve the question on the error code.
                                            I switch off my printer using a different method that pre-dates BtnCmd. I'm unsure if there is a conditional http get based on an object model value. I recall there is one for http Post.
                                            Its possible you could use http Post on Shelley. You could research that here:
                                            https://shelly-api-docs.shelly.cloud/gen2/ComponentsAndServices/HTTP/
