    First layer issues-Extrusion volume dropping on first layer?
    2.2k
    • rkarondeundefined
      rkaronde
      For a while I have been having issues with first layer when printing models that have a large surface area on the first layer.
      The bed is pretty flat and the print starts out well and as the first layer progresses the bottom infill does not stick well.
      I went through the normal debugging with Z Probe, bed leveling etc. Things I have tried that did not make a difference.
      • Rebuilt the Z-axis to make sure nothing is loose.
      • Switched between BL-Tocuh and SuperPinda
      • Printed with Mesh Bed Leveling ON and OFF
      • Switched between using TWO Z Motors and ONE
      • Tried PrusaSlicer and Simplify3D
      • Tried with Pressure Advance ON and OFF
      • Tried a few different filaments
      When nothing seemed to solve it I tried a few different infill patterns that go in different directions, this was to make sure the issue is not with bed leveling. The model is just a rectangle with 0.2mm height and printed with PLA
      I tried
      • Monotonic infill (goes from Right to Left)
      • Concentric (outside to inside)
      • Hilbert curve (starts out bottom left and moves through the layer and end bottom right)
      With these infill patterns the issue seemed to be with extrusion "slowing down" as the first layer progresses, since the gaps in infill increase by the end of first layer.
      So I replaced the extruder stepper motor and made sure the Bondtech Extruder is setup correctly.
      Still the issue persists. So I am kind of lost on what the next steps are to debug this issue.
      I have attached a photo with two printouts of the first layer (Monotonic and Hilbert infill style)
      With the Hilbert curve style the layer sticks well all through, and there are no bumps to touch, but at the end of the layer the gap between the fractals ends has increased a lot.
      config.g
      bed.g
      diag.txt
      Is there something else I can monitor during the print to check on extrusion.
      fcwiltundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @rkaronde
        @rkaronde
        The thing that helped me the most with first layer adhesion was slow speed -15 mm/s.
        I use plain old "rectilinear" infill for all surface layers.
        I have no idea what those infill types are.
        I've never experienced any sort of extruder slow down so I have no idea what might be causing it.
        Fredeick
        rkarondeundefined 1 Reply Last reply Reply Quote 0
        • rkarondeundefined
          rkaronde @fcwilt
          @fcwilt Adhesion is not a problem, and the first layer speed is slow 20mm/s.
          Monotonic is just rectilinear if there are no other patterns in the first layer.
          I used Hilbert Curve for the first time because I wanted to make the infill start from left side and go to right to make sure this is not an issue with bed leveling.
          fcwiltundefined 1 Reply Last reply Reply Quote 1
          • fcwiltundefined
            fcwilt @rkaronde
            @rkaronde said in First layer issues-Extrusion volume dropping on first layer?:
            When you tried mesh compensation did you create the height map with the bed hot? That can make a big difference.
            When I start a print I pre-heat the bed for 15 mins.
            • rkarondeundefined
              rkaronde @fcwilt
              @fcwilt Yup. I ran about 25 test with all the tweaks I mentioned, and most of the time I kept the bed hot when just changing config.g, etc.
              For any hardware change I let the bed heat for a while, not 15 min, but around 5.
              • fcwiltundefined
                fcwilt @rkaronde
                @rkaronde
                I posted your files using the </> tag.
                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Mon Feb 17 2020 22:28:24 GMT-0500 (Eastern Standard Time)
                G90                                            ; send absolute coordinates...
                M83                                            ; ...but relative extruder moves
                M550 P"SKGo"                                   ; set printer name
                M669 K1                                        ; select CoreXY mode
                M552 S1                                        ; enable network
                M586 P0 S1                                     ; enable HTTP
                M586 P1 S0                                     ; disable FTP
                M586 P2 S0                                     ; disable Telnet
                ;Set PanelDue 7i
                M575 P1 B57600 S1
                M584 X0 Y1 Z2:4 E3                             ; set drive mapping (dual Z on driver 2 and 4)
                ;M584 X0 Y1 Z2 E3                               ; set drive mapping
                M569 P0 S1                                     ; physical drive 0 goes forwards
                M569 P1 S1                                     ; physical drive 1 goes forwards
                M569 P2 S1                                     ; physical drive 2 goes forwards
                M569 P3 S0                                     ; physical drive 3 goes backwards
                ;Z Leadscrew locations
                M671 X-10:310  Y150:150 S5  ;left, Right  S5 is the max correction - measure your own offsets, to the bolt for the yoke of each leadscrew
                M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                ;motor currents
                M906 X1100 Y1100 Z1100 E800 I60                ; LDO LDO-42STH40-1684MAC  ZZZ Motor Currents (mA). 2.375A is peak of 1.68A RMS, 1.9A is 80% of 2.375A
                                                               ; set motor currents (mA) and motor idle factor in
                ; Accelerations
                M201 X4000 Y4000                               ; Accelerations (mm/s^2)
                M201 Z1000                                     ; LDO ZZZ Acceleration
                M201 E1500.00                                  ; Extruder acceleration (mm/s^2)
                M203 X24000.00 Y24000.00 Z900.00 E3600.00      ; set maximum speeds (mm/min)
                M566 X1000.00 Y1000.00 Z300 E1500.00           ; set maximum instantaneous speed changes (mm/min)
                ;M92 X200.00 Y200.00 Z1600.00 E830              ; set steps per mm
                M92 X200.00 Y200.00 Z800.00 E415              ; set steps per mm
                M84 S30                                        ; Set idle timeout
                M208 X0 Y0 Z0 S1                               ; set axis minima
                M208 X305 Y302 Z340 S0                         ; set axis maxima
                M574 X1 Y1 S3					; set X endstops to use motor stall
                M574 Z1 S2      				; set z-Probe
                ; Z-Probe PINDA
                M558 P5 C"^zprobe.in" I1 H0.7 F800 T6000 A20 S0.03 ; PINDA
                ;M308 S2 P"e1_temp" A"PINDA" Y"thermistor" T100000 B3950    ;thermistor on the PINDA
                G31 P500 X0 Y-27 Z2.23                                    ;yellow sheet   ; set Z probe trigger value, offset of 0 in X and -27 in Y and trigger height
                M557 X5:290 Y5:270 S20                                ; define mesh grid
                ; Z-Probe BLTouch
                ;M574 Z1 S2 ; Set endstops controlled by probe
                ;M558 P9 C"^zprobe.in" H4 F150 T8000
                ;M950 S0 C"exp.heater3"
                ;G31 P25 X23 Y0 Z3.485                                   ; set Z probe trigger value, offset of -22 in X and 0 in Y and trigger height (Slice 0.4)
                ;G31 P25 X23 Y0 Z3.196                                   ; set Z probe trigger value, offset of -22 in X and 0 in Y and trigger height  (E3D 0.8)
                ;M557 X10:295 Y10:295 S20                                ; define mesh grid
                ;Filament sensor
                M591 D0 P5 C"e0stop" R100:350 E10.0 S1  ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 100 to 350%, 10mm comparison length, Enabled
                ; Bed Heater
                M308 S0 P"bedtemp" Y"thermistor" T100000 B4138            ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0                                     ; create bed heater output on bedheat and map it to sensor 0
                M140 H0                                                   ; map heated bed to heater 0
                M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
                M307 H0 A191.5 C435.9 D4.3 V24.3 B0                       ; disable bang-bang mode for bed heater and set PID autotune PWM values
                ; Extruder Heater
                ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725  C7.06e-8   ; configure sensor 1 as Hemera thermistor on pin e0temp
                M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.196220e-7
                M950 H1 C"e0heat" T1                                      ; create nozzle heater output on e0heat and map it to sensor 1
                M143 H1 S440                                              ; set temperature limit for heater 1 to 390C
                M950 F0 C"fan0" ;Q200                           ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan2" Q15000                           ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S0.7 H1 ;L200 X250 H1 T60:140                ; set fan 1 value. Thermostatic control is turned on. Min speed of 120 as 60 deg, and max speed for 200 (255 is 100%) at 140+degrees
                M563 P0 D0 H1 F0                               ; define tool 0
                G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                M501						; Load config-override.g
                T0                                             ; select first tool
                M561                         ; clear any existing bed transform
                G28 ; home
                M558 H1
                G30 P0 X15 Y150 Z-99999 ; probe near a leadscrew, half way along Y axis
                G30 P1 X285 Y150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                ;do it again
                ;finally home Z again at the center of the bed
                G1 X150 Y177 F6000
                G30 ;single z probe
                • fcwiltundefined
                  fcwilt @rkaronde
                  @rkaronde
                  When you create or load the height map are you first setting the Z=0 datum using G30?
                  • rkarondeundefined
                    rkaronde @fcwilt
                    @fcwilt Yes, in bed.g, at the end, there is a G30 at the center on the bed. The mesh leveling happens after bed.g is run.
                    • fcwiltundefined
                      fcwilt @rkaronde
                      Have you tried upping the extrusion multiplier using M221 or the DWC slider control?
                        Calibrate your extruder and tune your extrusion multiplier.
                        https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                        I wouldn't use hilbert curve as an indicator of first layer quality. It's not really a suitable pattern for first layer with all the direction changes. The extrusion could become so slow that the filament starts to cook in the hotend.
                        Show us your slicer settings. Upload a sliced gcode file.
                        • rkarondeundefined
                          rkaronde @Phaedrux
                          @phaedrux Calibrated the Esteps and extrusion multiplier. ESteps did not change, the extrusion multiplier changed by 0.01, so went from 1 -> 1.01.
                          Running a few more tests it looks like an issue with Z distance between bed and nozzle increasing as the first layer progresses.
                          On a 150x150mm square print with reclinear infill the layer stops sticking halfway through the layer, I then reduced the distance using baby step, and kept doing that as the print stops sticking again. At the end of the layer I had to move the nozzle closer by 0.2mm (-0.2)!!!. That is a lot.
                          I tried heating bed for 15 min before starting print/probing to see if thermal expansion is somehow involved. But that did not help and the print still did not stick halfway through.
                          Next heated the bed for a while and then ran mesh bed leveling. Then moved the head to various points on the bed with a piece of paper under it to see if the nozzle is close to the bed. And the paper is being gripped by the nozzle correctly. If I raise the bed by 0.2mm the paper does not grip. So the moving the bed using the bed using the Dashboard is maintaining the nozzle distance correctly.
                          Attaching the gcode of the file I used, and slicer settings.IMG_1974.jpg Platter.png Layers.png Filament.png Cooling.png Speeds.png
                          150x150_center_0.2mm_PLA__50m.gcode
                          Also adding the height map, it is pretty level in the middle of the bed.
                            Instead of a large flat full infill print try something like this STL instead.
                            bedlevel_nozzle_0.4_200x200-0.3-0.8.stl
                            • o_lampeundefined
                              o_lampe @rkaronde
                              @rkaronde
                              Do you see skipped steps for the Z-axis?
                              That's the only explanation, why it keeps gripping the paper when moved manually, but building up a gap when it does mesh levelling
                              • rkarondeundefined
                                rkaronde @Phaedrux
                                Printed without an issue.
                                The lines are pretty well stuck to the bed, and I could see the Z motors move when printing near the bump in the front part of the bed.
                                • rkarondeundefined
                                  rkaronde @o_lampe
                                  @o_lampe I have not heard any skipping, not sure if there is any way to measure the skipping.
                                  Also in the middle of the bed the Z motors don't actually have to move since the bed is pretty flat. I also marked the Z motor pulley with a Sharpie and it does not move from the initial position printing infill in the center of the bed.
                                  This is a CoreXY with bed moving up/down, so if Z is stable then I would think the X gantry is somehow moving up (not sure how that can happen). I also did the bedlevel_nozzel print suggested by Phaedrux and that stuck well all through.
                                  The reason I am trying large flat full infill print as test is because I ran into this issue when printing large footprint models/STLs and got into debugging.
                                  I am going to recheck for any mechanical issues.
                                  engikeneerundefined Phaedruxundefined o_lampeundefined 3 Replies Last reply Reply Quote 0
                                  • engikeneerundefined
                                    engikeneer @rkaronde
                                    @rkaronde silly question time... you don't have any PLA parts supporting your hot bed that are warping under heat/load during the print are you? When I first started printing ABS on my printer I spent days trying to figure out why my z offset ket changing before realised my bed supports had basically melted... 😛
                                    i3 clone with a bunch of mods
                                    • rkarondeundefined
                                      rkaronde @engikeneer
                                      @engikeneer Fair question.
                                      Except for the cooling duct and PINDA holder this printer does not use any plastic parts, it is all metal.
                                      https://seckit3dp.design/kit/sk-go2-essential
                                        Phaedrux Moderator @rkaronde
                                        This may be more of an extrusion or cooling issue then.
                                        Can you confirm the fan is off for the first layer?
                                        Have you tried upping the first layer hotend and bed temp a bit? Maybe 65c bed, 225c nozzle?
                                        What is your first layer extrusion width?
                                        • rkarondeundefined
                                          rkaronde @Phaedrux
                                          @phaedrux Yes the cooling fan is OFF for the first layer
                                          The first layer extrusion width is 0.42mm (nozzle is 0.4mm), should I try a different extrusion width?
                                          I will try upping the temps.
                                          Thanks
                                          • fcwiltundefined
                                            fcwilt @rkaronde
                                            Thanks
                                            What is your first layer speed
                                            What is the first layer height as opposed to the normal layer height?
                                            Thanks.
