    Vertical banding on COREXY machine
    72
    6.1k
    • Egon.Netundefined
      Egon.Net @zabana
      @zabana said in Vertical banding on COREXY machine:
      @o_lampe as time pass and the more test I do I am more convinced that thus is something related on how the firmware process small ammounts of filament extrusion and send the steps pulses to the stepper, because if the requested ammount to ve extruder is the same but faster seems to be ok or if the ammount to be extruded is higher due to 0.4 layer height instead 0.2
      Maybe someone can give light about it...
      Maybe inertia at high speed solving a lack of microstepping torque at slow speed?
      • o_lampeundefined
        o_lampe @zabana
        @zabana
        If it turns out, Klipper produces better results even without acceleration sensor/input shaper, it would be interesting to compare the e-step pulses on a scope. It can't be hardware related then, so it's in the code. Although @droftart confirmed, both FW use the same default settings for stealthchop: it's what you make of it...
        Faster extrusion makes the driver change from stealthchop to spreadcycle mode and suddenly your result looks better...? Why can't we switch off stealthchop for extruders?
        Egon.Netundefined zabanaundefined gloomyandyundefined 3 Replies Last reply Reply Quote 0
        • Egon.Netundefined
          Egon.Net @o_lampe
          @o_lampe said in Vertical banding on COREXY machine:
          @zabana
          That would be very interesting. I'm suffering resonance at lowish speeds, and I wonder if there could me some slight mistimming in the step signals that klipper got better.
          • zabanaundefined
            zabana @o_lampe
            @o_lampe if I am right the duet wifi is not on stealth but in spread so if it does is not programmable or modificable.
            This afternoon will try because just in case with absurd high jerks and accelerations on the extruder
            • gloomyandyundefined
              gloomyandy @o_lampe
              @o_lampe In this case (using a Duet WiFi) the drivers (TMC2660) do not support stealthchop so switching is not likely to be an issue.
              What makes you think that you can't set an extruder driver to be in spreadcycle mode all of the time (on boards that have drivers that support both modes)? As far as I'm aware there is nothing to stop you using the D2 option to M569 with a driver that will be used as an extruder.
              • o_lampeundefined
                o_lampe @gloomyandy
                @gloomyandy
                my remarks were about the various threads about vertical lines. Other users with Duet3 Mini have reported similar issues, so I thought it was worth mentioning.
                It's good to know, that there's a way to modify driver settings. It's the first time someone mentioned it in this context.
                • o_lampeundefined
                  o_lampe @zabana
                  @zabana
                  They don't have to be absurd high, just enough so they aren't the bottleneck in the whole motion.
                  zabanaundefined 1 Reply Last reply Reply Quote 0
                  • zabanaundefined
                    zabana @o_lampe
                    @o_lampe yes, I know, and now they are good enough but because just in case I will try it but doesn't have too much espectation about it solving the problem.
                      Is that a self-made extruder design?
                      • zabanaundefined
                        zabana @Phaedrux
                        @phaedrux it is the sherpa mini but instead to print the original pieces I modded then to be integrated in the carriage instead to print separately and bolt it to the frame so the internal geometry and such is everything totally the same so that´s why it should work as well as any other sherpa mini.
                        • zabanaundefined
                          zabana
                          Latest tests I did:
                          • Printed in 1/8 instead 1/32
                          • Disabled P.A
                          • Increased steps so in full steps is a round number of 44 instead 43.1825
                          • Increased jerk from 600 to 3600 and acceleration from 1000 to 3000
                          • Increased current from 750 to 1300.
                          • Normally my current line in config.g is M906 X1600.00 Y1600.00 Z1700.00 E700.00 I30 but tried without the I30
                          • Disabled M592 command
                          • Tried M593 F90.90 (there are 3 rippling per mm at 30mm/s so 30/0.33= 90.90)
                          I did each change separately and no one of them improved the print quality so everything the same.
                          I also noticed that at slow speed if I print a 40mm diameter cilinder (not vase mode) it doesn´t show the pattern so probably because the direction changes to draw the circle in each layer so the extruder works different than in a straigh line like in the cubes, if I print faster then it shows normal ringing due acceleration and deceleration. So maybe something related to any kind of ahead look planification in the lines printing? thinking_face:
                          • zabanaundefined
                            zabana
                            I just tried now changing Jerk Policy to 1 with this command M566 X600.00 Y600.00 Z600.00 E600.00 P1 and it didn´t work neither...
                            Just in case it helps my M122 shows this:
                            m122
                            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3RC2 (2021-05-11 14:55:01) running on Duet WiFi 1.02 or later + DueX5
                            Board ID: 08DGM-917NK-F2MS4-7J1FA-3S46Q-THS0D
                            Used output buffers: 3 of 24 (20 max)
                            Static ram: 23876
                            Dynamic ram: 75568 of which 0 recycled
                            Never used RAM 12116, free system stack 124 words
                            Tasks: NETWORK(ready,13.3%,211) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,277) DUEX(notifyWait,0.0%,24) MAIN(running,86.1%,445) IDLE(ready,0.5%,29), total 100.0%
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:01:01 ago, cause: software
                            Last software reset at 2021-06-02 21:53, reason: User, GCodes spinning, available RAM 11940, slot 0
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Step timer max interval 0
                            MCU temperature: min 28.0, current 28.2, max 28.9
                            Supply voltage: min 23.1, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/12/0, gc cycles 0
                            Driver 0: position 74496, ok, SG min/max 0/123
                            Driver 1: position 18304, ok, SG min/max 0/121
                            Driver 2: position 663, ok, SG min/max 0/1023
                            Driver 5: position 0, ok, SG min/max 0/38
                            Driver 6: position 0, standstill, SG min/max not available
                            Driver 7: position 0, standstill, SG min/max not available
                            Driver 8: position 0, standstill, SG min/max not available
                            Driver 9: position 0, standstill, SG min/max not available
                            Driver 10: position 0
                            Driver 11: position 0
                            Date/time: 2021-06-02 21:54:27
                            Cache data hit count 2049737558
                            Slowest loop: 125.67ms; fastest: 0.16ms
                            === Storage ===
                            Free file entries: 9
                            SD card longest read time 1.0ms, write time 2.4ms, max retries 0
                            DMs created 83, maxWait 40009ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 54, completed moves 48, hiccups 1, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                            === AuxDDARing ===
                            Heater 0 is on, I-accum = 0.2
                            Heater 1 is on, I-accum = 0.5
                            Segments left: 1
                            Movement lock held by null
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is idle in state(s) 3
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Code queue is empty.
                            === DueX ===
                            Read count 1, 0.97 reads/min
                            === Network ===
                            Slowest loop: 157.74ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            • WiFi -
                              Network state is active
                              WiFi firmware version 1.26
                              WiFi MAC address b4:e6:2d:53:14:72
                              WiFi Vcc 3.41, reset reason Power up
                              WiFi flash size 4194304, free heap 26136
                              WiFi IP address 192.168.1.41
                              WiFi signal strength -35dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                            • DonStaufferundefined
                              DonStauffer @zabana
                              @zabana Remarkable.
                              I never would have thought doubling the printing speed would vastly IMPROVE a defect! But even these bad pictures show that. (I know, I've got ringing to deal with, but before it was hard to separate that from the stripes):
                              • mrehorstdmdundefined
                                mrehorstdmd
                                Maybe you're over extruding and at the higher speed the extruder can't keep up, so extrusion is reduced. Try the lower speed print with extrusion reduced.
                                DonStaufferundefined zabanaundefined 2 Replies Last reply Reply Quote 0
                                  DonStauffer @mrehorstdmd
                                  @mrehorstdmd It's not merely overextruded. The extrusion is periodic, like a sine wave. Even if overextruded, there shouldn't be periodic variation. I've played with extrusion and I've got it about perfect for PETG. My solid fill meets up with neither a ridge nor a valley (thought I think a difference in sheen is mostly my slicer). This is also the exact same pattern I've seen others have - all with Duet hardware.
                                  As the contributor above mentioned, this uneven extrusion at low levels seems to be firmware-related, hence the improvement with layer height as well as speed, and the 100% improvement when people go to Klipper.
                                  DonStaufferundefined 1 Reply Last reply Reply Quote 0
                                    DonStauffer @DonStauffer
                                      @donstauffer I wonder, if acceleration is done in "quanta", rather than smoothly (it almost has to - digital computers), could this be the incrementing of speed from acceleration being "out of phase" between extruder and XY? Imagine, extrusion increases, then speed, then extrusion, then speed, etc. You'd get a pulsing effect, in terms of extrusion per mm travel. Except then it would only happen when speed is changing, I guess. Well, just a thought.
                                      • zabanaundefined
                                        zabana @mrehorstdmd
                                        @mrehorstdmd no, that's not the reason, if I were overextruding the perimeter will be higher than 0.4mm I set but consistent and that's not the point and also y speed is double or later height double should show another different issues.
                                        DonStaufferundefined 1 Reply Last reply Reply Quote 1
                                        • zabanaundefined
                                          zabana @DonStauffer
                                          @donstauffer I don't know, that's out of my knoledge. What I can say is I inspected the gcode file and the gcode for the cube sides is go from A to B extruding C ammount of plastic at F speed so the extruder has one only order to follow and the cilinder has small tiny segments to be printed in the same way, if I can this afternoon will try to print a cube of 20mm and another of 80mm to see if it vary something but I think it will not.
                                          Maybe @dc42 can shed some light to this issue 🙂
                                            DonStauffer @zabana
                                            @zabana This is problematic, because I can't do much about regular ringing without low acceleration, but I can't eliminate this banding without at least 1200 acceleration, I assume because lower accelerations slow down printing. My ringing is at around 60Hz, and DAA at that frequency reduces it, but it must lower acceleration too much because the banding returns. My jerk is already around 300, and any lower seems to mess up corners without improving ringing.
                                            So right now, the best I can do seems to be to have moderate ringing (reasonably high acceleration), or mild ringing and moderate to severe banding (rather low acceleration). And I don't have the option I do on my other printer to slow printing down to get nice prints.
                                            PA between 0.15 and 0.20 seems to have helped basic print quality at high speed, so that at least enables me to print fast so I have minimal banding. I just have to tolerate moderate ringing.
                                            I have no ideas what else to try, except to consider Klipper.
