    Mini5+ BT dongle for transmit.
    Using Duet Controllers
    815
    • tecnoundefined
      tecno
      Need to fix a camera trigger for timelaps. I prefer BT instead of cable if possible.
      1. BT dongle
      2. IO - cable - isolation - earplug on my Xperia (isolation = relay driven from IO)
      3. IO - cable - BT remote (remote driven from IO 3V)
      Prefere #1 solution if possible.
      Cheers
      Bengt
        I'm not sure what you're asking.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @Phaedrux
          @phaedrux
          1 Can I use M42 to send triggersignal via BlueTooth?
          2/3 are possible but not preferred
            I'm not aware of any Duet compatible bluetooth dongle. Do you have something in particular in mind?
            • fcwiltundefined
              fcwilt @tecno
              @tecno said in Go / No go? Mini5+ BT dongle for transmit.:
              @phaedrux
              You can use M118 to send data over a Telnet connection.
              I've used that to send to an application which is waiting for the data and performs desired actions.
              • tecnoundefined
                tecno @Phaedrux
                @phaedrux
                Cambridge Silicon Radio Ltd. This is a generic BT dongle.
                • tecnoundefined
                  tecno @fcwilt
                  @fcwilt
                  Hmmm how can one trigger Android phone camera via Telnet using OPen Camera app ?
                  • fcwiltundefined
                    fcwilt @tecno
                    @fcwilt
                    I have no idea.
                    I just mentioned that it is a way to get data from the printer to a program running on some device on the same network.
                    In my case the program is running on a Windows machine which is up 24/7. The program receives messages from the printer and turns them into email messages to me.
                    • tecnoundefined
                      tecno @fcwilt
                      Waking up this question I have.
                      Mini5+ IO1 out
                      To
                      Sony Experia
                      Can somebody help me out to get this combo working, so I can get filming slowmotion of my prints.
                      I prefere this way = no cable = easier to place camera as I want
                      • tecnoundefined
                        tecno @tecno
                        Is this possible to drive from IO_1 on Mini5+ ?
                        • tecnoundefined
                          tecno @tecno
                          Is this OK?
                          alankilianundefined 1 Reply Last reply Reply Quote 0
                          • alankilianundefined
                            alankilian @tecno
                            @tecno said in Mini5+ BT dongle for transmit.:
                            Is this OK?
                            If it is not, would you be willing to hook up a hobby servo and have it physically push the button under command of the Duet?
                            • oliofundefined
                              oliof
                              @alankilian or, if a servo is undesirable, trigger the button mechanically, as exemplified in https://youtu.be/NgZZzi6sRDU
                              • tecnoundefined
                                tecno @oliof
                                @oliof @alankilian
                                Neither solution is desirable.
                                  alankilian @tecno
                                  @tecno OK, do you know that the momentary switch is normally-open and then closes to ground when you press the button?
                                  Can you try jumpering with a wire from the switch to ground on the PCB to verify it triggers?
                                  If that's true I think your schematic will work fine.
                                  • tecnoundefined
                                    tecno @alankilian
                                    @alankilian
                                    Yes it works that way. As I do not want to blow up IO_1, so do I need any protection? I do not think so but better ask twice 🙂
                                      alankilian @tecno
                                      @tecno
                                      I would put a series resistor inline.
                                      Maybe 100 Ohms to 1,000 Ohms and try it.
                                      That will help protect the Duet.
                                      I don't think you need any kind of flyback diode for this.
                                      • tecnoundefined
                                        tecno @alankilian
                                        Hi guys,
                                        This does not work, 3.3V is not present on IO_1 pin 3.3V_ext. Obviously I have understood this wrong.
                                        So where can I borrow 3.3V? TEMP is occupied, External drivers pin6 ?
                                        • tecnoundefined
                                          tecno @tecno
                                          Hi guys,
                                          Anybody??
                                          tecnoundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                          • tecnoundefined
                                            tecno @tecno
                                            Problem solved, pin6 on External Drivers for 3.3V
                                            Now some codeing to get this working.
