No WiFi this morning !?
This morning made me to wake up !
No Wfi ! Did work yesterday evening
M552 S1 and back to business, but no ....What is going on here
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.3RC2 (2021-05-11 14:55:40) running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: J8ZB5-U296U-D65J0-40KML-NP03Z-H7HL5
Used output buffers: 3 of 40 (18 max)
Static ram: 102476
Dynamic ram: 104708 of which 420 recycled
Never used RAM 36100, free system stack 138 words
Tasks: NETWORK(ready,16.4%,240) HEAT(delaying,0.0%,385) Move(notifyWait,0.1%,338) CanReceiv(notifyWait,0.0%,907) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,348) TMC(notifyWait,0.7%,115) MAIN(running,82.0%,384) IDLE(ready,0.0%,29) AIN(delaying,0.8%,273), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:58:59 ago, cause: power up
Last software reset at 2021-05-25 15:02, reason: User, GCodes spinning, available RAM 34900, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
MCU revision 3, ADC conversions started 3540000, completed 3540000, timed out 0, errs 0
Step timer max interval 1490
MCU temperature: min 24.7, current 25.4, max 25.8
Supply voltage: min 23.8, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 61230, writes 0, timeouts 0, DMA errors 0
Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 61230, writes 0, timeouts 0, DMA errors 0
Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 61229, writes 0, timeouts 0, DMA errors 0
Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 61229, writes 0, timeouts 0, DMA errors 0
Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 61230, writes 0, timeouts 0, DMA errors 0
Driver 5: position 0, assumed not present
Driver 6: position 0, assumed not present
Date/time: 2021-05-26 08:55:00
Slowest loop: 6.69ms; fastest: 0.11ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.8ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = -1 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 5817, send timeouts 0, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 25677, free buffers 17 (min 17)
=== Network ===
Slowest loop: 200.81ms; fastest: 0.08ms
HTTP sessions: 2 of 8- WiFi -
Network state is active
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.24beta2-05b1
WiFi MAC address f4:cf:a2:6f:be:16
WiFi Vcc 3.40, reset reason Power up
WiFi flash size 2097152, free heap 26400
WiFi IP address 192.168.1.219
WiFi signal strength -64dBm, mode none, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
config.g missing !!! Where can this file hide?
@tecno is there a file called config.bak?
Morning Jay,
Have copy on my PC but not 100% updated, so now there is a .bak file
Noticed that filaments is empty./Bengt
Now X and Y are moving in wrong direction (I know the did work OK with that copy of config.g
What is going on here?
@tecno said in No WiFi this morning !?:
Check the forum, there are others with SD-Card issues on Duet Mini5. Might be a bad batch or soldering issues?
Got it all sorted out .................. phuu
How do I ge a backup of 0:/system ?
How to move firmware files to 0:/firmware ?
@tecno you can either tick the little check box at the top of the system files tab and then right click and download as zip or you can use something like FTP to download everything. There is a utility for this here
To move things to the firmware folder its going to be a case of deleting whatever is present in system and let the firmware handle it going forwards. Or pull the sd card and manually move the files over
Right clikck > download does not exist here! Did read about it but nothing here. That would someting I prefere rather that be using RFM.
Is this a bug in latest RC ?
ps. Why do I get ERROR down in right corner when I want to Submit?? I have to restart forum
@tecno I get that restart error sometimes when submitting
latest RC
Make sure you right click in the area of the files, not on the tick box itself -
This is what I get
@tecno you can't download directories as part of the zip. uncheck them and you should be good to go
Thank you very much Jay, much appreciated!
Your wifi server version needs to be updated.
Place this bin file in your firmware folder and then boot up and send M997 S1 to re-flash the wifi module.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.3RC3/DuetWiFiServer.bin
Then check M122 again it should show the wifi server version as 1.26.
Well here I am again with no connection with my Mini 5+ other that terminal connects but accepts no commands at all !
Urgent help needed how to proceed .
@tecno
You might need a USB hub to have enough power to feed the Duet? Just guessing...
What kind of commands did you try? -
@tecno
Fair enough. What about M115 or M122? Just to see, if the SD-card has been read or not -
Anyone to help me?
