    Does it needs to be faster?
    My Duet controlled machine
    599
    • Chrissundefined
      Chriss
      https://vimeo.com/manage/videos/573254834
      matt3oundefined 1 Reply Last reply Reply Quote 0
      • jens55undefined
        jens55
        I didn't see it actually lifting off so yes, it needs to be faster ....
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @jens55
          @jens55
          You are right.. the b*tch should start flying... 😄
          • matt3oundefined
            matt3o @Chriss
            @chriss it seems it is banging the head twice against the frame... I'd say you need to go a little slower....
            jens55undefined Chrissundefined 2 Replies Last reply Reply Quote 1
            • jens55undefined
              jens55 @matt3o
              @matt3o, that wasn't the question. The question was 'does it need to go faster'. No parameters where mentioned so a bit of knocking shouldn't really enter into the equation 🙂
              • matt3oundefined
                matt3o @jens55
                @jens55 there's no such thing as "fast enough" in 3d printing 😄
                jens55undefined 1 Reply Last reply Reply Quote 0
                • jens55undefined
                  jens55 @matt3o
                  @matt3o ... exactly! Layer shift and crumbling print be damned 🙂
                  • mrehorstdmdundefined
                    mrehorstdmd
                    Servomotors FTW!
                    • Chrissundefined
                      Chriss @matt3o
                      @matt3o
                      That is what you hear, indeed. But it happens in slower speed too. The switches are to flush, so the always have the "mechanical" impact. That is the next thing. 😉 And I have to reduce the speed a lot, that was for testing and to swank only. 😉
                      I'm sooo happy that the tiny nema14 are now able to move everything in high speed. The V0 skipped steps at 130mm/s with the old stepper.
                      Cheers, Chriss
                      zaptaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                      • zaptaundefined
                        zapta @Chriss
                        @chriss, did you purchase a kit or did you source the parts individually? With Vorons, if you stick to the sourcing list the parts (and steppers in this case) should be good.
                        • fcwiltundefined
                          fcwilt @Chriss
                          @chriss
                          IR Beam Break devices for position sensing are nice - they are accurate and silent.
